查看: 11831|回复: 1
[基础教程] 求助,配置conversation,如何添加多个设备的语音控制
发表于 2018-8-17 20:05:13 | 显示全部楼层 |阅读模式
在论坛朋友热心的帮助下,成功的配置SSL,折腾conversation,尝试多次添加多个设备始终设备,求正确格式。谢谢!单个设备能够正常使用语音控制:
conversation:
  intents:
    OpenLight:
      - 打开{item}灯
      - 把{item}灯打开
    CloseLight:
      - 关上{item}灯
      - 关闭{item}灯
      - 关了{item}灯
intent_script:
  OpenLight:
    speech:
      text: 已打开{{ item }}灯
    action:
      service: light.turn_on
      data_template:
        entity_id: >
          {% if item=="餐厅" %}
            light.001
          {% endif %}
  CloseLight:
    speech:
      text: 已关闭{{ item }}灯
    action:
      service: light.turn_off
      data_template:
        entity_id: >
          {% if item=="餐厅" %}
            light.001
          {% endif %}
多个设备就不正常了:
conversation:
  intents:
    OpenLight:
      - 打开{item}灯
      - 把{item}灯打开
    CloseLight:
      - 关上{item}灯
      - 关闭{item}灯
      - 关了{item}灯
intent_script:
  OpenLight:
    speech:
    action:
      data_template:
        entity_id: >
          {% if item=="餐厅" %}
            light.001
          {% endif %}
  OpenLight:
    speech:
    action:
      data_template:
        entity_id: >
          {% if item=="客厅" %}
            light.002
          {% endif %}
  CloseLight:
    speech:
    action:
      data_template:
        entity_id: >
          {% if item=="餐厅" %}
            light.001
          {% endif %}
  CloseLight:
    speech:
    action:
      data_template:
        entity_id: >
          {% if item=="客厅" %}
            light.002
          {% endif %}
求正确配置格式,谢谢大神
发表于 2018-8-18 08:46:38 | 显示全部楼层
chrome的语音识别要翻越gfw吗
嗯哼,有论坛签名了
GMT+8, 2026-1-3 03:00 , Processed in 0.099928 second(s), 12 queries , MemCached On.
