查看: 21585|回复: 17
[已解决] packages配置老出错,请大神看看
发表于 2018-6-7 15:49:20 | 显示全部楼层 |阅读模式
正如几个大神回复的,在configuration.yaml里把automation: !include automation.yaml注释掉,问题解决了,谢谢大神们,你们真热心,我还得多看多学习,感觉这是基础知识,劳烦各位大神了
以下是原问题
在configuration中已经加入packages: !include_dir_named packages
但是一检测就出问题
这个是packages下yaml文件,是下载的holala大神 https://bbs.hassbian.com/forum.p ... 1&highlight=package帖子附件然后根据家里房间数改的(我用大神的原文件也试过也是同样的错误,包括没改input_slider和把input_slider替换input_number都试过)
homeassistant:
  customize:
    sensor.temp_show:
      friendly_name: 设定的温度
      icon: mdi:temperature-celsius
    sensor.volume_show:
      friendly_name: 设定的风量
      icon: mdi:fan
    sensor.timing_show:
      friendly_name: 设定的定时
      icon: mdi:camera-timer
    script.ac_cancel_timing:
      friendly_name: 定时取消
      icon: mdi:timer-off
group:
  airconditioner_control:
    view: no
    control: hidden
    entities:
      - input_select.select_rooms_ac
      - input_select.select_mode_ac
      - input_number.airconditioner_temp
      - input_number.airconditioner_volume
      - input_select.select_function_ac
      - input_number.airconditioner_timing_on
      - input_number.airconditioner_timing_off
#     - script.ac_cancel_timing
      - sensor.temp_show
      - sensor.volume_show
      - sensor.timing_show
input_select:
  select_rooms_ac:
    options:
      - Select Rooms
      - 客厅
      - 书房
      - 儿童房
      - 睡房
    initial: Select Rooms
    icon: mdi:air-conditioner
  select_mode_ac:
    options:
      - Select Mode
      - 关闭空调
      - 制冷模式
      - 制热模式
      - 除湿模式
      - 自动模式
    initial: Select Mode
    icon: mdi:settings
  select_function_ac:
    options:
      - Select Function
      - 强力运转
      - 舒适气流
      - 送风
      - 极速运转
      - 水平风
      - 垂直风
      - 立体气流
    initial: Select Function
    icon: mdi:apple-keyboard-command
input_number:
  airconditioner_temp:
    icon: mdi:thermometer-lines
    initial: 24
    min: 18
    max: 32
    step: 1
  airconditioner_volume:
    icon: mdi:weather-windy
    initial: 7
    min: 1
    max: 7
    step: 1
  airconditioner_timing_on:
    icon: mdi:timer
    initial: 0
    min: 0
    max: 12
    step: 1
  airconditioner_timing_off:
    icon: mdi:timer
    initial: 0
    min: 0
    max: 12
    step: 1
  - platform: template
    sensors:
      temp_show:
        unit_of_measurement: "°C"
        value_template: '{{states.input_number.airconditioner_temp.state|round(0)}}'
        entity_id:
      volume_show:
        unit_of_measurement: "级"
        value_template: '{{states.input_number.airconditioner_volume.state|round(0)}}'
        entity_id:
      timing_show:
        value_template: '{{states.input_number.airconditioner_timing_on.state|round(0)}}小时后开、{{states.input_number.airconditioner_timing_off.state|round(0)}}小时后关'
        entity_id:
automation:
  - id: airconditioner_set_temp
    alias: airconditioner_set_temp
    trigger:
      - platform: state
        entity_id: input_number.airconditioner_temp
    action:
      - service: script.turn_on
        data_template:
          entity_id:
            - script.ac_temp_{{ states.input_number.airconditioner_temp.state | int }}
  - id: airconditioner_set_mode
    alias: airconditioner_set_mode
    trigger:
      - platform: state
        entity_id: input_select.select_mode_ac
    action:
        data_template:
          entity_id: >
            {% if trigger.to_state.state == '关闭空调' %}
              script.ac_mode_close
            {% elif trigger.to_state.state == '制冷模式' %}
              script.ac_mode_cold
            {% elif trigger.to_state.state == '制热模式' %}
              script.ac_mode_heat
            {% elif trigger.to_state.state == '除湿模式' %}
              script.ac_mode_dry
            {% elif trigger.to_state.state == '自动模式' %}
              script.ac_mode_auto
            {% endif %}
  - id: airconditioner_set_volume
    alias: airconditioner_set_volume
    trigger:
      - platform: state
        entity_id: input_number.airconditioner_volume
    action:
        data_template:
          entity_id:
            - script.ac_volume_{{ states.input_number.airconditioner_volume.state | int }}
  - id: airconditioner_set_function
    alias: airconditioner_set_function
    trigger:
      - platform: state
        entity_id: input_select.select_function_ac
    action:
        data_template:
          entity_id: >
            {% if trigger.to_state.state == '强力运转' %}
              script.ac_function_1
            {% elif trigger.to_state.state == '舒适气流' %}
              script.ac_function_2
            {% elif trigger.to_state.state == '送风' %}
              script.ac_function_3
