楼主:
HASSMART定制窗帘电机使用教程
发表于 2019-2-12 06:31:57 来自手机 | 显示全部楼层
mark 窗帘
发表于 2019-2-25 13:23:58 | 显示全部楼层
固件设置界面终于用上bootstrap上了,好看多了。哈哈。
发表于 2019-4-1 12:39:40 | 显示全部楼层
支持支持,买了房子来一波
发表于 2019-4-1 22:35:21 | 显示全部楼层
楼主,
你好。
我是用了Configure UI自己手动修改UI,导致我HA页面的位置图Graph不会自动出现。如下:
要如何解决呢?
谢谢!
发表于 2019-4-12 16:42:45 | 显示全部楼层
给力,买了好几个。回头装上试试
发表于 2019-4-13 08:11:21 | 显示全部楼层
老大,日志显示这些,hassio 最新版
2019-04-12 04:10:16 ERROR (MainThread) [homeassistant.components.device_tracker] Unable to load /config/known_devices.yaml: Config file not found: /config/known_devices.yaml
2019-04-12 04:10:16 WARNING (MainThread) [homeassistant.loader] You are using a custom component for sonoff.switch which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-04-12 04:10:18 WARNING (MainThread) [homeassistant.loader] You are using a custom component for sonoff.sensor which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-04-12 04:10:26 ERROR (MainThread) [homeassistant.loader] Integrations need to be in their own folder. Change cover/hassmart.py to hassmart/cover.py. This will stop working soon.
2019-04-12 05:10:11 ERROR (MainThread) [homeassistant.components.updater] Got unexpected response: None
2019-04-12 06:25:11 ERROR (Thread-2) [websocket] error from callback <bound method Sonoff.on_message of <custom_components.sonoff.Sonoff object at 0xffff80b3f748>>: 'NoneType' object has no attribute 'attributes'
2019-04-12 07:17:30 ERROR (Thread-8) [custom_components.cover.hassmart] recv data error: timed out
2019-04-12 07:17:30 ERROR (Thread-6) [custom_components.cover.hassmart] recv data error: timed out
2019-04-12 07:17:30 ERROR (Thread-5) [custom_components.cover.hassmart] recv data error: timed out
2019-04-12 07:17:30 ERROR (Thread-7) [custom_components.cover.hassmart] recv data error: timed out
2019-04-12 07:18:00 ERROR (Thread-8) [custom_components.cover.hassmart] recv data error: timed out
2019-04-12 07:18:00 ERROR (Thread-8) [custom_components.cover.hassmart] timeout > 1, recreating socket
2019-04-12 07:18:00 ERROR (Thread-6) [custom_components.cover.hassmart] recv data error: timed out
2019-04-12 07:18:00 ERROR (Thread-6) [custom_components.cover.hassmart] timeout > 1, recreating socket
2019-04-12 07:18:00 ERROR (Thread-5) [custom_components.cover.hassmart] recv data error: timed out
2019-04-12 07:18:00 ERROR (Thread-7) [custom_components.cover.hassmart] recv data error: timed out
2019-04-12 07:18:00 ERROR (Thread-5) [custom_components.cover.hassmart] timeout > 1, recreating socket
2019-04-12 07:18:00 ERROR (Thread-7) [custom_components.cover.hassmart] timeout > 1, recreating socket
2019-04-12 07:18:30 ERROR (Thread-5) [custom_components.cover.hassmart] recv data error: timed out
2019-04-12 07:18:30 ERROR (Thread-6) [custom_components.cover.hassmart] recv data error: timed out
2019-04-12 07:18:30 ERROR (Thread-7) [custom_components.cover.hassmart] recv data error: timed out
2019-04-12 07:18:30 ERROR (Thread-8) [custom_components.cover.hassmart] recv data error: timed out
2019-04-12 07:19:00 ERROR (Thread-5) [custom_components.cover.hassmart] recv data error: timed out
2019-04-12 07:19:00 ERROR (Thread-7) [custom_components.cover.hassmart] recv data error: timed out
2019-04-12 07:19:00 ERROR (Thread-6) [custom_components.cover.hassmart] recv data error: timed out
2019-04-12 07:19:00 ERROR (Thread-5) [custom_components.cover.hassmart] timeout > 1, recreating socket
2019-04-12 07:19:00 ERROR (Thread-7) [custom_components.cover.hassmart] timeout > 1, recreating socket
2019-04-12 07:19:00 ERROR (Thread-8) [custom_components.cover.hassmart] recv data error: timed out
发表于 2019-4-14 21:08:12 | 显示全部楼层
很棒呀,支持一下!!!
发表于 2019-4-17 01:23:30 | 显示全部楼层
这是我最想买的组件
佑桑
发表于 2019-4-30 11:59:59 | 显示全部楼层
從 0.91.4 升級上 0.92.1 後無法使用了
請問該如何解決?
 楼主| 发表于 2019-4-30 12:35:25 | 显示全部楼层
請問該如何解決?
https://bbs.hassbian.com/thread-6768-1-1.html
GMT+8, 2026-1-17 13:54 , Processed in 0.532576 second(s), 12 queries , MemCached On.
