查看: 6051|回复: 2
[求助] 添加小米网关出错,求解决办法。
发表于 2018-7-10 12:14:17 | 显示全部楼层 |阅读模式
系统 ubuntu 18.04, python3.6.5,homeassistant0.73.1
加载小米网关时候提示
2018-07-10 12:05:16 ERROR (SyncWorker_2) [homeassistant.util.package] Unable to install package PyXiaomiGateway==0.9.5: Command "/srv/homeassistant/homeassistant_venv/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-9zanfmyn/cffi/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-8l9l8qse/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/homeassistant_venv/include/site/python3.6/cffi" failed with error code 1 in /tmp/pip-install-9zanfmyn/cffi/
这是什么原因,怎么解决?
发表于 2018-7-29 12:47:55 | 显示全部楼层
我也一样,请问楼主解决了没有?
发表于 2018-7-29 15:49:55 | 显示全部楼层
安装这个试试  pip3 install PyXiaomiGateway==0.9.5 -i https://pypi.tuna.tsinghua.edu.cn/simple
GMT+8, 2025-12-16 15:39 , Processed in 1.019781 second(s), 8 queries , MemCached On.
