查看: 3727|回复: 2
[技术探讨] 无法链接连接小米wifi放大器
发表于 2018-6-9 16:12:58 | 显示全部楼层 |阅读模式
根据官网描述,配置后无法链接小米wifi放大器,日志如下token是有效的
2018-06-09 15:50:39 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
2018-06-09 15:51:00 ERROR (SyncWorker_4) [miio.device] Unable to discover a device at address 192.168.130.30
2018-06-09 15:51:00 ERROR (SyncWorker_4) [homeassistant.components.device_tracker.xiaomi_miio] Device unavailable or token incorrect: Unable to discover the device 192.168.130.30
2018-06-09 15:51:00 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform xiaomi_miio
2018-06-09 15:51:06 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-06-09 15:54:59 ERROR (SyncWorker_1) [homeassistant.components.device_tracker.xiaomi] Connection to the router timed out at URL [url]http://192.168.31.1/cgi-bin/luci/;stok=607b08ad426233c9fb647a2dde0948db/api/misystem/devicelist[/url]
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 387, in _make_request
    six.raise_from(e, None)
  File "<string>", line 2, in raise_from
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 383, in _make_request
    httplib_response = conn.getresponse()
  File "/usr/lib/python3.6/http/client.py", line 1331, in getresponse
    response.begin()
  File "/usr/lib/python3.6/http/client.py", line 297, in begin
    version, status, reason = self._read_status()
  File "/usr/lib/python3.6/http/client.py", line 258, in _read_status
    line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
  File "/usr/lib/python3.6/socket.py", line 586, in readinto
    return self._sock.recv_into(b)
socket.timeout: timed out
  File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 440, in send
    timeout=timeout
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 639, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/usr/lib/python3.6/site-packages/urllib3/util/retry.py", line 357, in increment
    raise six.reraise(type(error), error, _stacktrace)
  File "/usr/lib/python3.6/site-packages/urllib3/packages/six.py", line 686, in reraise
    raise value
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 601, in urlopen
    chunked=chunked)
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 389, in _make_request
    self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
  File "/usr/lib/python3.6/site-packages/urllib3/connectionpool.py", line 309, in _raise_timeout
    raise ReadTimeoutError(self, url, "Read timed out. (read timeout=%s)" % timeout_value)
urllib3.exceptions.ReadTimeoutError: HTTPConnectionPool(host='192.168.31.1', port=80): Read timed out. (read timeout=5)
  File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/xiaomi.py", line 113, in _retrieve_list
    res = requests.get(url, timeout=5, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/api.py", line 72, in get
    return request('get', url, params=params, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/api.py", line 58, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 508, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/lib/python3.6/site-packages/requests/sessions.py", line 618, in send
    r = adapter.send(request, **kwargs)
  File "/usr/lib/python3.6/site-packages/requests/adapters.py", line 521, in send
    raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPConnectionPool(host='192.168.31.1', port=80): Read timed out. (read timeout=5)
发表于 2018-8-22 13:16:02 | 显示全部楼层
小米红外遥控器 报错:[homeassistant.components.remote.xiaomi_miio] Device unavailable or token incorrect: Got checksum error which indicates use of an invalid token. Please check your token!
发表于 2021-2-15 11:05:00 | 显示全部楼层
我的小米wifi 放大器接到Home assistant 也没有反应,找不到这个设备
GMT+8, 2025-12-29 10:31 , Processed in 0.048194 second(s), 6 queries , MemCached On.
