查看: 15158|回复: 6
[求助] hiomebridge已经起来但是HomeKit中搜不到配件?
发表于 2017-7-5 09:25:12 | 显示全部楼层 |阅读模式
昨天下班关闭前一切正常,今天上班开起来,发现homekit里面的配件提示正在更新,连不上,HA web页面操作配件正常,然后ssh进树莓派查看homebridge状态sudo systemctl status homebridge -l 也是提示active正常啊:
pi@raspberrypi:~ $ sudo systemctl status homebridge -l
● homebridge.service - Node.js HomeKit Server
   Loaded: loaded (/etc/systemd/system/homebridge.service; enabled)
   Active: active (running) since Wed 2017-07-05 01:12:49 UTC; 7min ago
Main PID: 660 (homebridge)
   CGroup: /system.slice/homebridge.service
           └─660 homebridge
Jul 05 01:15:20 raspberrypi homebridge[660]: [7/5/2017, 1:15:20 AM] [HomeAssistant] Received event: ping
Jul 05 01:15:30 raspberrypi homebridge[660]: [7/5/2017, 1:15:30 AM] [HomeAssistant] Received event: {"data": {"old_state": {"last_updated": "2017-07-05T01:14:30.314592+00:00", "entity_id": "sun.sun", "attributes": {"next_dusk": "2017-07-05T11:32:25+00:00", "next_noon": "2017-07-05T04:03:54+00:00", "next_setting": "2017-0
但是HK里面就是搜不到,删除家庭重新添加、重启HA HB也还是搜不到,什么原因?
发表于 2017-7-5 11:49:04 | 显示全部楼层
看下homeassistant的日志里是什么内容?有没有报异常
 楼主| 发表于 2017-7-5 12:23:57 | 显示全部楼层
日志没有报错
发表于 2017-8-13 02:32:19 | 显示全部楼层
这个问题解决了吗?
发表于 2017-11-5 09:16:15 | 显示全部楼层
我也最近莫名其妙碰到这个问题
有时候正常,有时候删掉以后再要添加上却怎么都不行了
发表于 2017-11-29 00:21:33 | 显示全部楼层
有人解决了吗?
发表于 2017-11-29 00:31:46 | 显示全部楼层
我也是 这问题困扰最多了
GMT+8, 2025-12-25 13:55 , Processed in 0.380826 second(s), 12 queries , MemCached On.
