查看: 10320|回复: 6
[技术探讨] Homebridge 地址冲突,求教,谢谢!
40 金钱 回复本帖可获得 5 金钱奖励! 每人限 1 次
发表于 2018-9-3 21:57:36 | 显示全部楼层 |阅读模式
目前使用HASS.IO 0.76.2
使用homebridge,用home
使用HA bridge,用叮咚
Homebridge设备能正常使用,但是日志里反复提示
Withdrawing address record for 172.30.32.1 on hassio.
Withdrawing address record for fe80::e677:b93f:c14e:e87b on wlan0.
Withdrawing address record for 192.168.31.193 on wlan0.
Host name conflict, retrying with null-300
Registering new address record for fe80::42:86ff:fe13:8fb9 on hassio.*.
Registering new address record for 172.30.32.1 on hassio.*.
Registering new address record for fe80::e677:b93f:c14e:e87b on wlan0.*.
Registering new address record for 192.168.31.193 on wlan0.*
是什么地方有错误呢?请指教
附homebridge的config
  "bridge": {
    "name": "Home Assistant",
    "username": "B8:27:EB:5C:ED:CD",
    "port": 51826,
    "pin": "888-88-888"
  "description": "Homebridge for Home Assistant",
  "accessories": [],
  "platforms": [
      "platform": "HomeAssistant",
      "name": "HomeAssistant",
      "host": "http://hassio/homeassistant",
      "password": "5b3ef6d90c114f00b75e128f4c2b4cb5",
      "default_visibility": "visible",
      "supported_types": [
        "automation",
        "binary_sensor",
        "climate",
        "cover",
        "device_tracker",
        "fan",
        "input_boolean",
        "light",
        "lock",
        "media_player",
        "remote",
        "scene",
        "script",
        "sensor",
        "switch",
        "vacuum"
      "logging": true,
      "verify_ssl": true
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-9-4 21:25:43 | 显示全部楼层
回帖奖励 +5 金钱
我的以前也这样 一直重试到3000多还不停  后来好了,好像是hostname的问题
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-9-21 21:08:58 | 显示全部楼层
没人解决么?
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-9-24 16:27:02 | 显示全部楼层
Host name conflict, retrying with hassio-241
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-9-24 16:53:36 | 显示全部楼层
经测试发现就是 HB插件中配置
  "log_level": "warning",
  "avahi_interfaces": "",
  "avahi_hostname": "",
  "avahi_domainname": "local",
  "enable_ipv6": false,
  "insecure": false,
  "packages": [
    "ffmpeg"
  "init_commands": [],
  "plugins": [
    "homebridge-camera-ffmpeg plugin",
    "homebridge-broadlink-s1c"
的  "avahi_hostname": "", 问题,改成hassio 就提示hassio 重复  改成raspberrypi 就提示raspberrypi 重复
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-9-25 13:40:01 | 显示全部楼层
找到问题所在了,你是不是eth0和wlan都连着呢? 有线或者无线选一种联网就可以了,都连接的话,HB在两个ip上都检测到,就会造成冲突 提示。断开一个就好了
hbrl 手机认证
发表于 2025-2-24 22:53:28 | 显示全部楼层
回帖奖励 +5 金钱
请教一下版主:s905l3a盒子冬瓜haos上面怎样安装Homebridge?目的是需要安装Homebridge的apple TV enhanced插件。
GMT+8, 2026-1-15 11:36 , Processed in 1.562200 second(s), 9 queries , MemCached On.
