楼主: SchumyHao
[进阶教程] 桥接若琪rokid和homeassistant
发表于 2017-7-6 16:29:44 | 显示全部楼层
这个牛逼了,可惜设备贵了点
发表于 2017-7-6 16:59:16 | 显示全部楼层
牛B的妖神!!感谢分享!!
wqqs 手机认证
活跃会员
发表于 2017-7-6 17:03:40 | 显示全部楼层
这个必须顶,妖神V5
发表于 2017-7-6 17:33:22 | 显示全部楼层
威联通NAS怎么安装呢,在docker没有找到镜像
发表于 2017-7-6 17:59:19 | 显示全部楼层
支持!!!!!!!!!!!!!!!!!
Jeff
活跃会员
发表于 2017-7-6 19:42:11 | 显示全部楼层
妖神 我的还是不行 错误日志附上
Process POST /list...
stdout
11:37:33
stdout
11:37:33
  Error: Cannot find module 'request-promise-core/configure/request2'
stdout
11:37:33
      at Function.Module._resolveFilename (module.js:485:15)
stdout
11:37:33
      at Function.Module._load (module.js:437:25)
stdout
11:37:33
      at Module.require (module.js:513:17)
stdout
11:37:33
      at require (internal/module.js:11:18)
stdout
11:37:33
      at Object.<anonymous> (/usr/local/lib/node_modules/homebase-hass-bridge/node_modules/request-promise/lib/rp.js:4:17)
stdout
11:37:33
      at Module._compile (module.js:569:30)
stdout
11:37:33
      at Object.Module._extensions..js (module.js:580:10)
stdout
11:37:33
      at Module.load (module.js:503:32)
stdout
11:37:33
      at tryModuleLoad (module.js:466:12)
stdout
11:37:33
      at Function.Module._load (module.js:458:3)
stdout
11:37:33
stdout
11:37:33
stdout
11:37:33
      at POST /list (/usr/local/lib/node_modules/homebase-hass-bridge/controllers/list.js:8:14)
stdout
11:37:33
      at dispatch (/usr/local/lib/node_modules/homebase-hass-bridge/node_modules/koa-compose/index.js:42:32)
stdout
11:37:33
      at next (/usr/local/lib/node_modules/homebase-hass-bridge/node_modules/koa-compose/index.js:43:18)
stdout
11:37:33
      at /usr/local/lib/node_modules/homebase-hass-bridge/node_modules/koa-router/lib/router.js:345:16
stdout
11:37:33
stdout
11:37:33
      at /usr/local/lib/node_modules/homebase-hass-bridge/node_modules/koa-compose/index.js:34:12
stdout
11:37:33
      at dispatch (/usr/local/lib/node_modules/homebase-hass-bridge/node_modules/koa-router/lib/router.js:350:31)
stdout
11:37:33
stdout
11:37:33
stdout
11:37:33
      at parseBody.then.body (/usr/local/lib/node_modules/homebase-hass-bridge/node_modules/koa-bodyparser/index.js:74:14)
stdout
11:37:33
      at <anonymous>
stdout
11:37:33
      at process._tickCallback (internal/process/next_tick.js:169:7)
Jeff
教程狂人卓越贡献突出贡献
 楼主| 发表于 2017-7-6 21:13:55 | 显示全部楼层
karl_31 发表于 2017-7-6 19:42
妖神 我的还是不行 错误日志附上
[code]Process POST /list...
stdout
刚才帮助Jeff解决了这个问题.
但是比较奇怪. 同一个image, 他那里相关的依赖包却不完全.
我把我本地的image都删除了重新pull试试.
如果遇到同样问题的童鞋, 可以将本地缓存的image镜像删掉. 重新下载试试.
如果还没有解决, 可以exec到container中, 进入/usr/local/lib/node_modules/homebase-hass-bridge
将目录下的node_modules全部删除, 再在目录下输入npm install重新安装依赖包.
发表于 2017-7-6 21:54:47 来自手机 | 显示全部楼层
厉害啊,膜拜!!
论坛风云人物
发表于 2017-7-7 00:25:13 | 显示全部楼层
妖神就是妖神,支持支持
eddy
发表于 2017-7-7 00:37:06 | 显示全部楼层
感谢老妖,让我到货许久的若琪开了封,哈哈
反馈一下安装结果  :目前前面的所有动作都已经完成,系统Ubuntu16.04 安装node --versionv8.1.3 成功
目前卡在最后这一步上:
结束
正常情况下, 上述操作完成后就可以在rokid的app中扫描到homeassistant中现在支持的设备了. 下一步可以自行对每个设备的tag进行定义.享受使用rokid控制家中设备的乐趣.
我目前在rokid 的app上,智能家居选项中,没有扫描到 homeassistant支持的设备,(就是说,目前我已经添加在homeassistant中的设备)
他们就显示很多个不同厂家的品牌,小米,飞利浦等等信息,其他的,每一看到。。
GMT+8, 2025-12-16 02:03 , Processed in 1.167621 second(s), 6 queries , MemCached On.
