查看: 3520|回复: 5
[求助] 求助 小米网关V3 报错
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-8-13 20:29:58 | 显示全部楼层 |阅读模式
2018-08-13 15:11:09 ERROR (SyncWorker_3) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:13:44 ERROR (SyncWorker_0) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:13:44 ERROR (SyncWorker_0) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:14:15 ERROR (SyncWorker_0) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:14:15 ERROR (SyncWorker_0) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:14:46 ERROR (SyncWorker_8) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:14:46 ERROR (SyncWorker_8) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:15:17 ERROR (SyncWorker_3) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:15:17 ERROR (SyncWorker_3) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:15:48 ERROR (SyncWorker_16) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:15:48 ERROR (SyncWorker_16) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:16:19 ERROR (SyncWorker_3) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:16:19 ERROR (SyncWorker_3) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:16:50 ERROR (SyncWorker_10) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:16:50 ERROR (SyncWorker_10) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:17:52 ERROR (SyncWorker_7) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:17:52 ERROR (SyncWorker_7) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:18:54 ERROR (SyncWorker_11) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:18:54 ERROR (SyncWorker_11) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:19:56 ERROR (SyncWorker_17) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:19:56 ERROR (SyncWorker_17) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:20:27 ERROR (SyncWorker_15) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:20:27 ERROR (SyncWorker_15) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:20:58 ERROR (SyncWorker_6) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:20:58 ERROR (SyncWorker_6) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:21:29 ERROR (SyncWorker_11) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:21:29 ERROR (SyncWorker_11) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:22:00 ERROR (SyncWorker_15) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:22:00 ERROR (SyncWorker_15) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:22:31 ERROR (SyncWorker_9) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:22:31 ERROR (SyncWorker_9) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:23:33 ERROR (SyncWorker_17) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:23:33 ERROR (SyncWorker_17) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:24:04 ERROR (SyncWorker_2) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:24:04 ERROR (SyncWorker_2) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:24:35 ERROR (SyncWorker_15) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:24:35 ERROR (SyncWorker_15) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:26:39 ERROR (SyncWorker_9) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:26:39 ERROR (SyncWorker_9) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:27:10 ERROR (SyncWorker_2) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:27:10 ERROR (SyncWorker_2) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:28:12 ERROR (SyncWorker_17) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:28:12 ERROR (SyncWorker_17) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:29:14 ERROR (SyncWorker_18) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:29:14 ERROR (SyncWorker_18) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:29:45 ERROR (SyncWorker_13) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:29:45 ERROR (SyncWorker_13) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:29:55 ERROR (SyncWorker_8) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:29:55 ERROR (SyncWorker_8) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:30:16 ERROR (SyncWorker_11) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:30:16 ERROR (SyncWorker_11) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:31:49 ERROR (SyncWorker_9) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:31:49 ERROR (SyncWorker_9) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:32:20 ERROR (SyncWorker_15) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:32:20 ERROR (SyncWorker_15) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:33:22 ERROR (SyncWorker_16) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:33:22 ERROR (SyncWorker_16) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:33:53 ERROR (SyncWorker_4) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:33:53 ERROR (SyncWorker_4) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:34:24 ERROR (SyncWorker_18) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:34:24 ERROR (SyncWorker_18) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:34:55 ERROR (SyncWorker_0) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:34:55 ERROR (SyncWorker_0) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:35:57 ERROR (SyncWorker_16) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:35:57 ERROR (SyncWorker_16) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:36:28 ERROR (SyncWorker_8) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:36:28 ERROR (SyncWorker_8) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:36:59 ERROR (SyncWorker_4) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:36:59 ERROR (SyncWorker_4) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:37:30 ERROR (SyncWorker_10) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:37:30 ERROR (SyncWorker_10) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:38:00 ERROR (SyncWorker_15) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:38:00 ERROR (SyncWorker_15) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:38:31 ERROR (SyncWorker_18) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:38:31 ERROR (SyncWorker_18) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:39:02 ERROR (SyncWorker_19) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:39:02 ERROR (SyncWorker_19) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:39:33 ERROR (SyncWorker_17) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:39:33 ERROR (SyncWorker_17) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:40:35 ERROR (SyncWorker_0) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:40:35 ERROR (SyncWorker_0) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:41:06 ERROR (SyncWorker_15) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:41:06 ERROR (SyncWorker_15) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:41:37 ERROR (SyncWorker_7) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:41:37 ERROR (SyncWorker_7) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:42:08 ERROR (SyncWorker_8) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:42:08 ERROR (SyncWorker_8) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:42:39 ERROR (SyncWorker_0) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:42:39 ERROR (SyncWorker_0) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:43:10 ERROR (SyncWorker_10) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:43:10 ERROR (SyncWorker_10) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:43:41 ERROR (SyncWorker_4) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:43:41 ERROR (SyncWorker_4) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:45:14 ERROR (SyncWorker_0) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:45:14 ERROR (SyncWorker_0) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:45:45 ERROR (SyncWorker_3) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:45:45 ERROR (SyncWorker_3) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:46:47 ERROR (SyncWorker_9) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:46:47 ERROR (SyncWorker_9) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:47:18 ERROR (SyncWorker_12) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:47:18 ERROR (SyncWorker_12) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:47:29 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: 'None' has no attribute 'attributes'
2018-08-13 15:47:49 ERROR (SyncWorker_4) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:47:49 ERROR (SyncWorker_4) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:48:51 ERROR (SyncWorker_10) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:48:51 ERROR (SyncWorker_10) [xiaomi_gateway] No data in response from hub None
2018-08-13 15:49:22 ERROR (SyncWorker_10) [xiaomi_gateway] Cannot connect to Gateway
2018-08-13 15:49:22 ERROR (SyncWorker_10) [xiaomi_gateway] No data in response from hub None
这TM到底什么情况,什么都不写,就光连不上网关,明明可以获取到设备状态,为何要这么提示呢???
现在log里全是 小米网关的错误,一大片一大片的。。。
大家有没有这种情况??如何解决啊?
发表于 2018-8-14 09:07:46 | 显示全部楼层
def _send_cmd(self, cmd, rtn_cmd=None):
        try:
            self._socket.settimeout(10.0)
            _LOGGER.debug("_send_cmd >> %s", cmd.encode())
            self._socket.sendto(cmd.encode(), (self.ip_adress, self.port))
            data, _ = self._socket.recvfrom(1024)
        except socket.timeout:
            _LOGGER.error("Cannot connect to Gateway")
            return None
        if data is None:
            _LOGGER.error("No response from Gateway")
            return None
发表于 2018-8-14 09:10:09 | 显示全部楼层
错误来源于PyXiaomiGateway库,无法从小米网关获取data,网关无响应。
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-8-14 12:26:10 来自手机 | 显示全部楼层
hassio的话没办法了……
发表于 2018-8-14 13:14:03 | 显示全部楼层
jyz_0501 发表于 2018-8-14 12:26
hassio的话没办法了……
不是不是,库函数本身没问题,只是报错,错误在网关不回应,要么网关问题要么网络问题
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-8-14 21:13:02 | 显示全部楼层
Mirukuteii 发表于 2018-8-14 13:14
不是不是,库函数本身没问题,只是报错,错误在网关不回应,要么网关问题要么网络问题 ...
哦 那可能是网络问题,最近路由器管理界面 显示只有一个设备,而app上都是全的 但是全是离线状态,小米路由器也是没谁了
GMT+8, 2025-12-24 21:33 , Processed in 0.677338 second(s), 7 queries , MemCached On.
