查看: 5944|回复: 4
[求助] 给HA接入SSL证书之后日志里一直报错
发表于 2018-9-6 10:06:43 | 显示全部楼层 |阅读模式
不知道什么情况
活跃会员
发表于 2018-9-6 15:31:42 | 显示全部楼层
我的也总报错,不过不影响使用
Error doing job: SSL error errno:1 reason: HTTP_REQUEST
  File "uvloop/sslproto.pyx", line 504, in uvloop.loop.SSLProtocol.data_received
  File "uvloop/sslproto.pyx", line 204, in uvloop.loop._SSLPipe.feed_ssldata
  File "uvloop/sslproto.pyx", line 171, in uvloop.loop._SSLPipe.feed_ssldata
  File "/usr/local/lib/python3.6/ssl.py", line 689, in do_handshake
    self._sslobj.do_handshake()
ssl.SSLError: [SSL: HTTP_REQUEST] http request (_ssl.c:841)
发表于 2018-12-4 19:14:29 | 显示全部楼层
我也一样 你们解决了吗
Error doing job: SSL handshake failed
  File "uvloop/handles/stream.pyx", line 609, in uvloop.loop.UVStream._on_eof
ssl.SSLError: [SSL: UNSUPPORTED_PROTOCOL] unsupported protocol (_ssl.c:841)
发表于 2018-12-20 09:25:48 | 显示全部楼层
出现同样错误,查到有人建议解决办法:
The LetsEncrypt certs can cause the WiFi module to run out of memory when trying to do the SSL handshake. See: Using Konnected with Hass.io and SSL/TLS
To work around this, use the NGINX SSL proxy:
 https://www.home-assistant.io/addons/nginx_proxy/
You will need to REMOVE the ssl_certificate, ssl_key, and base_url config variables from the HTTP section of your configuration.yaml. Also REMOVE api_host from the Konnected section. Install the NGINX proxy add-on and set "domain" to your DuckDNS domain.
By default the NGINX proxy exposes port 443 securely to your DuckDNS domain, and proxies internally to port 8123. Restart Hass and Konnected should start communicating locally to Hass over HTTP port 8123, avoiding the certificate issue.
发表于 2019-11-27 10:14:27 | 显示全部楼层
E部落 发表于 2018-12-20 09:25
出现同样错误,查到有人建议解决办法:
The LetsEncrypt certs can cause the WiFi module to run out of m ...
太复杂了 看不懂啊
GMT+8, 2025-12-23 18:44 , Processed in 0.395519 second(s), 12 queries , MemCached On.