            {% elif trigger.to_state.state == '极速运转' %}
              script.ac_function_4
            {% elif trigger.to_state.state == '水平风' %}
              script.ac_function_5
            {% elif trigger.to_state.state == '垂直风' %}
              script.ac_function_6
            {% elif trigger.to_state.state == '立体气流' %}
              script.ac_function_7
            {% endif %}
  - id: airconditioner_set_timing
    alias: airconditioner_set_timing
    trigger:
      - platform: state
        entity_id:
    action:
        data_template:
          entity_id:
            - script.ac_timing_on_{{ states.input_number.airconditioner_timing_on.state | int }}
            - script.ac_timing_off_{{ states.input_number.airconditioner_timing_off.state | int }}
script:
  ac_cancel_timing:
    sequence:
      - service_template: >
          {% if is_state('input_select.select_rooms_ac', '客厅') %}
            switch.broadlink_send_packet_192_168_2_17
          {% elif is_state('input_select.select_rooms_ac', '书房') %}
            switch.broadlink_send_packet_192_168_2_22
          {% elif is_state('input_select.select_rooms_ac', '儿童房') %}
            switch.broadlink_send_packet_192_168_2_23
          {% elif is_state('input_select.select_rooms_ac', '睡房') %}
            switch.broadlink_send_packet_192_168_2_24
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODg4ODg4PDg4OAAM8cjkOKg4PDg4ODg4rDg4NDw4PDg4NLA4ODisOKg4PDSsOKw4rDioOKw4ODg8NKw4PDg4ODg4PDg4NDw4PDg4ODg4PDg4ODg4PDg4NDw4ODg4PDg4rDg4ODg4PDioOKw4ODg8ODg4ODSwODg4rDioPDg0PDg4PDg4ODQ8ODw0PDg4ODw4qDisOKg8qDg8ODg0rDw4NKw4rDisOKg4PDg4ODg4PDg4ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8NDw4ODg8ODg0PDg8NDw4ODg4ODw0PDg4NEA4ODg4ODw4ODg4ODw4ODg4ODw0PDQ8ODg4PDg4OKw4ODisODg4ODg8OKg4rDg4NDw0QDg4OKw4ODg4NEA4ODg4ODg4PDg4ODg4PDg4ODg4rDg4OKw4ODisODg4rDgANBQAAAAA="
  ac_timing_on_0:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEARALEQ4ODg4ODg8OAAM8cjkOKg4PDg4ODg4rDg4ODw4ODg4OKw4ODSwOKw4ODisOKg4rDisOKg8ODQ8OKw4ODg4ODw4ODg4ODw4ODg4NEA4ODQ8NEA4ODQ8ODw4ODg4ODw4ODg4ODw4ODSsPKg4ODg8ODQ8rDg4ODg4rDisODg4NDw8ODg0PDRAODg4ODg8ODg4ODg4ODw4ODg4OKw4ODisNDw4PDg4ODg0QDQ8NDw0PDg8ODg0PDg8ODg4ODg8ODg4ODg8ODg4ODg4PDg0PDg4PDg0PDQ8ODg4PDg4ODw4ODg4ODw4ODg4ODw4ODg4ODg4PDQ8ODg4PDg4NDw4PDg4NKw8ODSsPDg4ODg4OKw0sDg4NDw4PDg4NKw8ODg4ODg4PDg4ODg0QDg4ODg4PDg4OKw4ODg4NLA4ODSwOKg4rDgANBQAAAAA="
  ac_timing_on_1:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODg4ODw4ODQ8NAAM+czkOKg8ODg4ODw4qDg8ODg4ODg8OKg4PDioOKw4ODisOKg8qDisOKg4PDg4OKw4ODg4ODw0PDg4ODw4ODg4ODw4ODg4ODw4ODg4ODw0PDg4ODw4ODSwODg4ODisOKg8ODg4NDw8qDg4ODw4qDisODg4PDg4ODg4PDQ8ODg4PDg4ODg4PDg4ODg4ODw4OKg4PDioODw4ODg4ODw4ODg4ODw4ODg4ODw4qDisOKg8qDg8NDw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4NEA0PDg4NEA0PDg4ODg8ODg4ODg4PDg4ODg4PDg4OKw4ODisODg4ODg8NKw4rDg4ODg4PDg4ODg4PDg4ODg4PDg4NDw4PDg4NDw4PDg4OKg8qDisODg4rDg4ODg4PDgANBQAAAAA="
  ac_timing_on_2:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODQ8ODw4ODg4NAAM/cjkOKw4ODg4NEA4qDg8ODg0PDg4PKg4ODisOKw0PDisOKg4rDisOKg8ODg4NLA4ODQ8ODw0PDg4ODw4ODg4NEA4ODg4ODw4ODg4ODw4ODQ8ODg8ODSsPDg4ODisOKg4PDg4NDw4rDg4ODw0rDisODg4PDg4ODg4ODw4NDw4ODg8ODg4ODg8ODg4ODg8OKg4PDSsODw0PDQ8ODw4ODg4ODg4PDg4ODg4PDioOKw4rDioODw4ODg4ODw0PDg4ODw4ODQ8NEA4ODg4ODw4ODg4ODw0PDg4ODw0PDg4ODg8ODg4ODg4PDg4ODg0QDQ8NDw4PDg4OKw4ODisODg0PDQ8OKw4rDg4ODg4PDg4ODg0QDg4ODg4PDg4ODg4PDQ8NDw4ODg8OKg8qDg4ODg8qDg8NKw4ODwANBQAAAAA="
  ac_timing_on_3:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8NDw4NDw4PDg4NAAM/cjkOKg8ODg4ODw0rDg4ODw4ODg4PKg4ODisOKw4ODSwOKg8qDisOKg4PDQ8NLA4ODg4PDg4ODQ8ODw0PDg4ODw4ODg4ODw4ODg4ODw0PDQ8ODw4ODisODg0PDisOKw4ODg4ODw0rDg8NDw0sDioODw0PDg4ODw4ODg4ODg4PDg4NDw4PDg4ODg4PDg4OKw4ODisODg4ODg8NDw4ODg8NDw4ODg8ODg4qDw4NKw8qDg4OKw4ODg8ODg0PDRAODg4ODg8NDg8ODg8ODg0PDg8NDw4ODQ8ODw0PDg4ODw4ODQ8NEA4ODQ8NEA4ODg4ODw0PDg4NLA4ODisODg4ODg8OKg4rDg4ODw4ODg4NDw8ODg4ODg4PDg4ODg4PDg4ODg4PDg0OLA4qDisOKg4PDg4ODg0sDgANBQAAAAA="
  ac_timing_on_4:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODg4NDw4PDQ8OAAM/czgOKw0PDg8ODg0sDg4ODg0QDg4OKg8ODioPKg4NECoOKw4qDyoOKw4ODg4OKw0PDg8NDw4ODg8ODg4ODg8ODg0PDg8ODg4ODg8NDw4ODg8ODg4ODSwODg4PDioOKw4ODg4ODw4qDw4ODg0sDioODw4ODQ8ODw4ODg4NDw4PDg4ODw0PDg4ODQ8PDg4NLA4ODisODg0PDRAODg4ODg8NDw4ODRAODg4rDioODw0rDg4ODw4qDw4NDw0PDg8NDw4ODg8ODg0PDg8ODg4ODg8ODg4ODg8NDw4ODg8ODg4ODg8ODg4ODg8NDw4ODg4ODw4ODQ8OKw4ODisODg4PDg4OKw4qDg8ODg4ODg8ODg4ODg4ODw0PDg4ODw4ODg4ODw4ODg4ODw4ODg4OKw0PDQ8PDg4ODgANBQAAAAA="
  ac_timing_on_5:
    sequence:
          {% endif %}
        data:
          packet:
