查看: 3528|回复: 2
[已解决] 求助!急!
发表于 2017-7-3 19:46:51 | 显示全部楼层 |阅读模式
esptool v0.4.9 - (c) 2014 Ch. Klippel <[email protected]>
        setting board to ck
        setting baudrate from 115200 to 115200
        setting port from COM1 to COM3
        setting address from 0x00000000 to 0x00000000
        espcomm_upload_file
        espcomm_upload_mem
        setting serial port timeouts to 1000 ms
opening bootloader
resetting board
trying to connect
        flush start
        setting serial port timeouts to 1 ms
        flush complete
        espcomm_send_command: sending command header
        espcomm_send_command: sending command payload
        read 0, requested 1
trying to connect
        flush start
        flush complete
        espcomm_send_command: receiving 2 bytes of data
Uploading 478704 bytes from C:\Users\ADMINI~1\AppData\Local\Temp\build3e9f46729539ff980f3c116f1fc27339.tmp/sonoff.ino.bin to flash at 0x00000000
        erasing flash
        size: 074df0 address: 000000
        first_sector_index: 0
        total_sector_count: 117
        head_sector_count: 16
        adjusted_sector_count: 101
        erase_size: 065000
        setting serial port timeouts to 15000 ms
        writing flash
................................................................................ [ 17% ]
................................................................................ [ 34% ]
................................................................................ [ 51% ]
................................................................................ [ 68% ]
................................................................................ [ 85% ]
....................................................................             [ 100% ]
starting app without reboot
closing bootloader
        flush start
        flush complete
以上刷机信息,刷机以后通电没有反应,求大神指点!万分感谢!
发表于 2017-7-8 16:34:57 | 显示全部楼层
用什么软件刷的?不是arduino啊?
 楼主| 发表于 2017-7-8 20:23:24 | 显示全部楼层
是用的arduino刷的,不行。换ATOM刷了固件就正常了,谢谢老大!
GMT+8, 2025-8-21 00:00 , Processed in 0.832058 second(s), 9 queries , MemCached On.
