查看: 12852|回复: 11
[求助] 433各种码的解决方案
wktm 手机认证
发表于 2018-9-5 20:31:57 | 显示全部楼层 |阅读模式
433各种码的解决方案
遇上个杜亚管机窗帘,耗费了几亿细胞,找了三种方案,都是不一样的结果,问题出在哪里呢
特意向step0766致敬,也向坛里热心人回复致敬
先是按照step0766 的  https://bbs.hassbian.com/thread-1314-1-1.html帖子进行实战,经过悉心指导,能显示码了,但是常规的胡桃433遥控器能显示一大堆数字:
Decimal: 11962632 (24Bit) Binary: 101101101000100100001000 Tri-State: not applicable PulseLength: 352 microseconds Protocol: 1
Raw data: 10927,1071,504,361,1181,1081,500,1065,496,371,1186,1075,498,1068,499,366,1191,1074,501,365,1189,371,1192,371,1194,1067,499,366,1199,362,1211,1052,505,363,1196,365,1194,367,1195,366,1207,1055,502,364,1192,368,1199,364,1225,
Raw data: 10935,1062,504,360,1202,1061,498,1068,501,365,1195,1067,503,1065,513,352,1202,1062,502,365,1196,364,1198,364,1203,1059,503,364,1192,368,1201,1062,505,362,1196,366,1198,363,1203,358,1204,1059,503,362,1204,358,1199,362,1230,
Raw data: 10931,1067,506,361,1199,1063,504,1064,502,364,1197,1064,505,1063,513,353,1199,1068,506,357,1208,354,1208,354,1200,1063,505,360,1202,359,1198,1066,510,358,1203,359,1204,358,1205,357,1204,1058,505,362,1200,360,1200,362,1226,
Raw data: 10935,1063,505,359,1198,1065,506,1061,506,361,1201,1062,511,1055,508,358,1204,1062,507,359,1198,364,1195,366,1199,1065,506,358,1203,359,1202,1062,515,353,1206,356,1199,363,1196,364,1206,1057,508,358,1199,363,1204,358,1222,
Raw data: 10933,1064,504,363,1198,1065,506,1064,516,348,1204,1059,505,1063,506,359,1212,1053,507,360,1200,362,1199,362,1205,1058,506,359,1207,355,1200,1063,517,351,1204,358,1202,360,1208,354,1201,1062,505,362,1198,361,1210,352,1223,
Raw data: 10934,1064,501,364,1208,1056,503,1065,505,360,1205,1059,505,1063,513,352,1204,1063,503,363,1199,362,1201,361,1200,1066,502,362,1208,353,1210,1054,511,359,1200,360,1203,359,1204,358,1200,1064,507,358,1200,362,1200,362,1227,
Decimal: 11962632 (24Bit) Binary: 101101101000100100001000 Tri-State: not applicable PulseLength: 353 microseconds Protocol: 1
Raw data: 10934,1064,504,362,1199,1065,505,1063,508,358,1200,1064,502,1065,507,358,1204,1062,508,358,1205,358,1203,358,1200,1064,507,359,1204,358,1201,1064,513,354,1198,364,1207,355,1200,361,1198,1066,505,362,1202,360,1197,364,1221,
接着又淘宝了五十大洋的串口转射频的模块
按同样的遥控键,读出的hex是
FD B6 89 08 53 DF
然后让博联RMPRO+ 读取的码有是:
b10084032e2e2e45172e2e0001b517452d17452e178a2e45172e44172e2e2e45172e2e0001b617442e17452e1744172e2e5c2e45172e2e2e5c2e2e2e000187177317452e1744182e2e444644172e2e2e45172e2e2e000188164644452e1745175c8a45172e2e2e44182e2e2e000187177317442f5b172e2f44172e45172e2e2e45452e2e0001881744458a45172e2e45172e45172e2e2e45452e2e000188174545448a452e45178a2e2e2e45175c2e0001885c2e17731744172f2e5b73172e2f2e8a2e2e000187178a452e5c172e73172e45172e2e2e45450001e4178a8a45172e2e45162f44172f2e2e45732e00019f45000114172e2e44172e5d5c2e45172e5c0001e48a2e1745172e2e5c2e45172e