楼主: charley
[插件集成] AirPlayer TTS 你值得拥有
发表于 2019-6-3 12:59:37 | 显示全部楼层
Jones 发表于 2018-9-3 20:50
虫神太低调,地址都不放,我做个好事?
下面这个放到custom_components目录下
請教各英雄, 文件放置位置已跟要求, 但仍然報錯, 求各英雄幫忙。。。謝謝!!
2019-06-03 12:38:29 ERROR (MainThread) [homeassistant.loader] Error loading custom_components.media_player.airplayer. Make sure all dependencies are installed
  File "/usr/src/app/homeassistant/loader.py", line 166, in _load_file
    module = importlib.import_module(path)
  File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
  File "<frozen importlib._bootstrap>", line 983, in _find_and_load
  File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 728, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/config/custom_components/media_player/airplayer.py", line 10, in <module>
    from homeassistant.components.media_player import (
ImportError: cannot import name 'SUPPORT_TURN_OFF' from 'homeassistant.components.media_player' (/usr/src/app/homeassistant/components/media_player/__init__.py)
2019-06-03 12:38:29 ERROR (MainThread) [homeassistant.loader] Unable to find platform airplayer.
2019-06-03 12:38:29 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform airplayer.media_player: Platform not found.
jajn
发表于 2019-6-3 14:09:08 | 显示全部楼层
虫神,意思是TTS可以支持HomePod了?
发表于 2019-6-3 18:09:11 | 显示全部楼层
E部落 发表于 2018-11-23 11:46
load_platform(hass, "media_player", MEDIA_PLAYER_DOMAIN, device)
改成
load_platform(hass, "media ...
0.93.2还是不行,报错“Unable to prepare setup for platform airplayer: Integration not found”
slwl 手机认证
发表于 2019-7-24 19:19:13 | 显示全部楼层
安装成功了。但是,怎么用呢。。。。
发表于 2019-8-27 18:35:12 | 显示全部楼层
学习学习
发表于 2020-4-8 14:55:53 | 显示全部楼层
马克一下 先
发表于 2020-7-7 19:53:29 | 显示全部楼层
家里有个支持airplay的设备,试试看
发表于 2021-1-11 00:17:24 | 显示全部楼层
跪求大神复出,更新插件!!
GMT+8, 2025-12-29 16:12 , Processed in 0.627416 second(s), 14 queries , MemCached On.