  ac_timing_on_6:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEARAODg4ODg0QDQ8OAAM/cjkOKw4ODg8ODg4rDg4ODg4PDg4OKw4ODisOKg4ODyoOKw4qDyoOKw4ODg4OKw0PDg8NDw4ODg8ODg4ODRAODg4ODg8ODg4ODg8NDw4ODg8NDw4ODSwODg4ODisOKw4ODg4NEA0rDg8ODg4rDioODw4ODQ8NEA4ODg4NDw8ODg4ODg4PDg4ODg4PDg4NLA4ODisODg0PDg8ODg4ODg8NDw0PDg4ODw4ODisODg0sDioODw4qDg8NDw0PDg8ODg0PDg8ODg4ODRANDw0PDg8NDw4ODQ8PDg0PDQ8ODw4ODg4ODw4ODg4NEA4ODQ8ODw4ODQ8OKw4ODisODg0PDg8OKg4rDg4ODw4ODg4ODw4ODQ8ODw0PDg4ODg4PDg4ODg4PDg4ODg4PDSsODw4ODg4NLA4ODgANBQAAAAA="
  ac_timing_on_7:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8NDw4NEA4ODQ8OAANAcToOKg4PDg4ODg4rDg4NEA4ODg4OKw4ODisOKg8ODioOKw4rDioOKw4ODg4PKg4PDg4ODg4PDg4NDw4PDQ8ODg4PDQ8NDw4ODg8ODg0PDg8ODg0PDisODg4PDioOKw4ODg8ODg4rDg4NDw4rDioPDg4ODg8NDw4ODQ8ODw0PDg4ODw4ODg4NEA4ODg4NLA4ODisODg0QDQ8ODg4ODg8NDw4ODg8ODg4rDg4ODg0sDg4NLA4rDg4ODg0PDg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8NDw0PDg4ODw4ODg4ODw4ODg4NEA4ODg4ODw0PDg4NLA4ODisODg0PDw4OKg4rDg4ODw4ODg4ODw4ODg4ODw0PDg4NDw8ODQ8ODw0PDQ8ODg4PDg4ODg4PDQ8NDw0sDgANBQAAAAA="
  ac_timing_on_8:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEARALEA4PDg4ODg4OAANBcTkOKg8ODQ8NDw4rDg4ODw0PDQ8OKw4ODyoOKw4ODisOKg4rDisOKg4PDg4OKw4ODg4ODw0PDg4ODw0PDg4NDw4PDg4ODg8ODg4NDw4PDg4NDw4PDioODw0PDSwNKw4PDg4NDw4rDg4ODw4qDisODg4ODw4NDw4ODg4PDg0PDg8ODg0PDg8ODg4ODg8OKg4NECoNEA4ODg4ODw0PDQ8ODg4PDg4ODg4ODw4NDw4rDisOKg4rDQ8ODw0PDg0PDw0PDg4ODBAPDQ8ODg0QDQ8ODg4PDg4ODg4PDQ8ODg4PDg4ODg4PDg4NDw4PDQ8ODg0PDg8OKg8ODioPDg4ODg4OKw4rDg4NDw0QDg4NDw4PDQ8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODisOKw4qDisODg0sDgANBQAAAAA="
  ac_timing_on_9:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8MEA4NDw4PDQ8OAANAczkOKw4ODg4ODw4qDw4ODg0PDg8NKw4PDioOKw4ODisOKg8qDisOKg8ODg4OKw4ODQ8ODw4ODQ8ODw4ODg4ODw4ODg4ODg8ODg4ODg4PDg4ODg4PDioODw4ODisOKg4PDQ8ODg4rDg4ODw4qDisODg4PDQ8ODg4ODg8NDw4ODg8NDw4ODg8NDw4ODg8OKg4PDioODw0PDg4ODw4ODg4ODg4PDQ8NDw4rDisOKg4PDg4NDw4ODisODg4PDg4ODg0QDg4ODg0QDg4ODg4PDg4NDw0QDQ8ODg0PDg8NDw4ODg8ODg4ODg8NDw0PDQ8ODw4ODQ8PKg4ODSwODg4PDg4OKg4rDg4ODw4ODg4ODw4ODg4ODw0PDg4ODw4ODg4NDw4PDg4OKw0PDQ8OKw4qDyoNLA4qDgANBQAAAAA="
  ac_timing_on_10:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODg8ODg4ODg8OAANBcjkOKg8ODg4NEA0rDg0QDg0PDg4OKw4PDSsOKw4ODisOKg4rDisOKg4PDg4OKw4ODg4ODw4ODQ8ODw0PDQ8ODw0PDg4ODw0PDg4ODg4PDg4ODg4PDioODw4ODisOKg4PDg4ODg0sDg4ODw4qDisODg4NEA4NDw0PDg8NDw4ODg8NDw4ODg8ODg4ODg8NKw4ODisODg4PDg4NDw4PDg4ODg4PDg4NDw4rDg4OKw4ODg4PKg4ODSwODg0QDg4NDw4PDQ8ODg4PDg4ODg4ODw4ODg0PDRAODg4ODg8ODg4ODg8ODg0PDg8NDw0PDg8NDw4ODg4OKw4ODisODQ8PDg4NLA4qDg8NDw4NDw8NDw4ODg4ODw4NDw4ODw4ODg4ODw4ODg4NLA4ODg4ODw4qDisOKg8ODgANBQAAAAA="
  ac_timing_on_11:
    sequence:
          {% endif %}
        data:
          packet:
  ac_timing_on_12:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8NDw8NDw4ODg8NAANCcjkOKw4ODg4ODw4qDg8ODg4NDw8OKg4PDioOKw4ODisOKg8qDisOKg4PDg4NLA4ODQ8ODw4ODQ8ODg4PDg4ODg4PDQ8NDw0QDQ8ODg4PDg0ODw4PDioODw4ODSwNKw4PDg4ODg4rDg4NDw8qDisODg4ODg8ODg4ODg8NDw4ODg8NDw4ODg8NDw4ODg4OKw4ODisODg4PDg4NDw4PDg4ODg4PDQ8ODg4ODw4OKg4PDSsPKg4ODisODg4PDg4ODg4ODg8ODg0PDg8ODg4ODg8ODg4ODRANDw0PDg8NDw4ODg4PDg0PDg4ODw0PDQ8ODw0PDg4OKw0PDisODg4PDQ8NKw4rDg4NEA4ODQ8ODw4ODg4ODw4ODQ8ODg4PDg4ODw0PDg0PKw4ODisOKg4PDioODw0rDgANBQAAAAA="
  ac_timing_off_0:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ4PDRAMEA0PDRAMAAM9cToNLA0PDRAMEA0rDRANDw0PDRANKw0QDSsNLA0PDSwNKw0sDSsOKw0QDQ8NKw4PDQ8NEA0PDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NDw0sDQ8NEA0PDSsNLA0QDBANDw0QDCwNEAwsDSsODw0PDRANDw0PDRAMEA0PDRAMEA0rDSwNKw4rDRAMEA0rDRANKw0sDSsOKw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0PDRANDw0PDRAMEA0PDRAMEA0PDRAMEA0PDQ8NEA0PDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NKw4PDSsNEA0PDRAMLA0rDg8NDw0QDQ8NKw0QDQ8NEAwQDQ8NEAwPDg8NDw0QDQ8NDw0sDQ8NLA0PDSwNDw0rDgANBQAAAAA="
  ac_timing_off_1:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODg8NDw0PDg8OAAM9cjkPKg4ODw4ODg4rDg4ODg4PDQ8NLA4ODisOKg4PDSsOKw4rDioOKw4ODg8NKw4PDg4ODg0QDg4ODg4PDQ8ODg4PDg4NDw4ODw4ODg4ODw4ODg4rDg4OKw4ODisOKg8ODg4ODg0QDioODw4qDisODg4PDg4NDw0QDg4ODg4PDQ8ODg4rDioPKg4rDg4ODg4rDg4OKw4rDioOKw4ODg8ODg4ODg8ODg4ODRAODg4ODRAODg0PDg8ODg4ODg4ODw4qDyoOKw4qDg8ODg4ODg8ODg4ODRAODg4ODg8ODg4ODRAODg0PDg4PDg4ODQ8PDg4ODg4PKg4ODisODg4PDg4OKw4qDg8ODg4ODg8ODg4ODg8ODg4ODQ8PDg4ODQ8ODw4ODg4OKw4ODg8ODg4ODisNLA4ODgANBQAAAAA="
  ac_timing_off_2:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEARAODg4ODg4PDg4NAAM+czgPKg4PDg4ODg4rDQ8ODg4PDg4OKw4ODisOKg4PDioOKw4rDioOKw4ODg8NKw4PDg4NDw4PDg4ODg4PDg4ODg0QDg4ODg4PDg4NDw4PDg4NDw4rDg4OKw0PDisOKg4PDQ8ODg4PDioODw4qDisODg4PDg4ODg4ODw4ODg4ODg8ODg4rDioOKw4rDg4ODg4rDg4OKw4qDyoOKw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw0PDg4NDw8ODg4ODg4PDioOKw4rDioODw4ODg4ODw4ODg4ODg4PDg4ODg4PDg4NDw4PDg4NDw4PDg4ODg0PDg8OKg4PDioODw0PDQ8OKw4qDw4ODg0PDg8ODg4ODg8ODg4ODg8ODg4ODg4ODw4ODQ8OKw4ODisODg4PDioODw4ODgANBQAAAAA="
