查看: 6825|回复: 0
[求助] windows 7 安裝失敗,不曉得我哪裡做錯。
发表于 2018-7-18 20:38:11 | 显示全部楼层 |阅读模式
[ 本帖最后由 alen72035 于 2018-7-18 20:51 编辑 ]\n\n詢問一下,我安装的是Windows7 环境下的Python 3.54。但是当我Hass –open-ui的时候,网页是有自动打开,但是都被拒绝而无法载入网页。然后我回去CMD哪里看都首先会有一行os error 然后接着一堆讯息出现。还请各位大大协助一下,谢谢。
这是HOMEassistant产生的错误报告:
a2018-07-11 23:04:02 WARNING (MainThread) [homeassistant.components.http] You have been advised to set http.api_password.
2018-07-11 23:04:06 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=8 from 2018-07-11 14:38:47.637711)
2018-07-11 23:04:14 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback _ProactorReadPipeTransport._loop_reading()
File “c:\users\administrator\appdata\local\programs\python\python35-32\lib\asyncio\events.py”, line 127, in _run
self._callback(*self._args)
File “c:\users\administrator\appdata\local\programs\python\python35-32\lib\asyncio\proactor_events.py”, line 189, in _loop_reading
data = fut.result() # deliver data later in “finally” clause
File “c:\users\administrator\appdata\local\programs\python\python35-32\lib\asyncio\futures.py”, line 288, in result
raise InvalidStateError(‘Result is not ready.’)
asyncio.futures.InvalidStateError: Result is not ready.
2018-07-11 23:04:15 ERROR (MainThread) [homeassistant.core] Error doing job: Accept failed on a socket
File “c:\users\administrator\appdata\local\programs\python\python35-32\lib\asyncio\proactor_events.py”, line 503, in loop
conn, addr = f.result()
File “c:\users\administrator\appdata\local\programs\python\python35-32\lib\asyncio\futures.py”, line 294, in result
raise self._exception
File “c:\users\administrator\appdata\local\programs\python\python35-32\lib\asyncio\windows_events.py”, line 697, in _poll
value = callback(transferred, key, ov)
File “c:\users\administrator\appdata\local\programs\python\python35-32\lib\asyncio\windows_events.py”, line 478, in finish_accept
return conn, conn.getpeername()
OSError: [WinError 10014] 系统检测到在一个调用中尝试使用指针参数时的无效指针地址。
2018-07-11 23:04:16 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “c:\users\administrator\appdata\local\programs\python\python35-32\lib\asyncio\tasks.py”, line 242, in _step
result = coro.throw(exc)
File “c:\users\administrator\appdata\local\programs\python\python35-32\lib\asyncio\windows_events.py”, line 484, in accept_coro
yield from future
File “c:\users\administrator\appdata\local\programs\python\python35-32\lib\asyncio\futures.py”, line 381, in __iter__
yield self # This tells Task to wait for completion.
File “c:\users\administrator\appdata\local\programs\python\python35-32\lib\asyncio\tasks.py”, line 310, in _wakeup
future.result()
2018-07-11 23:04:17 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-07-11 23:04:29 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback _ProactorReadPipeTransport._loop_reading()
File “c:\users\administrator\appdata\local\programs\python\python35-32\lib\asyncio\proactor_events.py”, line 187, in _loop_reading
self._closing)
AssertionError
2018-07-11 23:14:48 WARNING (Thread-6) [netdisco.ssdp] Error fetching description at 127.0.0.1
GMT+8, 2025-12-24 23:51 , Processed in 0.110036 second(s), 20 queries , MemCached On.
