查看: 6134|回复: 6
[已解决] 没有传感器的历史记录,怎么解决[已解决]
发表于 2018-6-13 13:13:04 | 显示全部楼层 |阅读模式
查看homeassistant的历史记录提示:
Error handling request
下午12:46 components/recorder/util.py (ERROR)
Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'SELECT states.state_id AS states_state_id, states.domain AS states_domain, states.entity_id AS states_entity_id, states.state AS states_state, states.attributes AS states_attributes, states.event_id AS states_event_id, states.last_changed AS states_last_changed, states.last_updated AS states_last_updated, states.created AS states_created \nFROM states \nWHERE (states.domain IN (?, ?) OR states.last_changed = states.last_updated) AND states.last_updated > ? AND states.entity_id IN (?) AND states.last_updated < ? ORDER BY states.last_updated'] [parameters: ('thermostat', 'climate', '2018-06-12 04:46:21.195000', 'sensor.humidity_158d000239acc0', '2018-06-13 04:46:21.195000')] (Background on this error at: http://sqlalche.me/e/4xp6)
发表于 2018-6-13 17:29:57 | 显示全部楼层
不懂,原因不会分析,但是对策应该是要么修复旧数据库要么导入新数据库
 楼主| 发表于 2018-6-13 18:30:29 | 显示全部楼层
数据库在哪里,要怎么修复
发表于 2018-6-13 18:46:37 | 显示全部楼层
停止hass运行,删除home-assistant_v2.db,重新启动hass。
 楼主| 发表于 2018-6-13 19:13:30 | 显示全部楼层
谢谢,解决问题。文件位置:/usr/share/hassio/homeassistant/home-assistant_v2.db
发表于 2018-6-20 17:10:37 | 显示全部楼层
谢谢~字数补丁
发表于 2018-10-9 19:48:20 | 显示全部楼层
我在 /usr/share/ 下没有 /hassio/homeassistant/home-assistant_v2.db
GMT+8, 2025-11-7 00:26 , Processed in 0.265229 second(s), 9 queries , MemCached On.
