查看: 5620|回复: 3
[技术探讨] 只要升级0.74就无法启动hass
发表于 2018-7-29 18:37:59 | 显示全部楼层 |阅读模式
换了好几个版本镜像,使用到0.73.2一切都ok,只要升级到0.74就挂掉,下面是log错误日志,有没有大神给看下
2018-07-29 18:30:22 WARNING (MainThread) [homeassistant.components.http] You have been advised to set http.api_password.
2018-07-29 18:30:26 WARNING (MainThread) [homeassistant.loader] You are using a custom component for redpoint which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-07-29 18:30:26 WARNING (MainThread) [homeassistant.loader] You are using a custom component for tunnel2local which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-07-29 18:30:50 WARNING (MainThread) [homeassistant.setup] Setup of xiaomi_aqara is taking over 10 seconds.
2018-07-29 18:30:50 WARNING (MainThread) [homeassistant.components.switch] Setup of platform xiaomi_miio is taking over 10 seconds.
2018-07-29 18:30:55 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
    result = coro.send(None)
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/http/__init__.py", line 132, in start_server
    await server.start()
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/http/__init__.py", line 284, in start
    await self.app.startup()
  File "/usr/local/lib/python3.5/dist-packages/aiohttp/web_app.py", line 278, in startup
    await self.on_startup.send(self)
  File "/usr/local/lib/python3.5/dist-packages/aiohttp/signals.py", line 35, in send
    await receiver(*args, **kwargs)
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/http/cors.py", line 60, in cors_startup
    _allow_cors(route)
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/http/cors.py", line 44, in _allow_cors
    cors.add(route, config)
  File "/home/pi/.homeassistant/deps/lib/python3.5/site-packages/aiohttp_cors/cors_config.py", line 263, in add
    return self._cors_impl.add(routing_entity, config)
  File "/home/pi/.homeassistant/deps/lib/python3.5/site-packages/aiohttp_cors/cors_config.py", line 135, in add
    routing_entity, self._preflight_handler)
  File "/home/pi/.homeassistant/deps/lib/python3.5/site-packages/aiohttp_cors/urldispatcher_router_adapter.py", line 195, in add_preflight_handler
    self.add_preflight_handler(route.resource, handler)
  File "/home/pi/.homeassistant/deps/lib/python3.5/site-packages/aiohttp_cors/urldispatcher_router_adapter.py", line 163, in add_preflight_handler
    .format(resource, route_obj.handler))
ValueError: <PlainResource  /auth/token> already has OPTIONS handler <bound method _PreflightHandler._preflight_handler of <aiohttp_cors.cors_config._CorsConfigImpl object at 0x712cd030>>
活跃会员
发表于 2018-7-29 22:00:33 | 显示全部楼层
很可能是自定义组件得问题,删除自定义组件再试试
发表于 2018-7-30 10:08:35 | 显示全部楼层
你装的是 0.74.0还是0.74.2?
试试0.74.2 好像修了这个bug
流水无味
灌水之王
发表于 2018-7-30 16:16:20 | 显示全部楼层
试试0.74.2 好像修了这个bug
我升级到0.74.0 也是这些代码。
回头再升级0.74.2试试
GMT+8, 2025-11-10 15:04 , Processed in 1.037463 second(s), 9 queries , MemCached On.
