查看: 6647|回复: 3
[求助] 群晖homebridge的配置文件修改后不能生效
发表于 2018-7-23 19:40:42 | 显示全部楼层 |阅读模式
装载路径照着论坛教程的帖子 /root/.homebridge,配置文件在 /docker/homebridge,在这个目录下修改了config.json
    "bridge": {
        "name": "Homebridge",
        "username": "XX:XX:XX:XX:XX:XX",
        "port": 51826,
        "pin": "123-45-678"
    "platforms": [{
        "platform": "HomeAssistant",
        "name": "HomeAssistant",
        "host": "http://127.0.0.1:8123",
        "password": "",
        "supported_types": ["binary_sensor", "climate", "cover", "fan", "garage_door", "device_tracker", "input_boolean", "light", "lock", "media_player", "rollershutter", "sensor", "scene", "switch"],
        "default_visibility": "visible",
        "verify_ssl": false
用的这个范本,然后修改了pin,之后重启HB,日志和终端还是输出的3145154的pin,可以在HK发现,但是房间下五设备,所以我现在只想确认我的配路径和方法是不是哪里出错了
发表于 2018-7-24 08:37:47 | 显示全部楼层
去终端或者日志文件查它读取的是哪里的配置文件
 楼主| 发表于 2018-7-24 15:17:10 | 显示全部楼层
我也看了,但是没找到路径,只有日志的路径
发表于 2018-7-24 18:15:16 | 显示全部楼层
运行日志里面,我用的是软路由搭建的,开机系统日志里面就有
GMT+8, 2025-12-24 23:52 , Processed in 0.567263 second(s), 5 queries , MemCached On.
