查看: 9752|回复: 8
[求助] 升级0.78后hass.io选项消失.....
发表于 2018-9-22 10:33:32 | 显示全部楼层 |阅读模式
RT:升级0.78后hass.io选项消失.....以下是错误信息:
18-09-21 19:46:01 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
18-09-21 20:11:35 ERROR (MainThread) [hassio.homeassistant] Error on call [url=http://172.30.32.1:8123/api/:]http://172.30.32.1:8123/api/:[/url]
18-09-21 20:11:42 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished coro=<Tasks._watchdog_homeassistant_api() done, defined at /usr/local/lib/python3.7/site-packages/hassio/tasks.py:109> exception=UnboundLocalError("local variable 'err' referenced before assignment")>
  File "/usr/local/lib/python3.7/site-packages/hassio/tasks.py", line 126, in _watchdog_homeassistant_api
    await self.sys_homeassistant.check_api_state():
  File "/usr/local/lib/python3.7/site-packages/hassio/homeassistant.py", line 439, in check_api_state
    _LOGGER.warning("Home Assistant API config mismatch: %d", err)
UnboundLocalError: local variable 'err' referenced before assignment
18-09-21 00:35:41 INFO (MainThread) [__main__] Initialize Hass.io setup
18-09-21 00:35:59 INFO (MainThread) [__main__] Run Hass.io
18-09-21 00:35:59 INFO (MainThread) [hassio.core] Ignore Hass.io auto updates on dev channel
18-09-21 00:35:59 INFO (MainThread) [hassio.core] Hass.io reboot detected
18-09-21 00:35:59 INFO (MainThread) [hassio.core] Hass.io is up and running
发表于 2018-9-22 10:57:53 | 显示全部楼层
docker images | grep hassio-supervisor | awk '{print $2}'
看看 hassio 版本是多少,最新是131。如果是低于这个版本,请使用以下方法升级hassio。
curl -SsL https://raw.githubusercontent.com/neroxps/hassio_install/master/hassio_upgrade.sh
bash hassio_upgrade.sh
 楼主| 发表于 2018-9-22 13:04:16 | 显示全部楼层
hassio的版本是131的,重新启动后也没有hass.io选项,随后我在树莓派终端apt-get update了下,发现官方dock源有问题,无法更新了,于是手动替换了国内源,再upgrade了一下,更新了下docker-ce,然后重新启动hassio 一切正常了。。。。。很奇怪,难道docker也会影响到hassio?
发表于 2018-9-22 22:51:36 | 显示全部楼层
plutosherry 发表于 2018-9-22 13:04
hassio的版本是131的,重新启动后也没有hass.io选项,随后我在树莓派终端apt-get update了下,发现官方do ...
当然啊,特别是 docker网络部分。
 楼主| 发表于 2018-9-23 16:50:05 | 显示全部楼层
neroxps 发表于 2018-9-22 22:51
当然啊,特别是 docker网络部分。
感谢回复!受教了
发表于 2018-12-13 11:31:44 | 显示全部楼层
楼主能详细说说怎么操作的吗
我和你一样的问题 现在困扰中... X86平台 centos docker hassio
hassio140升级141 开始返回502 bad gateway,后来不知道怎么的升级了 hassio边栏就没了
 楼主| 发表于 2018-12-14 17:01:28 | 显示全部楼层
ghostist 发表于 2018-12-13 11:31
楼主能详细说说怎么操作的吗
hassio140升 ...
ssh到i设备后使用如下命令即可
curl -SsL [url]https://raw.githubusercontent.com/neroxps/hassio_install/master/hassio_upgrade.sh[/url]
发表于 2018-12-14 21:39:08 | 显示全部楼层
plutosherry 发表于 2018-12-14 17:01
ssh到i设备后使用如下命令即可
[code]curl -SsL https://raw.githubusercontent ...
我其实在线升级成功了 只是重启容器没有效果,reboot设备不知道怎么了没起来
回家断电重启 自己就好了
hassio版本就上去了 HA又点了升级 也自动完成
 楼主| 发表于 2018-12-15 15:05:13 | 显示全部楼层
回家断电重启 自己就好了
ha ...
是的,版本升级有时候是需要将整个服务都重新启动一下的。光重启hass或者hassio可能会出现莫名其妙的问题了
GMT+8, 2025-12-16 06:57 , Processed in 0.076279 second(s), 7 queries , MemCached On.