  ac_timing_off_3:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODg4NEA4ODg4OAAM+cjkOKg8ODg4ODg4rDg4ODw4ODg4NLA4ODisOKg8ODioPKg4rDioOKw4ODg8OKg4PDg4ODg4PDQ8NDw4PDg4ODg4PDQ8NDw4ODw4ODg4ODw4ODg4rDg4OKw4ODioPKg4ODg8ODg4ODyoODg4rDisODg0PDg8ODg4ODg8ODg4ODg8ODg0rDyoOKw4qDg8ODg4rDg4OKw4qDisOKg8ODg4ODg4PDg4ODg4PDg4ODg4PDg4ODg4PDg4NDw4PDQ8ODg4rDg4NLA4qDg8OKg4PDg4ODg4PDQ8ODg4PDQ8ODg0PDw4ODg4ODg8NDw0PDg8ODg4ODg8NKw4PDSsNDw4PDQ8OKw4qDg8ODg0PDg8ODg4ODg4PDg4ODg4ODw0PDg4ODw0PDg4OKw4ODg8OKg4PDSsOKw4qDgANBQAAAAA="
  ac_timing_off_4:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODg4ODg8ODg4OAAM/czgOKw4ODg8ODg4qDw4ODg4ODg8OKg4PDioOKw4ODisOKw4qDisOKw4ODg4OKw4ODg8NDw4ODQ8ODw0PDg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4qDg8OKg4PDioOKw4ODg4PDg4ODisODg4rDioODw4ODg4ODw4ODg4ODw0PDg4ODg4rDisOKg4rDg4NEA4qDg8OKg4rDisOKg4PDg4ODg4PDQ8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg0PDg8OKg4rDioPKg4ODw4ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODQ8OKw4ODisNDw4PDQ8NLA4qDg8ODg0PDg8ODg4ODg4ODw4ODg4ODw4ODg4ODw0PDg4OKw4ODisOKg8ODSsODw4qDgANBQAAAAA="
  ac_timing_off_5:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODg4ODw4ODg4OAAM/czkOKg4PDg4ODg4rDg4ODw4ODg4OKw4ODisOKg4PDioPKg4rDioPKg4ODg8OKg4PDg4ODg4PDQ8ODg4PDg4ODg4PDg4ODg4PDg4NDw4PDg4ODg4rDg4OKw4ODisOKg4PDQ8ODg0QDioODw0rDisODg4ODw4ODg4ODg8ODg4ODg8ODg0sDioOKw4qDw4ODg4rDg4OKw4qDisOKw4ODg4ODw4ODg4ODw4ODg4ODw0PDQ8ODg4PDg4ODg4PDg4ODg4rDioPDg4qDg8ODg0sDg4ODg4PDg4ODg4ODw4ODg4ODg8ODg4ODg8NDw4ODg8ODg4ODg4OKw4ODisODg4PDg4OKw4qDg8NDw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODg4PDg4NDw4rDisOKg4PDQANBQAAAAA="
  ac_timing_off_6:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEARAKEQ4ODg4PDg4OAAM/cjkOKw4ODg8ODg4rDg4ODg4PDg4NLA4ODisOKg4PDSsOKw4qDyoOKw4ODg4OKw4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg0PDg8ODg4ODg8ODg4qDg8OKg4PDioOKw4ODg8NDw4ODisODg4rDioODw4ODg4ODw4ODg4ODw4ODg4NEA0rDisOKw4qDg8ODg4qDg8OKg4rDisOKg4PDg4ODg0QDQ8NDw4ODg8ODg4ODg8ODg4ODRAODg4ODg8ODg4ODisODg4rDioODw4qDg8ODg4ODg8ODg0PDg4PDg4ODQ8ODw4ODg4ODw4ODQ8ODw4ODg4OKw4ODisODg4ODg8OKg4rDg4ODw4ODg4ODw4ODg4ODw0PDg4ODg8ODg4ODg4PDQ8ODg4PDioODw4qDisODg4ODwANBQAAAAA="
  ac_timing_off_7:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODg4ODw4ODg4OAANAcjkOKg4PDg4ODg0sDg4ODw4ODg4OKw4ODisOKg4PDioOKw4rDioOKw4ODg8OKg4PDQ8ODg4PDQ8ODg4PDg4ODg4PDg4ODg4ODg8ODg4ODg8ODg4rDg4OKw4ODioPKg4PDg4ODg4PDSsODg4rDisODg4ODg8ODg4ODg8NDw4ODg8ODg4qDisOKw4qDg8ODg4qDw4OKg8qDisOKg4PDg4ODg4PDg4ODg0QDg4ODg4PDg4ODg0QDg4ODg4ODg8ODg4rDg4ODg4rDg4OKw4qDg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8NDw4ODg4OKw4ODisODg4PDg4NKw8qDg4ODw4ODg4ODw4ODQ8ODw4ODg4ODg4PDg4ODg0QDg4ODg0QDg4OKg8qDisOKg4rDgANBQAAAAA="
  ac_timing_off_8:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODg8ODg4ODQ8OAANBczgOKw4ODg8ODg0sDg4ODg4PDg4OKg8ODioPKg4ODisOKw4qDisOKw4ODg4OKw4ODRAODg4ODg8ODg4ODg8ODg4ODg4ODw4ODQ8ODw4ODg4ODw0rDg8OKg4PDioOKw4ODg4ODw4ODisODg0sDioODw4ODQ8ODw4ODg4ODw0PDg4ODg4rDisOKg4rDg4ODw4qDg4OKw4rDioOKw4ODg8ODg4ODg8ODg4ODg4ODw4ODg4ODw0PDg4NEA4ODQ8ODw4ODg4NDw4rDisOKg4rDg4ODg4PDg4ODg4PDg4NDw4PDg4ODg0QDg4ODg4PDQ8NDw4ODg8NKw4PDioODg8ODg4OKw4qDg8ODg4ODg8ODg0PDg8ODg0PDg4ODw4ODg4ODw4ODg4ODw4ODioPKg4rDSsODw4qDgANBQAAAAA="
  ac_timing_off_9:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODg4ODw4ODg4NAANCczgOKw4ODg4ODw0rDg8ODg4ODg8OKg4PDioOKw4ODisOKg4rDioPKg4ODw4OKg4PDg4ODg4PDg4ODg4PDQ8ODg4PDg4ODg4PDQ8NDw4PDg4ODg4rDg4OKw4ODisOKg4PDg4ODg4ODyoODg4rDisODg4ODRAODg4ODRAODg4ODg4PDg4qDisOKw4qDg8ODg4qDw4OKg4rDisOKg4PDg4ODg4PDg4ODg4ODg8NDw4ODg8ODg4ODg8NDw4ODg4PDg4qDisOKw4ODQ8ODw4ODisODg4ODg4ODw4ODg4PDg4ODg4ODw0PDg4ODw4ODg4ODw0PDg4OKw4ODisODg4ODg8OKg4rDg4ODg4PDg4ODg4PDg4ODg4PDg4ODg0QDg4ODg4PDg4OKg4rDisOKg4rDioOKw4ODgANBQAAAAA="
  ac_timing_off_10:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODg8NDw4ODg8OAANAcjkPKg4ODg8ODg4rDg4ODg4PDg4OKw4ODisOKg4PDioOKw4qDyoOKw4ODQ8OKw4ODRAODg4ODg8ODg4ODg8ODg4ODg8NDw0PDg4ODw0PDg4ODw4qDg8OKg4PDioOKw4ODg4ODw4ODisODg4qDyoODg4PDQ8ODg8ODg4ODg4PDg4ODg4rDioPKg0sDg4ODg4rDg4OKw4qDyoOKw4ODg4ODw4ODQ8ODg8ODg4ODg4PDg4ODg4PDg4ODg4PDg4ODg4PDioOKw4ODSwODg4ODisODg4PDg4ODg4PDg4ODg4ODg8ODg0PDg8ODg0PDg8ODg4ODg8OKg4ODyoODg4PDg4OKw4qDg8ODg4ODg8ODg4ODQ8ODw0PDQ8PDg4ODg4ODw4ODg4OKw4qDg8ODg4ODg8NKw4PDgANBQAAAAA="
  ac_timing_off_11:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODg8NDw0PDg8OAANAczgPKg4ODg8ODg4rDg4ODg4PDg4OKg8NDyoPKg4ODisOKw4qDisOKw4ODg4OKw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw0rDg8OKg4PDioOKw4ODg4ODw4ODisODg4qDyoODw4ODg4ODg8ODg4ODg8ODg4ODg4rDisOKg4rDg4NEA4qDg8OKg4rDioPKg4ODg8NDw4ODg8NDw4ODg8ODg4ODg8NDw4ODg4ODw4ODg4ODw0rDg8OKg4PDQ8OKg8ODioPDg0PDg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw0PDg4NLA4ODisODg4ODg8OKg4rDg4ODg4PDg4ODg4PDg4ODg4PDg4ODg4PDg4NDw4PDg4NKw8qDisODg4ODg8NDw4ODgANBQAAAAA="
