查看: 9534|回复: 3
[技术探讨] 为什么HASS里面左边没有HASS.IO菜单
发表于 2018-9-10 08:48:55 | 显示全部楼层 |阅读模式
为什么我左边没有HASS.IO啊。
我安装环境为:
N1,
docker-ce(单独安装)
root@N1:/# docker version
Client:
Version:           18.06.1-ce
API version:       1.38
Go version:        go1.10.2
Git commit:        e68fc7a
Built:             Tue Aug 21 17:21:14 2018
OS/Arch:           linux/arm
Experimental:      false
Server:
Engine:
  Version:          18.06.1-ce
  API version:      1.38 (minimum version 1.12)
  Go version:       go1.10.3
  Git commit:       e68fc7a
  Built:            Tue Aug 21 17:37:35 2018
  OS/Arch:          linux/arm
  Experimental:     false
LOG中有以下错误:
2018-09-10 08:41:39 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/ping request Cannot connect to host 172.30.32.2:80 ssl:None [Host is unreachable],
2018-09-10 08:41:35 INFO (MainThread) [homeassistant.setup] Setting up hassio,
2018-09-10 08:41:39 ERROR (MainThread) [homeassistant.components.hassio] Not connected with Hass.io,
2018-09-10 08:41:39 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 3.1 seconds.,
2018-09-10 08:41:39 ERROR (MainThread) [homeassistant.setup] Setup failed for hassio: Component failed to initialize.,
2018-09-10 08:41:39 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=persistent_notification, service=create, service_data=title=Invalid config, message=The following components and platforms could not be set up:
发表于 2018-9-10 15:26:18 | 显示全部楼层
网络问题哦。有时候网络卡顿会造成hassio插件安装失败。。。。
发表于 2018-10-24 23:35:21 | 显示全部楼层
楼主这个问题解决了么?
 楼主| 发表于 2018-10-25 01:22:46 | 显示全部楼层
最后重新安装了。
GMT+8, 2025-12-15 23:59 , Processed in 0.645266 second(s), 9 queries , MemCached On.
