查看: 7069|回复: 4
[求助] 0.76.1版 switch 出错,请教是为什么?
发表于 2018-8-20 21:43:23 | 显示全部楼层 |阅读模式
0.76.1版 switch 出错,以前没有这个错误提示,请教大神
The following components and platforms could not be set up:
Please check your config.
发表于 2018-8-20 21:53:50 | 显示全部楼层
根据你提供的内容答复如下
Keeps track which switches are in your environment, their state and allows you to control them.
Maintains a state per switch and a combined state all_switches.
Registers services switch.turn_on, switch.turn_off, and switch.toggle to control switches.
USE THE SERVICES
In the frontend open the sidebar. At the bottom, under Developer Tools, click Services. From the Service dropdown menu choose switch.turn_on or switch.turn_off from the list of available services. In the Entity dropdown menu choose or enter the entity ID you want to work with. This will enter something like the sample below into the Service Data field. Now hit CALL SERVICE.
{"entity_id":"livingroom_pin2"}
Service data attribute        Optional        Description
entity_id        yes        Only act on a specific switch. Otherwise it targets all switches.
 楼主| 发表于 2018-8-20 22:12:10 | 显示全部楼层
honry 发表于 2018-8-20 21:53
根据你提供的内容答复如下
Keeps track which switches are in your environment, their state and allows ...
谢谢!我这样写有问题吗?
switch:
      my_smartfan_buzzer:
        value_template: "{{ is_state_attr('fan.my_smartfan', 'buzzer', true) }}"
        turn_on:
          service: fan.xiaomi_miio_set_buzzer_on
          "entity_id": "fan.my_smartfan"
        turn_off:
          service: fan.xiaomi_miio_set_buzzer_off
发表于 2018-8-21 13:20:18 | 显示全部楼层
配置文件有問題~
寫法不是這樣
參考官網的
switch:  - platform: template    switches:      skylight:        value_template: "{{ is_state('sensor.skylight', 'on') }}"        turn_on:          service: switch.turn_on          data:            entity_id: switch.skylight_open        turn_off:          service: switch.turn_on          data:            entity_id: switch.skylight_close
发表于 2018-8-21 13:21:27 | 显示全部楼层
switch:
    switches:
      skylight:
        turn_on:
          data:
        turn_off:
          data:
GMT+8, 2025-12-26 14:16 , Processed in 0.076635 second(s), 5 queries , MemCached On.