  ac_timing_off_12:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODg8ODg4ODg8OAANBcjgPKg4ODg8ODg0sDg4ODg4PDg4OKw4ODisOKg4PDSsOKw4qDisOKw4ODg4OKw4ODg8ODg4ODg8ODg4ODg4PDg4ODg4ODw4ODg4NEA0PDg4NEA4qDg8NKw4ODyoOKw4ODg4NEA4ODioPDg4qDyoODg4PDg4ODg4PDg4ODg4PDg4ODg4rDioPKg4rDg4ODg4rDg4OKw4qDisOKw4ODg4ODw4ODg4ODw0PDg4ODg4PDg4ODg4PDg4ODg4PDQ8ODg4PDg4OKg8ODioPKg4ODisNDw4PDQ8ODg4ODw4ODg4ODg8ODg4ODg8ODg4ODg8ODg0PDg4OKw4ODisODg0QDg4OKg4rDg4ODw4ODg4ODw4ODg4ODg4PDQ8NDw4PDg4ODg0QDg4OKg8qDg4OKw4ODRANKw4rDgANBQAAAAA="
  ac_function_1:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEARENDQ8NEAwQDQ8NAAM9cToNLA0PDRANDw0rDg8NDw0QDQ8NKw4PDSwNKw0QDSsNLA0rDisNLA0PDRANKw0QDQ8NEAwQDQ8NEAwQDQ8NDw0QDQ8NDw0QDQ8NDw0QDQ8NDw0sDQ8NEA0PDSsOKw0QDQ8NDw0QDQ8NDw0sDSsNEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMLA0QDCwNKw4rDSwNKw4PDQ8NEA0PDQ8NEA0PDQ8NEA0PDQ8NEA0PDQ8NEA0PDQ8NEA0PDQ8NEAwQDQ8NEAwQDQ4OEAwQDSsNEA0PDRAMEA0PDRAMEA0PDRAMEA0PDQ8NDw4PDQ8NLA0PDSwNDw0QDQ8NKw4rDQ8NEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMLA0PDSwNKw4rDQANBQAAAAA="
  ac_function_2:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODQ8NEA0PDRAMAAM9czgNLA0QDBANDw0sDQ8NEAwQDQ8NKw4PDSsOKw0QDSsNLA0rDisNLA0PDRANKw0QDQ8NDw0QDQ8NDw0QDQ8NDw0QDBANDw0QDBANDw0QDBANDw0sDQ8NEAwQDSsNLA0PDRANDw0PDRAMEA0rDSwNEAwQDQ8NEAwQDQ8NEAwQDQ8NDw0QDQ8NDw0QDQ8NKw0QDSsNLA0sDSsNLA0ODhANDw0QDBANDw0QDBANDw0PDRANDw0ODhANDw0PDRANDw0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDQ8NEA0PDQ8NEA0PDRAMEA0PDQ8NLA0PDSwNDw0QDBANKw0sDRAMLA0QDBANDw0PDRANDw0PDRANDw0PDRANDw0PDRAMLA0QDBANKw0QDSsNLA0sDQANBQAAAAA="
  ac_function_3:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ4PDQ8NDw4PDRAMAAM9cToNLA0PDRANDw0sDQ8NEAwQDQ8NLA0PDSsOKw0QDSsNLA0rDisNLA0PDRANKw0PDg8NDw0QDQ8NDw0QDQ8NDw0QDQ8NDw0QDQ8NDw0QDQ8NDw0sDQ8NDw0QDQ8NLA0rDRANDw0sDQ8NEAwsDSwNDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0PDSwNKw4PDQ8NLA0rDSwNLA0NDxAMEA0PDRAMEA0PDRAMEA0PDRAMDw4PDQ8NEA0PDQ8NEA0PDQ8NEAwQDQ8NEAwQDQ8NDw0QDQ8NEAwQDQ8NEAwQDQ8NDw0QDQ8NDw0QDQ8NDw0QDBANKw0QDSsNEA0PDRAMLA0rDg8NDw0QDQ8NDw0QDBANDw0QDBANDw0QDBANDw0QDBANKw0QDQ8NKw4PDSsNEA0rDQANBQAAAAA="
  ac_function_4:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODRANDw0QDBANAAM8cjoNKw4PDQ8NDw4rDRANDw0PDRANKw0QDSsNLA0PDSwNKw4rDSwNKw4PDRAMLA0QDBANDw0QDBANDw0QDBANDw0QDBANDw0PDRANDw0QDBANDw0sDQ8NEAwQDQ8NLA0rDRANDw0sDQ8NEAwsDSwNDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDCwNLA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMDw4PDRAMEA0PDQ8NEA0PDRAMEA0PDQ8NEA0PDQ8NEA0PDQ8NEA0PDQ8NEA0PDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NLA0PDSwNDw0QDBANKw0sDQ8NEA0PDRAMEA0PDRAMEA0rDRANDw0QDBANDw0QDBANKw0sDQ8NLA0rDg8NDw0sDQANBQAAAAA="
  ac_function_5:
    sequence:
          {% endif %}
        data:
          packet:
  ac_function_6:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAREMDRANDw0QDBANAAM9cjkNLA0PDRAMEA0rDRANDw0QDBANKw0QDSsNLA0QDCwNLA0rDisNLA0PDRANKw0QDQ8NDw0QDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NDw0sDQ8NEA0PDQ8NLA0rDg8NDw0sDQ8NEA0rDSwNDw0QDQ8NDw0QDQ8NDw0QDQ8NDw0sDSsOKw0sDSsOKw0QDQ8NDw0QDQ8NDw0QDQ8NDw0QDQ8NDw0QDBANDw0ODw8NDw0QDQ8NDw0QDBANDw0QDBANDw0PDRANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANKw0QDSsNEA0PDRAMLA0sDQ8NEAwQDQ8NEAwQDQ8NEAwsDRAMEA0PDRAMEA0PDRAMEA0rDRANKw0QDSsNEA0rDQANBQAAAAA="
  ac_function_7:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEARANDRAMEA0PDRAMAAM9czgOKw0QDQ8NEAwsDRAMEA0PDRAMLA0PDSwNKw4PDSsOKw0sDSsOKw0QDQ8NKw4PDQ8NEA0PDQ8NEA0PDQ8NEA0PDQ8NEA0PDQ8NEA0PDQ8NEAwsDRAMEA0PDRAMLA0sDQ8NEAwsDRAMEA0rDSwNDw0QDQ8NEAwQDQ8NEAwQDQ8NDw0sDSsOKw0sDSsNLA0QDBANKw0sDSwNKw0QDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NDw0QDQ8NEAwQDQ8NDw0QDQ8NDw0QDBANDw0QDQ8NDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANKw0QDSsNEA0PDQ8NLA0rDRANDw0QDBANDw0QDBANDw0sDQ8NEAwQDQ8NEAwQDQ8NLA0PDRAMLA0sDSsNEA0rDQANBQAAAAA="
  ac_volume_1:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ4ODg8NEAwQDQ8NAAM9cToNLA0PDRANDw0rDg8NDw0QDQ8NKw4PDSsOKw0QDSsNLA0rDisNLA0PDRANKw0QDQ8NDw0QDQ8NDw0QDQ8NDw0QDQ8NEAwQDQ8NEAwQDQ8NDw0sDQ8NEA0PDSsOKw0QDQ8NEAwQDQ8NEAwsDSsODw0QDBANDw0QDBANDw0QDBANDw0PDRANDw0PDSwNKw4PDSsNLA0sDSsNLA0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0PDRANDw0PDRANDw0PDRANDw0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMLA0QDCwNEAwQDQ8NKw4rDRANDw0QDBANDw0PDRANDw0PDRANDw0PDRANDw0PDRAMLA0sDSsNEA0rDSwNLA0rDQANBQAAAAA="
