V0.4.5 多DC1支持 斐讯DC1离线控制
发表于 2018-10-25 00:29:52 | 显示全部楼层
感谢楼主分享
发表于 2018-10-25 11:04:17 | 显示全部楼层
感谢分享~~~~
发表于 2018-10-25 17:46:01 | 显示全部楼层
不知道好不好用啊。。。。
发表于 2018-10-25 18:29:39 | 显示全部楼层
看看咯,大哥厉害厉害。。。。。。。。。。
发表于 2018-10-25 20:02:58 | 显示全部楼层
小白啊  win7环境下 提示
2018-10-25 19:56:05 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=36 from 2018-10-25 11:50:53.397162)
2018-10-25 19:56:05 WARNING (MainThread) [homeassistant.loader] You are using a custom component for switch.phicomm_dc1 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-10-25 19:56:05 WARNING (SyncWorker_3) [custom_components.switch.phicomm_dc1] PhicommDC1Switch server started on port 8000
2018-10-25 19:56:09 WARNING (SyncWorker_5) [custom_components.switch.phicomm_dc1] PhicommDC1Switch going to accept new connection
2018-10-25 19:56:09 WARNING (SyncWorker_5) [custom_components.switch.phicomm_dc1] PhicommDC1Switch Client (192.168.2.237, 13785) connected
2018-10-25 19:56:09 WARNING (SyncWorker_5) [custom_components.switch.phicomm_dc1] PhicommDC1Switch Force send a heartbeat:b'{"uuid":"T1540468569002","params":{},"auth":"","action":"datapoint"}\n'
发表于 2018-10-25 21:45:39 | 显示全部楼层
现学习一下
发表于 2018-10-25 22:13:31 | 显示全部楼层
真心需要。。。。。。。。谢谢
发表于 2018-10-25 22:32:25 | 显示全部楼层
收藏。。。。。。。
发表于 2018-10-25 23:13:22 | 显示全部楼层
看看,学习一下。
发表于 2018-10-26 10:12:57 | 显示全部楼层
看看好操作不
GMT+8, 2026-1-16 03:01 , Processed in 0.616088 second(s), 11 queries , MemCached On.
