查看: 8776|回复: 6
[求助] win10 下安装鸿雁排插 不成功
发表于 2018-7-21 00:20:46 | 显示全部楼层 |阅读模式
win10 下安装鸿雁排插 不成功
switch:  - platform: broadlink    host: IP_ADDRESS    mac: 'MAC_ADDRESS'    type: mp1    friendly_name: 'MP1'    slots:      # friendly name of slots - optional      # if not set, slot name will be switch's friendly_name + 'slot {slot_index}'. e.g 'MP1 slot 1'      slot_1: 'TV slot'      slot_2: 'Xbox slot'      slot_3: 'Fan slot'      slot_4: 'Speaker slot'IHC8340B
控件用的是C大的
https://bbs.hassbian.com/thread-584-1-1.html
网页没有报错......
wndh8.com
 楼主| 发表于 2018-7-21 00:29:19 | 显示全部楼层
2018-07-21 00:26:59 WARNING (MainThread) [homeassistant.components.http] You have been advised to set http.api_password.
2018-07-21 00:27:00 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=3 from 2018-07-20 15:53:24.530443)
2018-07-21 00:27:00 WARNING (MainThread) [homeassistant.loader] You are using a custom component for switch which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-07-21 00:27:00 ERROR (MainThread) [homeassistant.setup] Error during setup of component switch
  File "c:\python37\lib\site-packages\homeassistant\setup.py", line 146, in _async_setup_component
    component.setup, hass, processed_config)  # type: ignore
AttributeError: module 'custom_components.switch' has no attribute 'setup'
2018-07-21 00:27:04 ERROR (SyncWorker_5) [homeassistant.util.package] Unable to install package netdisco==1.5.0: Command "c:\python37\python.exe -u -c "import setuptools, tokenize;__file__='C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\pip-install-v0b2mh2v\\netifaces\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record C:\Users\ADMINI~1\AppData\Local\Temp\pip-record-e3zktc0r\install-record.txt --single-version-externally-managed --compile --user --prefix=" failed with error code 1 in C:\Users\ADMINI~1\AppData\Local\Temp\pip-install-v0b2mh2v\netifaces\
2018-07-21 00:27:04 ERROR (MainThread) [homeassistant.requirements] Not initializing discovery because could not install requirement netdisco==1.5.0
2018-07-21 00:27:04 ERROR (MainThread) [homeassistant.setup] Setup failed for discovery: Could not install all requirements.
2018-07-21 00:27:10 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
2018-07-21 00:27:20 ERROR (SyncWorker_0) [homeassistant.util.package] Unable to install package warrant==0.6.1: Command "c:\python37\python.exe -u -c "import setuptools, tokenize;__file__='C:\\Users\\ADMINI~1\\AppData\\Local\\Temp\\pip-install-t3r2vzap\\pycryptodome\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record C:\Users\ADMINI~1\AppData\Local\Temp\pip-record-agh3bj_z\install-record.txt --single-version-externally-managed --compile --user --prefix=" failed with error code 1 in C:\Users\ADMINI~1\AppData\Local\Temp\pip-install-t3r2vzap\pycryptodome\
2018-07-21 00:27:20 ERROR (MainThread) [homeassistant.requirements] Not initializing cloud because could not install requirement warrant==0.6.1
2018-07-21 00:27:20 ERROR (MainThread) [homeassistant.setup] Setup failed for cloud: Could not install all requirements.
wndh8.com
 楼主| 发表于 2018-7-21 00:42:45 | 显示全部楼层
我把C大的 插件删了  网页能打开
invalid config
discovery
cloud         (上面蓝色按钮)
switch.broadlink    黑色的字
wndh8.com
 楼主| 发表于 2018-7-21 20:18:23 | 显示全部楼层
我装了  buildtools   还是报错啊。。。。  14   的 111MB
net framework 4.7    3.5没装
wndh8.com
发表于 2018-7-21 23:08:05 | 显示全部楼层
这个页面搜 == 就知道什么没装了
 楼主| 发表于 2018-7-23 05:11:52 | 显示全部楼层
tang5275 发表于 2018-7-21 23:08
这个页面搜 == 就知道什么没装了
兄弟怎么搜  不懂啊  能具体吗 谢谢
wndh8.com
发表于 2018-7-23 15:04:09 | 显示全部楼层
lty365 发表于 2018-7-23 05:11
兄弟怎么搜  不懂啊  能具体吗 谢谢
报错信息啊,就是你贴出来的报错,搜==啊
GMT+8, 2025-12-24 23:51 , Processed in 0.060489 second(s), 8 queries , MemCached On.