  ac_volume_2:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ4PDQ8NEA0PDRAMAAM9cToNLA0PDRANDw0rDg8NDw0QDQ8NKw4PDSsOKw0QDSsNLA0rDSwNLA0PDRAMLA0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0PDRANDw0rDg8NDw0QDCwNLA0PDRAMEA0PDRAMEA0rDSwNEAwQDQ8NDw0QDQ8NDw0QDBANDw0QDBANDw0QDCwNLA0PDRAMLA0rDisNLA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDQ8NEA0PDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NDw0QDQ8NDw0QDQ8NDw0QDBANDw0PDRANKw0QDSsNEA0PDQ8NLA0rDRANDw0QDBANDw0QDBANDw0PDRANDw0PDRANDw0PDRAMLA0sDSsNEA0rDSwNKw0QDQANBQAAAAA="
  ac_volume_3:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEARANDRANDw0QDBANAAM9czgNKw0QDQ8NEAwsDRAMEA0PDRAMLA0PDSwNLA0PDSwNKw0sDSwNKw0QDQ8NLA0PDRAMEA0PDRANDw0PDRANDw0PDRAMEA0PDRAMEA0PDRAMEA0rDRANDw0QDCwNLA0PDRAMEA0PDRAMEA0rDSwNEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwsDRAMLA0sDSsNLA0QDBANDw0PDRANDw0QDBANDw0PDRANDw0PDRANDw0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDQ8NLA0PDSwNDw0QDBANKw8qDRAMEA0PDRAMEA0PDQ8NEA0PDQ8NEA0PDQ8NEA0PDQ8NLA0rDSwNEAwQDQ8NEAwsDQANBQAAAAA="
  ac_volume_4:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ4PDRANDw0QDBANAAM9cToNKw4PDQ8NEA0rDRAMEA0PDRAMLA0QDSsNLA0PDSwNKw4rDSwNKw0QDQ8NLA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0rDRANDw0QDCwNKw4PDRAMEA0PDQ8NEA0rDSwNDw0QDQ8NDw0QDQ8NDw0QDBANDw0QDBANDw0QDCwNEAwsDRAMLA0rDisNLA0QDBANDw0QDBANDw0PDRANDw0PDRANDw0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDQ8NEAwQDQ8NEAwQDQ8NLA0PDSwNDw0PDRANKw0sDQ8NEA0PDQ8NEAwQDQ8NEAwQDQ8NDw0QDQ8NEAwQDQ8NKw4rDSwNDw0sDQ8NEAwsDQANBQAAAAA="
  ac_volume_5:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODg8NEAwQDQ8NAAM9cjkNKw4PDRAMEA0rDRANDw0QDBANKw0QDSsNLA0PDSwNLA0rDSwNLA0PDRAMLA0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0sDQ8NEAwQDSsNLA0PDRANDw0QDBANDw0rDisNEA0PDQ8NEA0PDQ8NEA0PDQ8NEA0PDQ8NEA0PDQ8NLA0rDg8NKw0sDSwNKw0QDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NDw0QDQ8NDw0QDQ8NDw0QDQ8NDw0QDQ8NDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANKw0QDSsNEA0PDQ8NLA0rDRANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANKw0sDSwNDw0QDCwNEAwsDQANBQAAAAA="
  ac_volume_6:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ4NDw8NEAwQDQ8NAAM9cjkNLA0QDBANDw0sDQ8NEA0PDQ8NLA0PDSwNKw0QDSsOKw0sDSsOKw0QDBANKw0QDQ8NEA0PDQ8NEA0PDQ8NEA0PDQ8NEAwQDQ8NEAwQDQ8NEAwsDRAMEA0PDSwNKw0QDQ8NEAwQDQ8NEAwsDSwNDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0PDSwNKw4rDRANKw0sDSsOKw0PDRANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0PDRANDw0PDRANDw0PDRANDw0PDRANDw0PDRAMEA0PDRAMEA0PDRAMLA0QDCwNDw0QDQ8NKw4rDRANDw0PDRANDw0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMLA0rDisNEA0rDSwNDw0sDQANBQAAAAA="
  ac_volume_7:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ4PDRAMEA0PDRAMAAM+cToNKw0QDQ8NEAwsDRAMEA0PDRAMLA0QDCwNLA0PDSwNKw4rDSwNKw4PDQ8NLA0PDQ8ODw0PDRANDw0PDRANDw0PDRANDw0QDBANDw0QDBANDw0rDg8NDw0QDSsNLA0PDRANDw0PDRANDw0rDisNEA0PDQ8NEA0PDQ8NEA0PDQ8NEA0PDQ8NEA0PDQ8NLA0PDSwNKw4rDSwNKw0QDQ8NEA0PDQ8NEAwQDQ8NEAwQDQ8NEA0PDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NDw0QDQ8NDw0QDBANDw0QDBANKw0QDSsNEA0PDRAMLA0sDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NDw0QDQ8NDw0QDQ8NKw0sDSwNDw0QDCwNLA0rDQANBQAAAAA="
  ac_mode_close:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEARANDRAMEA0PDRANAAM8czkNKw0QDQ8NEAwsDQ8NEA0PDRAMLA0QDCwNKw4PDSsOKw0sDSsOKw0QDQ8NKw4PDQ8NEA0PDQ8NEA0PDQ8NEA0PDQ8NEA0PDQ8NEA0PDQ8NEA0PDQ8NEAwQDQ8NEAwQDQ8NEAwsDRAMEA0rDSwNEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NDw0QDQ8NKw4PDSsOKw0sDSsOKw0QDQ8NDw0QDBANDw0QDQ8NDw0QDQ8NDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0PDRANKw0QDSsNEA0PDQ8NLA0rDRANDw0QDBANDw0QDCwNDw0QDQ8NEAwQDQ8NDw0QDBANDw0QDBANKw0sDSwNKw0sDQANBQAAAAA="
  ac_mode_cold:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAREMDRANDw0PDRANAAM8dDcOKw0QDQ8NDw0sDQ8NEA0PDQ8NLA0PDSwOKg0QDSsNLA0sDSsNLA0QDBANKw0QDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NDw0sDg4ODw0PDSsOKw4ODRANDw0QDBANDw0sDSsNEA0PDRAMEA0PDRAMEA0PDRAMEA0PDQ8NEA0PDQ8NLA0PDSwOKg0sDisNKw0QDQ8NDw0QDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NDw0QDQ8NDw0QDQ8NDw0QDQ8NDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0PDRANKw0QDCwODwwQDQ8NLA4qDRANDw0QDBANDw0QDBANDw0PDRANDw0PDRAMEA0PDRAMLA4rDSsNEA0PDSsPKg0sDgANBQAAAAA="
  ac_mode_heat:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ4PDRANDw0QDBANAAM8czgOKw0QDQ8NDw0sDQ8NEA0PDRAMLA0PDSwNKw4PDSsOKw0sDSsOKw0QDQ8NKw4PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDQ8NEA0rDRANDw0PDRANDw0rDRANDw0sDQ8NEAwsDSwNDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANKw0QDSsNLA0rDisNLA0PDRANDw0PDRANDw0PDRANDw0PDRANDw0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDQ8NEA0PDQ8NEA0PDQ8NEA0PDQ8NEAwQDQ8NLA0PDSwNDw0QDBANKw0sDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDQ8NLA0PDRANKw0sDSsNLA0sDQANBQAAAAA="
