查看: 5920|回复: 4
貌似我又要悲剧了~付hassio的启动log,求解决……
发表于 2018-8-13 21:54:59 | 显示全部楼层 |阅读模式
2018-08-13 20:29:55 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=33 from 2018-08-10 10:41:30.113191)
2018-08-13 20:30:02 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2018-08-13 20:30:14 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
2018-08-13 20:30:15 WARNING (MainThread) [homeassistant.setup] Setup of homekit is taking over 10 seconds.
2018-08-13 20:30:25 ERROR (SyncWorker_15) [homeassistant.components.light.yeelight] Failed to connect to bulb 192.168.3.51, Light51: A socket error occurred when sending the command.
2018-08-13 20:30:31 WARNING (MainThread) [homeassistant.components.light] Setup of platform yeelight is taking over 10 seconds.
2018-08-13 20:30:32 ERROR (SyncWorker_16) [homeassistant.components.light.yeelight] Failed to connect to bulb 192.168.3.50, Light50: Bulb closed the connection.
2018-08-13 20:30:48 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-08-13 20:31:13 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-08-13 20:31:17 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-08-13 20:31:22 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-08-13 20:31:57 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-08-13 20:32:39 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-08-13 20:32:43 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-08-13 20:47:27 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal error on transport TCPTransport (error status in uv_stream_t.read callback)
TimeoutError: [Errno 110] Operation timed out
断电启动需要5~10分钟。卧槽……
发表于 2018-8-14 08:34:13 | 显示全部楼层
把 light.yeelight 的配置去掉看看。
流水无味
灌水之王
发表于 2018-8-14 15:57:06 | 显示全部楼层
我也一天到晚刷这个记录:
能用不清楚啥状况
Freddy.
最佳新人卓越贡献
发表于 2018-8-14 16:45:57 | 显示全部楼层
xieahui 发表于 2018-8-14 15:57
我也一天到晚刷这个记录:
2018-08-13 20:31:22 ERROR (MainThread) [homeassistant.core] Timer got out o ...
无解,不要紧的问题
 楼主| 发表于 2018-8-16 10:15:03 | 显示全部楼层
重点是太慢了~
GMT+8, 2026-1-31 23:11 , Processed in 0.680790 second(s), 6 queries , MemCached On.
