楼主: lidicn
[插件集成] 蓝牙距离检测【蓝牙手环】【手机蓝牙】【ble】【ibeacon】
发表于 2018-9-23 21:50:20 | 显示全部楼层
正好有我需要的功能,测量蓝牙距离
严重灌水用户
发表于 2018-9-23 22:12:10 | 显示全部楼层
牙距离检测【蓝牙手环】【手机蓝牙】【
发表于 2018-9-23 23:34:11 | 显示全部楼层
谢谢楼主分享。
发表于 2018-9-24 00:24:44 | 显示全部楼层
发现是容器缺少bluepy,安装后又出现权限问题....
2018-09-24 00:29:34 ERROR (MainThread) [homeassistant.components.sensor] ble_presence: Error on device update!
  File "/usr/src/app/homeassistant/helpers/entity_platform.py", line 248, in _async_add_entity
    await entity.async_device_update(warning=False)
  File "/usr/src/app/homeassistant/helpers/entity.py", line 320, in async_device_update
    yield from self.async_update()
  File "/usr/local/lib/python3.6/asyncio/coroutines.py", line 212, in coro
    res = func(*args, **kw)
  File "/config/custom_components/sensor/ble_presence.py", line 106, in async_update
    devices = scanner.scan(10.0)
  File "/usr/local/lib/python3.6/site-packages/bluepy/btle.py", line 734, in scan
    self.start(passive=passive)
  File "/usr/local/lib/python3.6/site-packages/bluepy/btle.py", line 672, in start
    self._mgmtCmd("le on")
  File "/usr/local/lib/python3.6/site-packages/bluepy/btle.py", line 279, in _mgmtCmd
    rsp = self._waitResp('mgmt')
  File "/usr/local/lib/python3.6/site-packages/bluepy/btle.py", line 338, in _waitResp
    raise BTLEException(BTLEException.MGMT_ERROR, "Management not available (permissions problem?)")
bluepy.btle.BTLEException: Management not available (permissions problem?)
问问还需要什么依赖吗?报错好像少依赖
2018-09-24 00:21:52
ERROR (MainThread) [homeassistant.loader] Error loading custom_components.sensor.ble_presence. Make sure all dependencies are installed
  File "/usr/src/app/homeassistant/loader.py", line 94, in get_component
    module = importlib.import_module(path)
  File "/usr/local/lib/python3.6/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 994, in _gcd_import
  File "<frozen importlib._bootstrap>", line 971, in _find_and_load
  File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 665, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 678, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/config/custom_components/sensor/ble_presence.py", line 11, in <module>
    from bluepy.btle import Scanner, DefaultDelegate
ModuleNotFoundError: No module named 'bluepy'
发表于 2018-9-24 00:55:57 | 显示全部楼层
大神你可不要骗我哦
发表于 2018-9-24 01:32:18 | 显示全部楼层
看看能做什麼..............
发表于 2018-9-24 08:06:02 来自手机 | 显示全部楼层
学习学习
发表于 2018-9-24 13:35:10 | 显示全部楼层
学习学习
发表于 2018-9-24 20:45:39 | 显示全部楼层
dfds asdsadsd
参与人数 1金钱 -100 收起 理由
-100 灌水
发表于 2018-9-24 21:40:59 | 显示全部楼层
谢谢分享!!!!!!!
GMT+8, 2026-1-16 04:48 , Processed in 0.909259 second(s), 13 queries , MemCached On.