  ac_mode_dry:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEARANDRANDw0QDQ8NAAM8czkNKw0QDQ8NEAwsDRAMEA0PDQ8NLA0PDSwNKw4PDSsOKw0sDSsOKw0QDBANKw4PDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwsDQ4OEA0PDQ8NLA0PDRAMEA0PDRAMEA0PDRAMLA0sDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NDw0QDQ8NKw4PDSsOKw0sDSsOKw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0PDRANDw0PDRANDw0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDQ8NEA0PDQ8NLA0PDSwNDw0QDBANKw0sDQ8NEA0PDQ8NEA0PDQ8NEA0PDQ8NEAwQDQ8NEAwQDQ8NLA0rDSwNDw0QDSsNLA0PDQANBQAAAAA="
  ac_mode_auto:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODQ8ODw0PDRANAAM7czoNKw4PDQ8NEA0rDRAMEA0PDRANKw0QDSsNLA0PDSwNKw4rDSwNKw4PDQ8NLA0PDRANDw0PDRANDw0PDRANDw0QDBANDw0QDBANDw0QDBANDw0rDg8NEAwQDQ8NDw0QDQ8NEAwsDQ8NEA0rDSwNDw0QDQ8NDw0QDQ8NDw0QDQ8NDw0QDQ8NDw0QDBANKw0QDSsNLA0sDSsNLA0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0QDBANDw0PDRANDw0QDBANDw0PDRANDw0QDBANDw0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMLA0PDSwNDw0QDQ8NKw4rDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMEA0PDRAMLA0PDRANKw0sDSsODw0rDQANBQAAAAA="
  ac_temp_18:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ4PDQ8NEA0PDRAMAAM+cToNKw4PDQ8NEA0rDRANDw0QDBANKw8ODSsNLA0QDCwNLA4qDSwNLA0PDRANKw0PDg8NDw0PDg8NEAwQDQ8NDw0QDQ8NEAwQDQ8NEAwQDQ8NEAwsDQ8NEA0PDSwNKw0QDQ8NDw0QDSsNEA0PDSwNDw0QDBANDw0QDBANDw0QDBANDw0sDSsNLA0sDSsNLA0QDBANKw0sDSwNKw0QDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NDw0QDQ8NEAwQDQ8NDw0QDQ8NDw0PDg8NEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NEAwQDQ8NKw4PDSsODw0PDRANKw0sDQ8NEA0PDQ8NEA0PDQ8NEA0rDQ8ODw0PDRANDw0PDRANKw0sDQ8NLA0rDisNLA0PDQANBQAAAAA="
  ac_temp_19:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEARANDg8ODg4ODg8OAAM8cjkOKw4ODg4ODw4qDg8ODg4ODg8OKg4PDioOKw4ODisOKw4qDisOKw4ODg4OKw4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4rDg4ODg4PDioOKw4ODg8ODg4rDioODw4ODisODg4ODg8ODg4ODg8ODg4ODg8ODg4qDyoOKw4qDyoOKw4ODg8OKg4rDioPKg4PDg4ODg4PDg4ODg4PDg4ODg4PDg4ODg4PDg4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8OKg4PDioODw4ODg4OKw4qDw4ODg4ODw4ODg4ODw4ODg4rDg4ODg8ODg4ODg4PDg4OKw8NDisOKg4rDisOKg4PDwANBQAAAAA="
  ac_temp_20:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ4PDw0NEA4ODw0PAAM8cToNKw8ODw0PDQ8qDw0PDg8NDw4OKg8NDyoNLA8LESoNKw4rDyoPKQ8ODw0PKg8NDwsRDg0QDBANDw0PDRAODg0PDw4NDw0PDQ8PDg8NDg4PDg0rDg8PDQ0QDioNLA0PDRANDw0QDBANKw8NDyoNDw8ODQ8NEA0PDQ8NDw8ODg4PDQ4rDyoPKQ8qDyoNKw8ODg4PKg4qDSwPKg0PDw0PDg8NDw0PDg4ODw4ODg0PDw4ODQ8ODw0PDg4ODw4ODQ8ODw0PDg4ODw0PDg4ODw4ODQ8ODw0PDQ8ODw0PDQ8ODw0PDQ8ODw0PDg4ODw0PDg4ODw0PKRANDykPDg8NDw0PKg8qDw0PDQ8ODw0PDQ0QDw0NDw8qDw0PDQ8ODw0PDQ8ODw0PKg8pDyoPKRApDyoNKw8ODwANBQAAAAA="
  ac_temp_21:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAREJEA8PDRANDw4OAAM7cjkPKg0PDw4PDQ0sDw0PDg4ODw0PKg0PDyoPKQ8ODykOKw8qDykPKg8NDw4PKQ4PDw0PDQ8ODw4ODQ8ODw0PDQ8ODw0PDg4ODw0PDg8NDw0NEA8pDw4ODg8ODioPKg8NDw0PDg8pDw4PKQ8ODykPDg8NDw4ODg8NDw0PDg8NDw0PDg8pDyoQKQ8pDyoPKg8NDw0PKg8qECgQKRAKEQ4PDQ8NDw4PDQ8NDw4PDQ8NDw4PDQ8ODw0PCxENEA0PDQ8NDw4PDQ8NEA0PDQ8NEA0PDg4NEA0PDQ8NDw4PDQ8NDw4PDQ8NDw4PDQ8NDw4PDQ8NDw4PKQ8ODykQDQ8NDw0PKhAoEA0PDQ8ODw0PDQ8NEA0PDQ8qDw0PDRANDw0PDQ8ODw0PKhAMDw0PDg8NDw0PDg8pDwANBQAAAAA="
  ac_temp_22:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEARILEQwPDRANDw0QAAM6czgPKhAMDw0QDQ8pEA0PDRAMEA0QKBANECgQKRAMECkQKRAoECkQKRAMEAwQKRAMEA0PDRAMEA0QDA8NEA0PDRAMEA0PDQ8NDw4PDRAMDw4PDQ8pEA0PDQ8ODioOKw4ODg4PDg4ODisOKg8ODioPDg4ODg4ODw4ODg4ODw4ODg4ODw4qDisOKw4qDisOKw4ODg4OKw4qDyoOKw4ODg8ODg4ODg4PDg4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODg8ODg4ODg8ODg4OKw4ODisODg4ODg8OKg4rDg4ODw4ODg4ODw4ODg4ODw4qDg8ODg4ODg8ODg4ODg8OKg4rDg4ODg8ODg4ODg4rDgANBQAAAAA="
  ac_temp_23:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODg4ODw4ODg4OAAM9cjkOKg8ODg4ODw4qDg4PDg4ODg8OKg4PDioOKw4ODisOKg8qDisOKg8ODg4OKw4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4rDg4ODg4PDioOKw4ODg8ODg4rDioOKw4ODisODg4PDg4ODg4PDg4ODg4PDg4ODg4rDisOKg4rDioPKg4PDg4OKg8qDisOKg8ODg4ODg8ODg4ODw0PDg4ODg4PDg4ODg4PDg4ODg4PDg4ODg4PDg4ODg4PDg4ODg4PDg4ODg4PDg4ODg4PDg4ODg4PDg4ODg4PDg4ODg4PDg4ODg4PDg4OKg4PDioODw4ODg4OKw4rDg4ODg4PDg4ODg4PDg4ODg4rDg4ODw4ODg4ODw4ODg4OKw4ODisODg4ODg8ODg4rDgANBQAAAAA="
  ac_temp_24:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODg4ODw4ODg4OAAM8czgOKw4ODg8ODg4rDg4ODg4PDg4OKw4ODisOKg4PDioOKw4rDioOKw4ODg8OKg4PDg4ODg4PDg4ODg4PDg4ODg4PDg4ODg4PDg4ODg4PDg4ODg4rDg4ODg4PDioOKw4ODg8ODg4ODg8ODg4rDioODw4ODg4ODw4ODg4ODw4ODg4ODw4qDisOKw4qDisOKw4ODg4OKw4rDioOKw4ODg8ODg4ODg8ODg4ODg4ODw4ODg4PDg4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4OKw4ODisODg4ODg8OKg4rDg4ODw4ODg4ODw4ODg4ODw4qDg8ODg4ODg8ODg4ODg8OKg4rDioODw4ODg4ODw4qDgANBQAAAAA="
