查看: 4525|回复: 0
[求助] Home Assistant 0.74.0 错误日志求助
发表于 2018-7-28 15:56:07 | 显示全部楼层 |阅读模式
1、Error doing job: SSL handshake failedTraceback (most recent call last):  File "uvloop/handles/stream.pyx", line 609, in uvloop.loop.UVStream._on_eof  File "uvloop/sslproto.pyx", line 171, in uvloop.loop._SSLPipe.feed_ssldata  File "/usr/local/lib/python3.6/ssl.py", line 689, in do_handshake    self._sslobj.do_handshake()ssl.SSLError: [SSL: HTTP_REQUEST] http request (_ssl.c:841)
2、Error doing job: SSL error errno:1 reason: HTTP_REQUESTTraceback (most recent call last):  File "uvloop/sslproto.pyx", line 504, in uvloop.loop.SSLProtocol.data_received  File "uvloop/sslproto.pyx", line 204, in uvloop.loop._SSLPipe.feed_ssldata  File "uvloop/sslproto.pyx", line 171, in uvloop.loop._SSLPipe.feed_ssldata  File "/usr/local/lib/python3.6/ssl.py", line 689, in do_handshake    self._sslobj.do_handshake()ssl.SSLError: [SSL: HTTP_REQUEST] http request (_ssl.c:841)
3、Error doing job: Task was destroyed but it is pending!
GMT+8, 2025-12-24 23:51 , Processed in 0.240076 second(s), 7 queries , MemCached On.
