楼主: 2643223380
[插件集成] 用爬虫的方式实现国内油价查询
 楼主| 发表于 2018-9-13 20:59:25 | 显示全部楼层
情非殇 发表于 2018-9-12 11:24
感谢楼主,实测可行
[code]
#分享非插件城市汉化方法
不错不错,
发表于 2018-9-14 20:01:41 | 显示全部楼层
感谢分享,学习了……
发表于 2018-9-15 13:55:10 | 显示全部楼层
2018-09-15 13:50:15 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template 0#柴油, the state is unknown.
2018-09-15 13:50:15 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template 更新时间, the state is unknown.
2018-09-15 13:50:15 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template 92#汽油, the state is unknown.
2018-09-15 13:50:15 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template 95#汽油, the state is unknown.
2018-09-15 13:50:15 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template 原油价格, the state is unknown.
2018-09-15 13:50:15 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template 98#汽油, the state is unknown.
2018-09-15 13:50:15 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template 原油价更新时间, the state is unknown.
2018-09-15 13:50:15 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template 城市, the state is unknown.
这是怎么回事?
 楼主| 发表于 2018-9-15 20:55:40 | 显示全部楼层
ilikehassbian 发表于 2018-9-15 13:55
2018-09-15 13:50:15 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render ...
你用的是后面修改的包还是原来那个?
你现在的情况是爬虫没有运行成功。
发表于 2018-9-15 23:59:37 | 显示全部楼层
用后来的那个不知道啥原因我的也没爬成功。
发表于 2018-9-16 00:01:09 | 显示全部楼层
2018-09-15 23:54:49 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template 0#柴油, the state is unknown.
2018-09-15 23:54:49 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template 爬虫时间, the state is unknown.
2018-09-15 23:54:49 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template 原油价格, the state is unknown.
2018-09-15 23:54:49 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template 城市, the state is unknown.
2018-09-15 23:54:49 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template 原油价更新时间, the state is unknown.
2018-09-15 23:54:49 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template 92#汽油, the state is unknown.
2018-09-15 23:54:49 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template 95#汽油, the state is unknown.
 楼主| 发表于 2018-9-17 12:06:48 | 显示全部楼层
2018-09 ...
你把整个log,发上来,这样好判断,你这个错误信息,看不出什么的
发表于 2018-9-20 09:17:12 | 显示全部楼层
汉化也可以这样写:
可以少调用一个sensor
  - platform: template
    sensors:
      youjia_city:
        friendly_name: "所在城市"
        value_template: '{% if states.sensor.youjia.attributes.city == "hubei" %}湖北{% else %}{{states.sensor.youjia.attributes.city}}{% endif %}'
发表于 2018-10-11 10:53:25 | 显示全部楼层
顶部badge内的油价,怎么自定义为92#的价格,而不是原油价格,我现在显示的是原油价格
 楼主| 发表于 2018-10-15 22:46:17 | 显示全部楼层
你进行group分组
GMT+8, 2026-1-5 16:04 , Processed in 1.766490 second(s), 14 queries , MemCached On.