  ac_temp_25:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODg4ODw4ODg4OAAM8cjkOKw4ODg8ODg4rDg4ODg4PDg4OKw4ODioPKg4PDioOKw4qDyoOKw4ODg8OKg4ODg8ODg4ODw4ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4rDg4ODg4PDioPKg4ODw4ODg4PDioODg4rDisODg4ODw4ODg4ODg8ODg4ODg8ODg4rDioOKw4rDioOKw4ODg8OKg4rDioOKw4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4OKw4ODisODg4ODg8OKg4rDg4ODw4ODg4ODw4ODg4ODw4qDg8ODg4ODg8ODg4ODg4OKw4rDg4OKw4ODg4ODw4qDgANBQAAAAA="
  ac_temp_26:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODg8ODg4ODg8OAAM8cjkOKw4ODg4ODw4qDg8ODg4ODw4OKg8ODioOKw4ODisOKw4qDyoOKw4ODg4PKg4ODw4ODg4ODw4ODg4ODw4ODg4ODg8ODg4ODg8ODg4ODw4ODg4rDg4ODw4ODioPKg4PDg4ODg4rDioPDg4qDisODg4PDg4ODg8ODg4ODg8ODg4ODg4rDisOKg4rDisOKg4PDg4OKw4qDisOKw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODg8ODg4ODg8ODg4OKw4ODisODg4ODg8OKg4rDg4ODw4ODg4ODw4ODg4ODw4qDg8ODg4ODg8ODg4ODg8OKg4PDioOKw4ODg8ODg4qDwANBQAAAAA="
  ac_temp_27:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODw4ODg4ODg8OAAM8cjkOKg8ODg4ODg4rDg4ODw4ODg4PKg4PDioOKw4ODisOKg8qDisOKg8ODg4OKw4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4qDw4ODg4PDioOKw4ODg8ODg4ODg4PKg4rDioPDg4ODg4PDg4ODg4ODw4ODg4ODw4qDisOKw4qDisOKw4ODg4OKw4qDyoOKw4ODg8ODg4ODg8ODg4ODg4PDg4ODg4PDg4ODg4PDg4ODg4PDg4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4OKw4ODisODg4ODw4OKg8qDg4ODw4ODg4ODw4ODg4ODw4qDg8ODg4ODg8ODg4ODg8OKg4rDioPKg4PDg4ODg4rDgANBQAAAAA="
  ac_temp_28:
    sequence:
          {% endif %}
        data:
          packet:
  ac_temp_29:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODg8ODg4ODg8OAAM8cjkOKg4PDg4ODg4rDg4ODw4ODg4OKw4ODisOKw4ODisOKg4rDisOKg4PDg4OKw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4qDg8ODg4ODisOKw4ODg4ODw4qDg8OKg4rDisODg4ODg8ODg4ODg8ODg4ODg8ODg4qDyoOKw4qDyoOKw4ODg8OKg4rDioOKw4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8NDw4ODg8ODg4ODg8OKg4ODisODg4PDg4OKw4qDg8ODg4ODg8ODg4ODg8ODg4rDg4ODg4PDg4ODg4ODw4OKg4PDg4ODg8qDg4ODw4qDgANBQAAAAA="
  ac_temp_30:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEARAODg4ODg4PDg4OAAM8cjkOKw4ODg8ODg4qDw4ODg4PDg4OKg8ODioPKg4PDioOKw4qDyoOKw4ODg8OKg4PDg4ODg4PDg4ODg4PDg4ODg4ODw4ODg4ODw4ODg4ODg8ODg4rDg4ODg4PDioOKw4ODg8ODg4rDioOKw4rDioODw4ODg4ODw4ODg4ODw4ODg4ODg4rDisOKg4rDisOKg4PDg4OKw4qDisOKw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODg4PDg4ODg8ODg4ODg8ODg4ODg4PDg4ODg4PDg4ODg4PDg4ODg4PDg4ODg4PDg4OKg8ODioPDg4ODg4OKw4rDg4ODg4PDg4ODg4PDg4ODg4rDg4ODw4ODg4ODw4ODg4OKw4ODisODg4rDg4ODg8qDgANBQAAAAA="
  ac_temp_31:
    sequence:
          {% endif %}
        data:
          packet:
  ac_temp_32:
    sequence:
          {% endif %}
        data:
          packet:
            - "JgBEAQ8ODg8ODg4ODw4OAAM8cjkOKg8ODg4ODg8qDg4PDg4ODg8OKg4PDioOKw4ODisOKg8qDisOKg8ODg4OKw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4ODg4ODw4qDg8ODg4ODisOKw4ODg4ODw4ODg4ODw4ODQ8OKw4ODg8ODg4ODg8ODg4ODg4PDg4qDyoOKw4qDyoOKw4ODg4OKw4rDioPKg4ODw4ODg4ODg8ODg4ODg8ODg4ODRAODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg8ODg4ODg4PDg0PDg4ODw4ODg4OKw4ODisODg4PDg4OKw4qDg8ODg4ODg8ODg4ODg8ODg4qDw4ODg4ODw4ODg4ODg8OKg4rDisODg4rDg4ODg4rDgANBQAAAAA="
wqqs 手机认证
活跃会员
发表于 2018-6-7 16:29:19 | 显示全部楼层
自动化不要写在package里面,否则会报错
发表于 2018-6-7 17:02:17 | 显示全部楼层
自动化可以写在里面的呀,但要把配置目录下的automations.yaml里的内容(默认是个方括号)删掉。
wqqs 手机认证
活跃会员
发表于 2018-6-7 17:09:04 | 显示全部楼层
Jones 发表于 2018-6-7 17:02
自动化可以写在里面的呀,但要把配置目录下的automations.yaml里的内容(默认是个方括号)删掉。 ...
原来如此啊
 楼主| 发表于 2018-6-7 17:45:34 来自手机 | 显示全部楼层
谢谢大神
发表于 2018-6-7 17:54:03 | 显示全部楼层
是的,这个坑曾经坑了我一个下午和一个晚上!
论坛风云人物
发表于 2018-6-7 18:31:49 | 显示全部楼层
我automations和packages一起用可以呀
活跃会员教程狂人
发表于 2018-6-7 18:55:24 | 显示全部楼层
如果还是报错,你把:
    sensors:
      temp_show:
        entity_id:
      volume_show:
        entity_id:
      timing_show:
        entity_id:
里面的
        entity_id:
         - XXXX
这项全都删掉...当初不记得是哪个版本升级死活用不了,后来看了半天日志,才发现这个原因(不知道现在版本加这个会不会影响,仅供参考。)。
所有过往,皆为序章。
wqqs 手机认证
活跃会员
发表于 2018-6-7 19:30:49 | 显示全部楼层
看看你的配置目录下的automations.yaml文件里面是不是空的,空的话删掉试试
 楼主| 发表于 2018-6-7 19:56:40 | 显示全部楼层
空的还是报错
配置无效
Invalid config for [automation]: required key not provided @ data['action']. Got None
required key not provided @ data['trigger']. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/automation/
删除的话也报错
配置无效
Error loading /config/configuration.yaml: Config file not found: /config/automations.yaml
GMT+8, 2025-12-29 19:00 , Processed in 0.089689 second(s), 8 queries , MemCached On.
