查看: 12870|回复: 8
[求助] 小米風扇設置求助?
发表于 2017-6-24 18:38:36 来自手机 | 显示全部楼层 |阅读模式
在putty找不到米家風扇token,不知出了什麼問題。已經嘗試過跟本論壇教程,或GitHub.com教學,但都不成功。求大神出手相救~~
https://github.com/homeassistantchina/custom_compo
活跃会员
发表于 2017-6-24 18:59:41 | 显示全部楼层
miio discover 就可以了,没有前面的python
 楼主| 发表于 2017-6-24 19:19:02 | 显示全部楼层
miio discover 都是不可以。。。。
pi@raspberrypi:~ $ miio discover
-bash: miio: command not found
pi@raspberrypi:~ $
wqqs 手机认证
活跃会员
发表于 2017-6-24 19:25:50 | 显示全部楼层
没有小米风扇,帮顶
 楼主| 发表于 2017-6-24 19:30:48 | 显示全部楼层
wqqs 发表于 2017-6-24 19:25
没有小米风扇,帮顶
謝CHING帮顶~~
活跃会员
发表于 2017-6-25 15:35:14 | 显示全部楼层
Install python-miio lib. pip3 install python-miio.
Make sure your fan is powered on and connected to the same local network with your PC.
Get your fan's IP addr in MiJia app. Run miio discover to get fans token.
 楼主| 发表于 2017-6-25 22:48:03 | 显示全部楼层
已經找到TOKEN,但出以下ERROR, 求大神幫忙..謝
2017-06-25 22:44:36 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=17 from 2017-06-25 14:08:06.847577)
2017-06-25 22:44:39 ERROR (MainThread) [homeassistant.components.fan] Error while setting up platform smart_mi_fan
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 161, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
  File "/usr/lib/python3.4/asyncio/tasks.py", line 372, in wait_for
    return fut.result()
  File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
    raise self._exception
  File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
  File "/home/homeassistant/.homeassistant/custom_components/fan/smart_mi_fan.py", line 75, in setup_platform
    SmartMiFan(hass, name, host, token),
  File "/home/homeassistant/.homeassistant/custom_components/fan/smart_mi_fan.py", line 144, in __init__
    self._state_attrs = self.fan_get_prop()
  File "/home/homeassistant/.homeassistant/custom_components/fan/smart_mi_fan.py", line 377, in fan_get_prop
    prop = self.fan.send("get_prop", ["temp_dec","humidity","angle","speed","poweroff_time","power","ac_power","battery","angle_enable","speed_level","natural_level","child_lock","buzzer","led_b"])
  File "/home/homeassistant/.homeassistant/custom_components/fan/smart_mi_fan.py", line 248, in fan
    self._fan = Vacuum(self.host, self.token)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/mirobo/vacuum.py", line 20, in __init__
    self.token = bytes.fromhex(token)
ValueError: non-hexadecimal number found in fromhex() arg at position 0
发表于 2017-7-27 10:37:13 | 显示全部楼层
小米风扇的价格还是高了点
卓越贡献
发表于 2017-7-27 10:46:08 | 显示全部楼层
2017-06-25 22:44:36 WARNING (Recorder) [homeassistant. ...
错误提示token不是十六进制,看看是不是写错了?
GMT+8, 2025-12-25 17:38 , Processed in 0.540138 second(s), 10 queries , MemCached On.
