查看: 8114|回复: 9
[求助] 【解决】HA0.77.3 一直转圈 进不去
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-9-8 13:19:42 | 显示全部楼层 |阅读模式
删除了.storage  重新创建了帐户,配置文件配置了  就是进不去 一直转圈,浏览器也清空了  好生奇怪
2018-09-08 05:33:04 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 390, in start
    resp = await self._request_handler(request)
  File "/usr/local/lib/python3.6/site-packages/async_upnp_client/aiohttp.py", line 138, in _handle_request
    status = await self.event_handler.handle_notify(headers, body)
  File "/usr/local/lib/python3.6/site-packages/async_upnp_client/__init__.py", line 176, in handle_notify
    service.notify_changed_state_variables(changes)
  File "/usr/local/lib/python3.6/site-packages/async_upnp_client/__init__.py", line 465, in notify_changed_state_variables
    self.on_event(self, changed_state_variables)
  File "/usr/local/lib/python3.6/site-packages/async_upnp_client/dlna.py", line 167, in _on_event
    dlna_handle_notify_last_change(state_variable)
  File "/usr/local/lib/python3.6/site-packages/async_upnp_client/dlna.py", line 63, in dlna_handle_notify_last_change
  File "/usr/local/lib/python3.6/site-packages/async_upnp_client/__init__.py", line 458, in notify_changed_state_variables
    state_var.upnp_value = value
  File "/usr/local/lib/python3.6/site-packages/async_upnp_client/__init__.py", line 771, in upnp_value
    self.value = self.coerce_python(upnp_value)
  File "/usr/local/lib/python3.6/site-packages/async_upnp_client/__init__.py", line 778, in coerce_python
    return data_type(upnp_value)
ValueError: invalid literal for int() with base 10: ''
2018-09-08 05:33:05 ERROR (MainThread) [aiohttp.server] Error handling request
  auth_providers:
   - type: homeassistant
   # uncomment this to enable backwards compatible API password support
   - type: legacy_api_password
http:
  api_password: *********
发表于 2018-9-8 13:33:34 | 显示全部楼层
我前一段也遇到了,没找到办法。找了个上次0.773的.storage文件复制进去才解决
发表于 2018-9-8 15:22:39 | 显示全部楼层
看来还是要备份好啊
发表于 2018-9-8 16:12:42 | 显示全部楼层
换一台手机或电脑试试,我上次也遇到这种情况,家中一台电脑就是进不了,转圈,其他电脑和手机都能登录,将电脑克隆还原都不行,最后将win7换成win10才好的。
发表于 2018-9-8 18:24:23 | 显示全部楼层
清理浏览器缓存就可以了
参与人数 1金钱 +5 收起 理由
jyz_0501 + 5 赠人玫瑰,手留余香!
发表于 2018-9-8 20:13:08 | 显示全部楼层
清理浏览器缓存就可以了
参与人数 1金钱 +5 收起 理由
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-9-8 23:25:56 | 显示全部楼层
zhenxiwen 发表于 2018-9-8 20:13
清理浏览器缓存就可以了
果然,之前可能清理不彻底,又全部清空一遍  就可以了
发表于 2018-9-9 20:04:21 | 显示全部楼层
我的安装好了,但是没法homekit
发表于 2018-9-9 20:51:02 | 显示全部楼层
清浏览器缓存其实不准确,是清cookie。
★Raspberry + Raspbian + Home Assistant v0.1
★树莓派 + Raspbian系统 + HomeAssistant
https://github.com/huangqian8/homeassistant
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-9-9 20:55:17 | 显示全部楼层
en  dui  是的
GMT+8, 2025-12-24 19:28 , Processed in 1.514437 second(s), 13 queries , MemCached On.
