查看: 12404|回复: 1
[基础教程] 怎么在树莓派里不是rm-cover
发表于 2018-6-22 20:06:19 | 显示全部楼层 |阅读模式
按照论坛大神的帖子部署树莓派。我是装了hassio、hassbian9,我把那个rm_cover文件拷贝进custom_components下的cover里,但是出现coverRM.cover配置错误的提示。ha日志里出现以下情况:018-06-22 08:33:25 ERROR (SyncWorker_11) [homeassistant.util.package] Unable to install package broadlink==0.8: Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-0fx9_06o/pycryptodome/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-scfe9qvi-record/install-record.txt --single-version-externally-managed --prefix  --compile --user --prefix=" failed with error code 1 in /tmp/pip-build-0fx9_06o/pycryptodome/2018-06-22 08:33:25 ERROR (MainThread) [homeassistant.requirements] Not initializing cover.rm_cover because could not install requirement broadlink==0.8
2018-06-22 08:33:25 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform cover.rm_cover: Could not install all requirements.
我的配置是这样的:
 楼主| 发表于 2018-6-22 20:09:35 | 显示全部楼层
总是出现这两个错误:[homeassistant.requirements] Not initializing cover.rm_cover because could not install requirement broadlink==0.8
GMT+8, 2026-1-3 08:57 , Processed in 0.107817 second(s), 9 queries , MemCached On.
