楼主:
斐讯体脂秤S7插件 for HomeAssistant
发表于 2018-11-19 09:20:42 | 显示全部楼层
看下怎么拯救我的破秤
发表于 2018-11-19 11:34:34 | 显示全部楼层
神奇,购买了之后变成了199,又不能下载了
发表于 2018-11-20 09:18:14 | 显示全部楼层
我这有问题啊,不能用啊
2018-11-20 09:01:40 INFO (MainThread) [homeassistant.components.http.view] Serving /auth/token to 172.30.32.2 (auth: False)
2018-11-20 09:01:40 INFO (MainThread) [homeassistant.components.http.view] Serving /api/ to 172.30.32.2 (auth: True)
2018-11-20 09:02:21 WARNING (MainThread) [homeassistant.components.sensor] Updating phicomm_balance sensor took longer than the scheduled update interval 0:03:20
2018-11-20 09:03:27 ERROR (SyncWorker_19) [custom_components.sensor.phicomm_balance] get token failed
2018-11-20 09:03:27 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 240, in async_update_ha_state
    device_attr = self.device_state_attributes
  File "/config/custom_components/sensor/phicomm_balance.py", line 97, in device_state_attributes
    'weight': self._detail['weight'],
KeyError: 'weight'
2018-11-20 09:05:42 INFO (SyncWorker_16) [custom_components.sensor.phicomm_balance] Updating the sensor...
2018-11-20 09:05:52 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.phicomm_balance is taking over 10 seconds
2018-11-20 09:06:40 INFO (MainThread) [homeassistant.components.http.view] Serving /api/ to 172.30.32.2 (auth: True)
2018-11-20 09:07:53 ERROR (SyncWorker_16) [custom_components.sensor.phicomm_balance] get token failed
2018-11-20 09:09:03 WARNING (MainThread) [homeassistant.components.sensor] Updating phicomm_balance sensor took longer than the scheduled update interval 0:03:20
2018-11-20 09:10:06 ERROR (SyncWorker_16) [custom_components.sensor.phicomm_balance] get token failed
2018-11-20 09:10:07 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
KeyError: 'weight'
2018-11-20 09:11:40 INFO (MainThread) [homeassistant.components.http.view] Serving /api/ to 172.30.32.2 (auth: True)
2018-11-20 09:12:23 INFO (SyncWorker_14) [custom_components.sensor.phicomm_balance] Updating the sensor...
2018-11-20 09:12:33 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.phicomm_balance is taking over 10 seconds
2018-11-20 09:14:32 ERROR (SyncWorker_14) [custom_components.sensor.phicomm_balance] get token failed
2018-11-20 09:15:44 WARNING (MainThread) [homeassistant.components.sensor] Updating phicomm_balance sensor took longer than the scheduled update interval 0:03:20
发表于 2018-11-21 13:59:03 | 显示全部楼层
厉害了~~~~
发表于 2018-11-21 22:44:16 | 显示全部楼层
刚好有一台 看看
发表于 2018-11-22 13:07:22 | 显示全部楼层
多谢分享,天猫精灵也可以用吧。
发表于 2018-11-22 14:34:34 | 显示全部楼层
腻害了我的天,那堆垃圾又可以用了
发表于 2018-11-22 22:23:07 | 显示全部楼层
谢谢,明后天试试看
发表于 2018-11-23 15:56:38 | 显示全部楼层
把权限设低一些吧
发表于 2018-11-24 01:13:10 | 显示全部楼层
感谢分享,不知道怎么用.........
GMT+8, 2025-12-17 03:20 , Processed in 0.619164 second(s), 17 queries , MemCached On.
