查看: 6305|回复: 2
[基础教程] 树梅派安装的备份后还原怎么进不了container和ha了
发表于 2018-7-18 16:39:55 | 显示全部楼层 |阅读模式
树梅派坏了,换了一个,恢复以前的备份,结果就从:9000的container都进不去,8123的ha网址进不去。关键是container进不去,想删除ha重新装都没戏阿。日志错误2018-07-18 16:26:19 ERROR (SyncWorker_0) [homeassistant.util.yaml] YAML file /config/configuration.yaml contains duplicate key "scan_interval". Check lines 78 and 81.2018-07-18 16:26:19 ERROR (SyncWorker_0) [homeassistant.util.yaml] YAML file /config/configuration.yaml contains duplicate key "sensor". Check lines 59 and 73.
2018-07-18 16:26:19 ERROR (SyncWorker_0) [homeassistant.util.yaml] YAML file /config/configuration.yaml contains duplicate key "tts". Check lines 63 and 174.
2018-07-18 16:26:19 ERROR (SyncWorker_0) [homeassistant.util.yaml] YAML file /config/configuration.yaml contains duplicate key "cloud". Check lines 67 and 182.
2018-07-18 16:26:19 ERROR (SyncWorker_0) [homeassistant.util.yaml] YAML file /config/configuration.yaml contains duplicate key "group". Check lines 69 and 184.
2018-07-18 16:26:19 ERROR (SyncWorker_0) [homeassistant.util.yaml] YAML file /config/configuration.yaml contains duplicate key "automation". Check lines 70 and 185.
2018-07-18 16:26:19 ERROR (SyncWorker_0) [homeassistant.util.yaml] YAML file /config/configuration.yaml contains duplicate key "script". Check lines 71 and 186.
2018-07-18 16:26:39 ERROR (MainThread) [homeassistant.setup] Error during setup of component xiaomi_aqara
  File "/usr/lib/python3.6/site-packages/homeassistant/setup.py", line 146, in _async_setup_component
    component.setup, hass, processed_config)  # type: ignore
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/lib/python3.6/site-packages/homeassistant/components/xiaomi_aqara.py", line 127, in setup
    hass.add_job, gateways, interface)
  File "/usr/lib/python3.6/site-packages/xiaomi_gateway/__init__.py", line 35, in __init__
    self._socket.bind((interface, 0))
OSError: [Errno 99] Address not available
2018-07-18 16:26:42 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
2018-07-18 16:27:35 WARNING (MainThread) [homeassistant.components.switch] Setup of platform broadlink_mp1 is taking over 10 seconds.
2018-07-18 16:27:55 ERROR (SyncWorker_18) [custom_components.switch.broadlink_mp1] Failed to connect to device
2018-07-18 16:27:56 ERROR (SyncWorker_5) [asyncio] Future exception was never retrieved
future: <Future finished exception=NonUniqueNameException()>
  File "/usr/lib/python3.6/site-packages/pyhap/accessory_driver.py", line 237, in _do_start
    self.advertiser.register_service(self.mdns_service_info)
  File "/usr/lib/python3.6/site-packages/zeroconf.py", line 1780, in register_service
    self.check_service(info, allow_name_change)
  File "/usr/lib/python3.6/site-packages/zeroconf.py", line 1896, in check_service
    raise NonUniqueNameException
zeroconf.NonUniqueNameException
2018-07-18 16:28:12 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-07-18 16:28:34 ERROR (SyncWorker_15) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
活跃会员教程狂人
发表于 2018-7-18 18:47:21 | 显示全部楼层
最开始的那几条日志明显提示你,有重复的“tts”“cloud”“group”等等。你用winscp登陆进去改改也行啊!
所有过往,皆为序章。
 楼主| 发表于 2018-7-19 09:32:42 | 显示全部楼层
谢谢哥了,问题解决,我特么地树莓派地址改变了,蛋疼!
GMT+8, 2026-1-3 07:02 , Processed in 0.231120 second(s), 7 queries , MemCached On.
