查看: 8958|回复: 6
sonoff 刷 DHT的温湿度传感器原生homekit的固件 失败记录
wktm 手机认证
发表于 2018-8-23 14:52:07 | 显示全部楼层 |阅读模式
泡论坛许久,看了很多帖子,收获很多,一股脑的吧树莓派B+等各种玩意收齐,开始了实战研究。
参考了long 大侠 https://bbs.hassbian.com/thread-4543-1-1.html
        czde  大侠  [url]https://bbs.hassbian.com/thread-4482-1-1.html[/url]
yiyiwawa   大侠 https://bbs.hassbian.com/forum.p ... mp;highlight=sonoff等诸神的贡献贴
前期也安装了win64的python  怕 ESPFlashDownloadTool_v3.6.4清理不干净内存,就用命令行的形式清理一遍
C:\Windows\system32>esptool.py --port COM3 erase_flash
esptool.py v2.5.0
Serial port COM3
Connecting........__
  File "c:\users\a\appdata\local\programs\python\python37\lib\site-packages\espt
ool.py", line 316, in command
    p = self.read()
ool.py", line 261, in read
    return next(self._slip_reader)
ool.py", line 1796, in slip_reader
    raise FatalError("Timed out waiting for packet %s" % waiting_for)
esptool.FatalError: Timed out waiting for packet header
  File "C:\Users\A\AppData\Local\Programs\Python\Python37\Scripts\esptool.py-scr
ipt.py", line 11, in <module>
    load_entry_point('esptool==2.5.0', 'console_scripts', 'esptool.py')()
ool.py", line 2842, in _main
    main()
ool.py", line 2543, in main
    esp = ESPLoader.detect_chip(each_port, initial_baud, args.before, args.trace
ool.py", line 245, in detect_chip
    detect_port.connect(connect_mode)
ool.py", line 447, in connect
    last_error = self._connect_attempt(mode=mode, esp32r0_delay=True)
ool.py", line 424, in _connect_attempt
    self.sync()
ool.py", line 363, in sync
    timeout=SYNC_TIMEOUT)
ool.py", line 327, in command
    self._port.timeout = saved_timeout
  File "c:\users\a\appdata\local\programs\python\python37\lib\site-packages\seri
al\serialutil.py", line 368, in timeout
    self._reconfigure_port()
al\serialwin32.py", line 222, in _reconfigure_port
    'Original message: {!r}'.format(ctypes.WinError()))
serial.serialutil.SerialException: Cannot configure port, something went wrong.
Original message: PermissionError(13, '拒绝访问。', None, 5)
然后又打开ESPFlashDownloadTool_v3.6.4刷czde 的贡献的bin ,
一切都看着很正常,但是居然在wifi 里找不到homekit 开头信号,按压开关也无果。
很是奇怪
发表于 2018-8-28 10:06:33 | 显示全部楼层
一切都看着很正常,但是居然在wifi 里找不到homekit 开头信号,按压开关也无果。 me too
wktm 手机认证
 楼主| 发表于 2018-8-28 20:57:33 | 显示全部楼层
我的也是刷了十几遍才成功一个,指头都按的疼
发表于 2018-9-6 10:40:23 | 显示全部楼层
楼主你用 esptool.py Erase 的时候 最后那个是不是报错  端口无法打开?
wktm 手机认证
 楼主| 发表于 2018-9-6 11:41:19 | 显示全部楼层
还没有用过你说的软件,回头试试,现在正在解决杜亚的射频窗帘遥控问题,头晕头大头痛,用了三种方法都得不到想要的码,目前只有博联能读取出来,但是转换成串口码一直报错,用 step0766 的  https://bbs.hassbian.com/thread-1314-1-1.html只能读取继电器的射频遥控码,杜亚的一点都没反应
发表于 2020-6-5 13:25:12 | 显示全部楼层
兄弟,我也是刷成功了但是搜不到wifi,你最后咋解决的啊?
wktm 手机认证
 楼主| 发表于 2020-6-5 22:00:22 | 显示全部楼层
重新刷
GMT+8, 2025-12-30 16:50 , Processed in 1.302888 second(s), 12 queries , MemCached On.
