查看: 12481|回复: 10
[基础教程] 新人求助,Platform not found: climate.xiaomi_miio
发表于 2018-8-21 14:38:22 | 显示全部楼层 |阅读模式
请教各位大神,不论我装hassio或者hassbian,总是会出现Platform not found: climate.xiaomi_miio,我已经把xiaomi_miio拷贝到/custom_components/climate/xiaomi_miio.py。是不是不能直接拷贝?
2018-08-21 05:25:00 WARNING (MainThread) [homeassistant.components.http] You have been advised to set http.api_password.
2018-08-21 05:25:04 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=2 from 2018-08-20 20:24:36.857435)
2018-08-21 05:25:04 ERROR (MainThread) [homeassistant.loader] Unable to find component climate.xiaomi_miio
2018-08-21 06:03:04 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
2018-08-21 06:11:03 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
    result = coro.send(None)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 311, in _async_add_entity
    'Invalid entity id: {}'.format(entity.entity_id))
homeassistant.exceptions.HomeAssistantError: Invalid entity id: fan.
2018-08-21 06:11:12 ERROR (Thread-12) [homeassistant.components.media_player.xiaomi_tv] Could not find Xiaomi TV with specified IP: 192.168.31.139
2018-08-21 06:11:31 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-08-21 06:11:36 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-08-21 06:12:57 ERROR (Thread-6) [homeassistant.loader] Unable to find component climate.xiaomi_miio
2018-08-21 06:15:18 ERROR (Thread-8) [homeassistant.loader] Unable to find component climate.xiaomi_miio
2018-08-21 06:15:20 ERROR (Thread-19) [homeassistant.loader] Unable to find component climate.xiaomi_miio
2018-08-21 06:17:07 ERROR (Thread-11) [homeassistant.loader] Unable to find component climate.xiaomi_miio
2018-08-21 06:17:07 ERROR (MainThread) [homeassistant.components] Platform not found: climate.xiaomi_miio
2018-08-21 06:25:06 ERROR (MainThread) [homeassistant.components.updater] Got unexpected response: None
 楼主| 发表于 2018-8-21 15:10:08 | 显示全部楼层
顶上去,大神救我!
发表于 2018-8-21 22:05:00 | 显示全部楼层
拷贝文件夹和配置文件截图贴上来看看
发表于 2018-9-22 22:24:29 | 显示全部楼层
楼主问题解决了吗? 求分享, 找不到平台!:
发表于 2018-10-13 17:33:50 | 显示全部楼层
帮顶,我也不会。。。
发表于 2019-2-26 21:31:20 | 显示全部楼层
一样一样,现在还是连不上空调伴侣
iwha
发表于 2019-2-26 21:33:21 | 显示全部楼层
0.88?
新版本改路径了
放在 config folder/custom_components/xiaomi_iio/climate.py
发表于 2019-4-13 23:23:00 | 显示全部楼层
iwha 发表于 2019-2-26 21:33
0.88?
新版本改路径了
这个目录要自己建立吗?建立在哪里
发表于 2019-7-7 22:55:20 | 显示全部楼层
一样 求解啊
发表于 2019-7-8 19:19:25 来自手机 | 显示全部楼层
15894978264 发表于 2019-7-7 22:55
一样 求解啊
论坛有个帖子,0.92版本之后自定义组件的存放位置变了,需要自己改一下。
GMT+8, 2026-1-1 13:52 , Processed in 0.086873 second(s), 12 queries , MemCached On.
