查看: 17229|回复: 13
[技术探讨] 【Lifesmart】设备接入HASS的尝试【已获取到设备列表】
活跃会员
发表于 2018-8-1 22:03:37 | 显示全部楼层 |阅读模式
家中有一些早年购入的Lifesmart的开关和传感器,虽然现在能够稳定的接入homekit,米家(小爱同学)和天猫精灵,不过一直纠结于无法接入hass,没法联动控制,正好今天无事,发现原来封闭的Lifesmart已经推出了开放平台,研究了开放文档发现米家和天猫精灵都应该是通过开放平台接入的
平台地址:http://www.ilifesmart.com/open文档地址:http://www.ilifesmart.com/open/docs/
由于实践过天猫精灵的接入过程,并结合论坛上的webhook文章,
自己摸索着搞定了设备的websocket通讯
不过不知能否通过websocket将设备接入hass,还请大神指教
登录认证界面js代码
<script>
        var timestamp = Math.round(new Date().getTime()/1000).toString();
        document.write(timestamp);
        var sign = hex_md5("appkey=xxxxxxx&auth_callback=https://xxxx/ls/lifesmart.php&time=" + timestamp + "&apptoken=xxxxxx");
        document.write("<br/>" + sign);
        var link = "https://api.ilifesmart.com/app/auth.authorize?id=957&appkey=xxxxxx&time="+ timestamp +"&auth_callback=https://xxxx/ls/lifesmart.php&sign="+ sign +"&lang=zh"
        document.write("<br/>" + link);
        var oBtn = document.getElementById('btn');
    oBtn.onclick = function(){
        window.location.href=link;
</script>
WebSocket 认证js代码
        <script type="text/javascript">
        ls();
        function ls() {
            $(document).ready(function () {
                    function GetQueryString(name){
                    var reg = new RegExp("(^|&)"+ name +"=([^&]*)(&|$)");
                    var r = window.location.search.substr(1).match(reg);
                    if(r!=null)return  unescape(r[2]); return null;
                var url_userid = GetQueryString("userid");
                var url_usertoken = GetQueryString("usertoken");
                            var timestamp = Math.round(new Date().getTime()/1000).toString();/*=时间戳=*/
                                var sign = hex_md5("method:WbAuth,time:"+ timestamp +",userid:"+ url_userid +",usertoken:"+ url_usertoken +",appkey:xxxx,apptoken:xxxx");/*=生成签名=*/
                ws = new WebSocket('wss://api.ilifesmart.com:8443/wsapp/'); /*=api地址=*/
                ws.addEventListener('open', function (event) {
                    ws.send('{"id": 957,"method": "WbAuth","system": {"ver": "1.0","lang": "ch","userid": "'+ url_userid +'","appkey": "xxxx","time": ' + timestamp + ', "sign":"' + sign + '"}}');
                                ws.onmessage = function (event) {
                document.write(event.data)
                                ws.onerror = function(event) {
                                document.write("WebSocketError!");
        </script>
获取设备列表
<?php
$id = (int)$_GET['id'];
$method = $_GET['method'];
$ver = $_GET['ver'];
$lang = $_GET['lang'];
$userid = $_GET['userid'];
$usertoken = $_GET['usertoken'];
$appkey = 'xxxxxxx';
$apptoken = 'xxxxxxx';
$time = (int)time();
$sign_str = "method:$method,time:$time,userid:$userid,usertoken:$usertoken,appkey:$appkey,apptoken:$apptoken";
$sign = md5($sign_str);
$data = array(
        'id' => $id,
        'method' => $method,
        'system' => array(
                'ver' => $ver,
                'lang' => $lang,
                'userid' => $userid,
                'appkey' => $appkey,
                'time' => $time,
                'sign' => $sign
header('Content-type:application/json');
$data1 = json_encode($data);
//echo $data1;
//echo "\n\n";
$opts = array(
        'http' => array(
                'method' => 'POST',
                'header' => 'Content-type:application/json',
                'content' => $data1
$url = "https://api.ilifesmart.com/app/api.EpGetAll";
$context = stream_context_create($opts);
$result = file_get_contents($url, false, $context);
echo $result;
// 写入文件
file_put_contents('alldevice.json', $result);
发表于 2018-8-1 22:25:50 | 显示全部楼层
如果开放了,必然是可以接入的。
活跃会员
 楼主| 发表于 2018-8-3 14:53:20 | 显示全部楼层
最新进展
已经生成了获取到全部的设备信息的json文件
参与人数 1金钱 +12 收起 理由
Mirukuteii + 12 在下对你的景仰犹如滔滔长江之水,连绵不绝.
发表于 2018-8-3 15:11:52 | 显示全部楼层
赞~~~~~ Lifesmart 的开关很好看啊,特别是那个流光开关。
活跃会员
 楼主| 发表于 2018-8-3 16:18:06 | 显示全部楼层
目前能通过REST将部分json数据传入hass
过程比较折腾,期盼能以插件的形式实现
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-8-3 16:33:53 来自手机 | 显示全部楼层
厉害了,这个需要加分制定,期待大大们的zuo p
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-8-3 16:34:56 来自手机 | 显示全部楼层
厉害,这个必须加分置顶
发表于 2018-8-10 13:14:01 | 显示全部楼层
这个要顶,希望能实现
发表于 2018-8-11 10:45:57 | 显示全部楼层
牛逼 ,可惜得外网获取 信息,没办法内网。
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-9-10 23:23:05 | 显示全部楼层
作品咋样了
GMT+8, 2026-1-15 09:20 , Processed in 1.737795 second(s), 10 queries , MemCached On.