2e2e8b2e2d00019f462d5c2e175ca1172f45172e2e2e451700022a44000114172e2e5c2e8b2ee62e0001e5ce8b2e45172e8aa2172e2e0001b65c2e17458a172e2e45d02e2e5c5c2f00018817cf450001428b2e8a2e2e0001b7000114732e2e5d2e5c2e0004812e5c2e8ba1452f000257468a452e0001152eb95c0001891646454545b95c00015a00028600012c2eb98a2e2e0003e1172e2e46000171178b0002135dfd4517e774170003f8451873172e2f2e5c0002145d2d180001435db85d000357fed0fe0002b6e72e2ee85c2f450002438ae75c8c45fe000215a10001a0741700042845b9fe0003410001cf00012c7400029f8a00015b5d0004840001fd5c000271455c0001440003138b737300022b00022c00039d00027046000189fe74175c00036f000143e80003cbe75d8b00022b0001150001168a5db90001fd0001158b8b0001158b0002432e1700053e00011400011600049b00015b0001a000025ad045b946175c00011600022b000214a2450003b4e70001a10002142e00012d2e8ab98b000215a18b8a8b000172000271d00001158b0001160001e617fe73a2178be75d00025a8a0001448b0003f98b2e46178a2f2e2eb92f0001a046cfff455d8b8a2f2e0002141774732e2f4517b92e2f5c2e2f2e000189188a462d175da2172e46172e2f2e45172f2e2e00018a5c2e18e62f2e45172e5d2e2e2fb92e00018a17d02e5c462e45172e46172f2e73172f2e2e0001a1462e17458a182e2e5d73182d2f2e45182e2e2f00018918452e5c8a7446172e46172e2e2e46172e2f0001b7187317d0172e2f45172e46172e2e2f8a2f2e00018a17462d18452e1745172e2f45172f45172e2f2e45172f2e2e00018a18452e170005dc00000000
怎么转换都得不到统一的码
另外 杜亚的25管机窗帘遥控 ,虽然是433的但是死活都没有反应,只是nudemcu 的小蓝灯变化一下,窗扣一个数据也显示不了
这个博联读出的码怎么转换成串口的hex ?  感觉用串口发指令的机会多 ,homeassstans 已经成功安装,好累
发表于 2018-9-6 00:10:15 | 显示全部楼层
我也研究了很久,应该是不支持接收和发射那么长的信号
发表于 2018-9-6 08:14:55 | 显示全部楼层
博联的需要多读几次,比如,扫码时候多按一会,读码时候多按1s,总有一次会成短码的,我曾经读了10多次433,刚开始800多位,最后读到短码貌似20多位
wktm 手机认证
 楼主| 发表于 2018-9-6 09:20:07 | 显示全部楼层
tang5275 发表于 2018-9-6 08:14
博联的需要多读几次,比如,扫码时候多按一会,读码时候多按1s,总有一次会成短码的,我曾经读了10多次433 ...
按的杜亚的dc92 五通道遥控灯都不闪了,屏幕没有任何数码出现,是不是杜亚的25管机内置的射频接收有问题呢?遥控里的编码芯片居然给抹掉,很是奇怪,你的杜亚的内置的射频接收不是,还是常规的外置接收盒啊
发表于 2018-9-6 09:38:10 | 显示全部楼层
wktm 发表于 2018-9-6 09:20
按的杜亚的dc92 五通道遥控灯都不闪了,屏幕没有任何数码出现,是不是杜亚的25管机内置的射频接收有问题 ...
普通的433遥控器,我用易控学习的,学了几遍长度都不一样。
如果用智慧星学习开关的话,需要学好几遍才(我觉得智慧星是设定了码的长度)
wktm 手机认证
 楼主| 发表于 2018-9-6 09:49:02 | 显示全部楼层
如果用智慧星学习开关的话,需要学好几遍才( ...
杜亚的码估计是加密了吧,不然用了三种方法都没有解决,除了博联的易控能读出了,但是却发现太长,发送不出去,很是郁闷
发表于 2018-9-6 10:08:56 | 显示全部楼层
wktm 发表于 2018-9-6 09:49
杜亚的码估计是加密了吧,不然用了三种方法都没有解决,除了博联的易控能读出了,但是却发现太长,发送不 ...
不是加密吧,多学习几次,多新建几个按钮,依次学习,看哪个最短
你尝试扫码时候短按和长按
学习时候短按和长按
wktm 手机认证
 楼主| 发表于 2018-9-6 10:17:37 | 显示全部楼层
搞糊涂了,杜亚的码我用博联读出了过,但是里边的码太长,现在是在用是按照step0766 的  https://bbs.hassbian.com/thread-1314-1-1.html  的方法想读取出来,因为里边有直接显示的二进制码,直接转换成16进制就能用,博联里的码太长,不知道怎么缩短转换成类似于 FD B6 89 08 53 DF这种 ,并且博联里读取的码好像没有二进制的,
wktm 手机认证
 楼主| 发表于 2018-9-6 16:16:50 | 显示全部楼层
还是不成功,现在从博联里读取的红外码 也转不成能用串口发送的码,用了很多工具,没有一个是成功的
zfnu
发表于 2020-3-29 11:34:02 | 显示全部楼层
你最后有没有搞定
一样的情况,普通433正常显示,杜亚的什么反应都没有
GMT+8, 2026-1-21 19:59 , Processed in 0.390377 second(s), 9 queries , MemCached On.
