楼主: cnk700i
[插件集成] 通用型定时器【任务列表+周期任务+可服务调用】
发表于 2020-5-21 05:49:45 | 显示全部楼层
學習下通用型定时器
发表于 2020-6-10 11:31:28 | 显示全部楼层
大佬新版本好像不支持了哦~~
发表于 2020-8-3 13:58:33 | 显示全部楼层
大佬,学习了你的定时器组件。0.112.1版本不支持了,报如下的问题。想去改改代码,折腾了两天,总是提示参数不对,请提点一二:
2020-07-18 01:21:38 ERROR (MainThread) [homeassistant.setup] Error  during setup of component common_timer
  File  "/home/homeassistant/.local/share/virtualenvs/homeassistant-blabs_3G/lib/python3.7/site-packages/homeassistant/setup.py", line 193, in  _async_setup_component
    result = await asyncio.wait_for(task, SLOW_SETUP_MAX_WAIT)
  File "/usr/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
    return fut.result()
  File  "/home/homeassistant/.homeassistant/custom_components/common_timer/__init__.py", line 232, in async_setup
    entity = InputSelect(object_id, conf)
TypeError: __init__() takes 2 positional arguments but 3 were given
发表于 2020-8-5 10:21:37 | 显示全部楼层
0.112.1版本下一点一点改,目前卡在这里,来回调试,已经找不出办法了。大佬们,帮忙看看呗:
2020-08-05 10:19:52 ERROR (MainThread) [homeassistant.setup] Error during setup of component common_timer
    return fut.result()
  File "/home/homeassistant/.homeassistant/custom_components/common_timer/__init__.py", line 338, in async_setup
    yield from hass.data['sensor']._platforms[PLATFORM_KEY].async_add_entities(entities)
KeyError: ('template', None, 'common_timer')
发表于 2020-9-3 03:09:04 | 显示全部楼层
https://ljr.im/articles/plugin-h ... r-upgraded-version/  更新于 2020-08-31為何設備類型欄是空的沒設備顯示呢.........查看log也沒報錯訊息........
发表于 2021-1-29 23:39:46 | 显示全部楼层
        膜拜大神!
发表于 2021-1-30 09:45:16 | 显示全部楼层
楼主厉害,这个必须支持
发表于 2021-3-6 17:20:56 | 显示全部楼层
看看能不能用得上
发表于 2021-3-7 11:46:58 | 显示全部楼层
看看老板看看老板看看老板看看老板
wjh 手机认证
发表于 2021-3-10 11:06:59 | 显示全部楼层
forked-daapd
GMT+8, 2026-1-16 06:17 , Processed in 1.627182 second(s), 17 queries , MemCached On.
