查看: 17063|回复: 14
【转运】小米床头灯貌似能经HB进HK了~
发表于 2017-7-1 10:15:44 | 显示全部楼层 |阅读模式
无意间翻仓库更新,突然就看到了~链接
About Yeelight bedside lamp (BLE device)
BLE device can only be supported by Raspberry Pi 3. If you want to make Yeelight bedside lamp work with other hardware running homebridge, please try to install a bluetooth dongle and make sure it's working properly. Following is the procedure for Pi 3 users:
  • sudo apt-get install libbluetooth-dev
  • sudo npm install -g noble
  • sudo apt-get install libcap2-bin
  • Run following command:
sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
  • update homebridge-yeelight to latest version and restart homebridge service.
  • When you connect your bedside lamp for 1st time, remember to press the Mode button after your see the breathing effect. This is to authorize your Pi to access bedside lamp's services.
发表于 2017-7-2 01:37:58 | 显示全部楼层
一直就可以,不过也只是在hb里
 楼主| 发表于 2017-7-2 10:23:20 | 显示全部楼层
xinqinew 发表于 2017-7-2 01:37
一直就可以,不过也只是在hb里
这样子啊……一直不知道
发表于 2017-7-7 21:37:24 | 显示全部楼层
谢谢分享
发表于 2017-7-9 23:47:35 | 显示全部楼层
谢谢分享
发表于 2017-7-20 16:49:13 | 显示全部楼层
接入HB没意义呀,什么时候能接入HA
发表于 2017-7-20 23:58:43 | 显示全部楼层
学习学习,谢谢分享
发表于 2017-7-25 23:56:24 | 显示全部楼层
怎么链接上的,我的一直没有反应啊
发表于 2017-7-29 03:36:06 | 显示全部楼层
楼主辛苦了,谢谢分享
发表于 2017-8-3 02:49:57 | 显示全部楼层
已成功连接
GMT+8, 2026-2-2 01:50 , Processed in 1.627663 second(s), 12 queries , MemCached On.
