查看: 17065|回复: 12
[求助] 有没有大侠试过往网关加超过 5 个 Aqara 墙壁插座的
发表于 2018-9-10 21:59:59 | 显示全部楼层 |阅读模式
如题…
题主用的Aqara空调伴侣(升级版),刚刚往网关加新的Aqara墙壁插座,一重启HA发现报错了。分析来分析去,把插座从米家APP移除,剩下5个就正常了…想问一下论坛有大侠遇到过这个问题吗?HA里的log是这个样子的:
2018-09-10 21:07:52 DEBUG (Thread-5) [homeassistant.components.xiaomi_aqara] Expecting 1 gateways
2018-09-10 21:07:53 INFO (Thread-5) [homeassistant.components.xiaomi_aqara] Discovering Xiaomi Gateways (Try 1)
2018-09-10 21:07:53 INFO (Thread-5) [xiaomi_gateway] Xiaomi Gateway xxxxxxxxxxxx found at IP 192.168.xx.xx
2018-09-10 21:07:53 INFO (Thread-5) [xiaomi_gateway] Discovering Xiaomi Devices
2018-09-10 21:07:53 DEBUG (Thread-5) [xiaomi_gateway] _send_cmd >> b'{"cmd":"discovery"}'
2018-09-10 21:07:53 ERROR (MainThread) [homeassistant.setup] Error during setup of component xiaomi_aqara
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 148, in _async_setup_component
    component.setup, hass, processed_config)  # type: ignore
  File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
    future.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
    raise self._exception
  File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/xiaomi_aqara.py", line 131, in setup
    xiaomi.discover_gateways()
  File "/srv/homeassistant/lib/python3.5/site-packages/xiaomi_gateway/__init__.py", line 112, in discover_gateways
    resp["proto_version"] if "proto_version" in resp else None)
  File "/srv/homeassistant/lib/python3.5/site-packages/xiaomi_gateway/__init__.py", line 219, in __init__
    if self._discover_devices():
  File "/srv/homeassistant/lib/python3.5/site-packages/xiaomi_gateway/__init__.py", line 226, in _discover_devices
    else self._send_cmd(cmd, "discovery_rsp")
  File "/srv/homeassistant/lib/python3.5/site-packages/xiaomi_gateway/__init__.py", line 313, in _send_cmd
    resp = json.loads(data.decode())
  File "/usr/lib/python3.5/json/__init__.py", line 319, in loads
    return _default_decoder.decode(s)
  File "/usr/lib/python3.5/json/decoder.py", line 339, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/usr/lib/python3.5/json/decoder.py", line 355, in raw_decode
    obj, end = self.scan_once(s, idx)
json.decoder.JSONDecodeError: Expecting ',' delimiter: line 1 column 1025 (char 1024)
发表于 2018-9-11 16:27:57 | 显示全部楼层
是不是有些开关太远了,zigbee信号不好,我家新装修想全部用aqara,居然有这种情况,表示关注
 楼主| 发表于 2018-9-11 17:04:37 | 显示全部楼层
evantalk 发表于 2018-9-11 16:27
是不是有些开关太远了,zigbee信号不好,我家新装修想全部用aqara,居然有这种情况,表示关注 ...
不是距离的问题. 翻了一些资料, 发现答案其实就在报错里.. 小米的网关 py 文件里把 buff 设成了 1024, 所以设备太多就出错了. 我在 GitHub 里提了个 issue, 看看他们改不改吧.
P.S. 还有设备功耗和使用情况的判断, 和墙壁插座的开关控制都有问题, 更神奇的是这些问题网上都没人提起
发表于 2018-9-27 12:42:05 | 显示全部楼层
抚音 发表于 2018-9-11 17:04
不是距离的问题. 翻了一些资料, 发现答案其实就在报错里.. 小米的网关 py 文件里把 buff 设成了 1024, 所 ...
没有问题啊,我接了8个开关,2个门磁,1个人体传感器,5个温湿度,都没有问题
 楼主| 发表于 2018-9-27 21:18:57 | 显示全部楼层
needs 发表于 2018-9-27 12:42
没有问题啊,我接了8个开关,2个门磁,1个人体传感器,5个温湿度,都没有问题 ...
我一共25个ZigBee设备
发表于 2018-9-28 11:39:06 | 显示全部楼层
用Aqara空调伴侣(升级版)问题多,还是接小米二代网关好
发表于 2018-9-29 11:58:52 | 显示全部楼层
我两个网关72个设备没问题啊
 楼主| 发表于 2018-10-4 20:29:40 | 显示全部楼层
pcping 发表于 2018-9-29 11:58
我两个网关72个设备没问题啊
反正我已经把buff改成了2048, 更新完看到还是2048, 不知道是fix了还是改过的文件没被替换, 没人遇到也就无所谓了.
发表于 2018-12-28 17:52:22 | 显示全部楼层
我也遇到上,请问是怎么解决的?
 楼主| 发表于 2019-1-1 22:47:49 | 显示全部楼层
feijichagn 发表于 2018-12-28 17:52
我也遇到上,请问是怎么解决的?
xiaomi网关的配置文件里有两个"_socket.recvfrom(1024)", 把里面的值改成2048试试 路径:
如果还是不行就和我不是同一个问题了, 可以把日志post上来看看.
GMT+8, 2025-12-24 09:30 , Processed in 1.458227 second(s), 8 queries , MemCached On.
