查看: 8151|回复: 1
[求助] 安装homebirdge出错,希望论坛里的大佬指点下,万分感谢
发表于 2018-8-20 00:42:10 | 显示全部楼层 |阅读模式
安装homebirdge之前的所有步骤都没有出错,到了这一步,就出错了,我进过提示中的文件夹,也翻译了看过,但是不太明白bignum.o和bignum.node这两个文件怎么处理,希望大佬能指点一下思路,小弟万分感谢.
pi@hassbian:/usr/lib/node_modules/homebridge $ sudo npm install --unsafe-perm bignum
> [email protected] install /usr/lib/node_modules/homebridge/node_modules/bignum
> prebuild-install || node-gyp rebuild
prebuild-install WARN install No prebuilt binaries found (target=8.11.4 runtime=node arch=arm platform=linux)
make: Entering directory '/usr/lib/node_modules/homebridge/node_modules/bignum/build'
  CXX(target) Release/obj.target/bignum/bignum.o
  SOLINK_MODULE(target) Release/obj.target/bignum.node
  COPY Release/bignum.node
make: Leaving directory '/usr/lib/node_modules/homebridge/node_modules/bignum/build'
+ [email protected]
updated 1 package in 26.813s
 楼主| 发表于 2018-8-22 14:34:21 | 显示全部楼层
已解决:缺少安装homebridge的依赖,详情参考我的基础教程贴
GMT+8, 2025-12-24 21:35 , Processed in 0.606826 second(s), 8 queries , MemCached On.
