查看: 7604|回复: 1
[求助] 群晖docker用homebridge连接homeassistant时docker循环崩溃
发表于 2018-6-24 23:28:52 | 显示全部楼层 |阅读模式
新手小白跟着教程在群晖下安装好了homeassistant,在安装homebridge时在配置好两种config.json时,启动后,homebridge就出现两种情况情况。
第一种配置文件如下:
    "bridge": {
        "name": "Homebridge",
        "username": "CC:22:3D:E3:CE:30",
        "port":51826,
        "pin": "123-45-678"
    "platforms": [
            "platform": "AqaraPlatform",
            "sid": [
                "f0b42999aab2"
            "password": [
                "qc2eeuwji4yyhbvu"
            "platform": "yeelight",
            "name": "yeelight"
        "platform": "HomeAssistant",
        "name": "HomeAssistant",
        "host": "http://192.168.1.111:8123",
        "password": "1234567890",
        "supported_types": ["binary_sensor", "climate", "cover", "fan", "switch", "garage_door", "camera", "device_tracker", "input_boolean", "light", "lock", "media_player", "rollershutter", "sensor", "scene", "switch"],
        "default_visibility": "visible",
        "logging": false,
        "verify_ssl": true
这种配置文件与小米的智能网关还有homeassistant同时连接可正常运行.
第二种配置文件如下
    "bridge": {
        "port":51826,
        "pin": "123-45-678"
    "platforms": [
        "logging": false,
        "verify_ssl": true
这种配置只把homebridge与homeassistant相连,这种情况下只要运行homebridge,就会出现无限崩溃的情况,系统提示容器已停止,请大神告知这是什么原因,如何解决
发表于 2018-6-25 11:48:04 | 显示全部楼层
你把第二种,homeassistant的host改为http://127.0.0.1:8123试试
GMT+8, 2025-11-6 22:04 , Processed in 0.236802 second(s), 8 queries , MemCached On.
