记一次完整的用siri+homekit+broadlinkrm pro 控制空调+调温开关
发表于 2017-7-9 23:48:05 | 显示全部楼层
谢谢分享
发表于 2017-7-10 21:18:04 | 显示全部楼层
执行sudo npm install -g --unsafe-perm homebridge hap-nodejs node-gyp这一句出现错识是怎么回事
npm ERR! Linux 4.4.13-v7+
npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "-g" "ember-cli"
npm ERR! node v7.10.0
npm ERR! npm  v4.2.0
npm ERR! path /tmp/npm-17694-b3dd9916
npm ERR! code ENOSPC
npm ERR! errno -28
npm ERR! syscall mkdir
npm ERR! nospc ENOSPC: no space left on device, mkdir '/tmp/npm-17694-b3dd9916'
npm ERR! nospc This is most likely not a problem with npm itself
npm ERR! nospc and is related to insufficient space on your system.
npm ERR! Please include the following file with any support request:
npm ERR!     /home/pi/.npm/_logs/2017-07-10T13_13_27_263Z-debug.log
pi@raspberrypi:~ $ sudo npm install -g --unsafe-perm homebridge hap-nodejs node-gyp
npm ERR! tar.unpack untar error /root/.npm/tar/2.2.1/package.tgz
npm ERR! tar.unpack untar error /root/.npm/mkdirp/0.5.1/package.tgz
npm ERR! tar.unpack untar error /root/.npm/ajv/4.11.8/package.tgz
npm ERR! tar.unpack untar error /root/.npm/nan/2.3.5/package.tgz
npm ERR! tar.unpack untar error /root/.npm/json-schema/0.2.3/package.tgz
npm ERR! tar.unpack untar error /root/.npm/ed25519/0.0.4/package.tgz
npm ERR! tar.unpack untar error /root/.npm/fstream/1.0.11/package.tgz
npm ERR! tar.unpack untar error /root/.npm/node-gyp/3.6.2/package.tgz
npm ERR! tar.unpack untar error /root/.npm/hawk/3.1.3/package.tgz
npm ERR! tar.unpack untar error /root/.npm/hap-nodejs/0.4.27/package.tgz
npm ERR! tar.unpack untar error /root/.npm/sshpk/1.13.1/package.tgz
npm ERR! tar.unpack untar error /root/.npm/nan/2.6.2/package.tgz
npm ERR! tar.unpack untar error /root/.npm/readable-stream/2.3.3/package.tgz
npm ERR! tar.unpack untar error /root/.npm/mdns/2.3.3/package.tgz
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: [email protected] (node_modules/node-gyp/node_modules/json-schema):
npm WARN nospc SKIPPING OPTIONAL DEPENDENCY: ENOSPC: no space left on device, mkdir '/usr/lib/node_modules/.staging/json-schema-9152276f/draft-00'
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: [email protected] (node_modules/node-gyp/node_modules/hawk):
npm WARN nospc SKIPPING OPTIONAL DEPENDENCY: ENOSPC: no space left on device, write
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: [email protected] (node_modules/node-gyp/node_modules/sshpk):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: [email protected] (node_modules/hap-nodejs/node_modules/nan):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: [email protected] (node_modules/node-gyp/node_modules/readable-stream):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: [email protected] (node_modules/hap-nodejs/node_modules/mdns):
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: [email protected] (node_modules/node-gyp/node_modules/har-schema):
npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "-g" "--unsafe-perm" "homebridge" "hap-nodejs" "node-gyp"
npm ERR! npm  v4.2.0
npm ERR! errno -28
npm ERR! syscall write
npm ERR! nospc ENOSPC: no space left on device, write
npm ERR!     /root/.npm/_logs/2017-07-10T13_15_07_814Z-debug.log
吃了藤藤菜就是长得帅
 楼主| 发表于 2017-7-10 22:04:25 | 显示全部楼层
npm ERR ...
机器空间不足。
卓越贡献
发表于 2017-7-14 16:49:38 | 显示全部楼层
很全面!学习了!
发表于 2017-7-14 21:15:23 | 显示全部楼层
虽然早就根据教程安装好了,也来学习一下
发表于 2017-7-15 16:23:15 来自手机 | 显示全部楼层
不错的想法啊
发表于 2017-7-16 00:18:03 | 显示全部楼层
感谢楼主分享
发表于 2017-7-18 10:25:13 | 显示全部楼层
谢谢分享
发表于 2017-7-21 01:26:46 | 显示全部楼层
但愿用你的能把博联搞定
编码狂魔
发表于 2017-7-23 12:21:37 | 显示全部楼层
马一下,回头博联rm来了试试
GMT+8, 2025-12-29 12:23 , Processed in 0.489201 second(s), 11 queries , MemCached On.
