查看: 6766|回复: 4
[求助] 关于京东万象他的天气信息
发表于 2018-6-6 15:39:24 | 显示全部楼层 |阅读模式
想增加风速等其他的信息应该怎么弄
根据已有的hachina.py改了改,没有生效而且整个hachina.py都失效了
红字的后来加的,帮忙看看问题在哪
import json
from urllib import request, parse
import logging
from datetime import timedelta
import voluptuous as vol
from homeassistant.components.sensor import PLATFORM_SCHEMA
from homeassistant.const import (
    ATTR_ATTRIBUTION, ATTR_FRIENDLY_NAME, TEMP_CELSIUS)
from homeassistant.helpers.entity import Entity
import homeassistant.helpers.config_validation as cv
from homeassistant.helpers.event import track_time_interval
import homeassistant.util.dt as dt_util
_LOGGER = logging.getLogger(__name__)
TIME_BETWEEN_UPDATES = timedelta(seconds=600)
# 配置文件中三个配置项的名称
CONF_OPTIONS = "options"
CONF_CITY = "city"
CONF_APPKEY = "appkey"
# 定义三个可选项:温度、湿度、PM2.5
# 格式:配置项名称:[OBJECT_ID, friendly_name, icon, 单位]
OPTIONS = {
    "temprature": [
        "hachina_temperature", "室外温度", "mdi:thermometer", TEMP_CELSIUS],
    "humidity": ["hachina_humidity", "室外湿度", "mdi:water-percent", "%"],
    "pm25": ["hachina_pm25", "PM2.5", "mdi:walk", "μg/m3"],
"speed": ["hachina_speed", "speed", "mdi:walk", "m/s"],
ATTR_UPDATE_TIME = "更新时间"
ATTRIBUTION = "来自京东万象的天气数据"
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
    vol.Required(CONF_CITY): cv.string,
    vol.Required(CONF_APPKEY): cv.string,
    # 配置项的options是一个列表,列表内容只能是OPTIONS中定义的三个可选项
    vol.Required(CONF_OPTIONS,
                 default=[]): vol.All(cv.ensure_list, [vol.In(OPTIONS)]),
def setup_platform(hass, config, add_devices, discovery_info=None):
    """根据配置文件,setup_platform函数会自动被系统调用."""
    _LOGGER.info("setup platform sensor.hachina...")
    city = config.get(CONF_CITY)
    appkey = config.get(CONF_APPKEY)
    # 定义一个新的数据对象,用于从京东万象获取并存储天气数据。Sensor的实际数据从这个对象中获得。
    data = WeatherData(hass, city, appkey)
    # 根据配置文件options中的内容,添加若干个设备
    dev = []
    for option in config[CONF_OPTIONS]:
        dev.append(HAChinaWeatherSensor(data, option))
    add_devices(dev, True)
class HAChinaWeatherSensor(Entity):
    """定义一个温度传感器的类,继承自HomeAssistant的Entity类."""
    def __init__(self, data, option):
        """初始化."""
        self._data = data
        self._object_id = OPTIONS[option][0]
        self._friendly_name = OPTIONS[option][1]
        self._icon = OPTIONS[option][2]
        self._unit_of_measurement = OPTIONS[option][3]
        self._type = option
        self._state = None
        self._updatetime = None
    @property
    def name(self):
        """返回实体的名字."""
        return self._object_id
    @property
    def registry_name(self):
        """返回实体的friendly_name属性."""
        return self._friendly_name
    @property
    def state(self):
        """返回当前的状态."""
        return self._state
    @property
    def icon(self):
        """返回icon属性."""
        return self._icon
    @property
    def unit_of_measurement(self):
        """返回unit_of_measuremeng属性."""
        return self._unit_of_measurement
    @property
    def device_state_attributes(self):
        """设置其它一些属性值."""
        if self._state is not None:
            return {
                ATTR_ATTRIBUTION: ATTRIBUTION,
                ATTR_UPDATE_TIME: self._updatetime
    def update(self):
        """更新函数,在sensor组件下系统会定时自动调用(时间间隔在配置文件中可以调整,缺省为30秒)."""
        # update只是从WeatherData中获得数据,数据由WeatherData维护。
        self._updatetime = self._data.updatetime
        if self._type == "temprature":
            self._state = self._data.temprature
        elif self._type == "humidity":
            self._state = self._data.humidity
        elif self._type == "pm25":
            self._state = self._data.pm25
        elif self._type == "speed":
            self._state = self._data.speed
class WeatherData(object):
    """天气相关的数据,存储在这个类中."""
    def __init__(self, hass, city, appkey):
        """初始化函数."""
        self._url = "https://way.jd.com/he/freeweather"
        self._params = {"city": city,
                        "appkey": appkey}
        self._temprature = None
        self._humidity = None
        self._pm25 = None
        self._speed = None
        self.update(dt_util.now())
        # 每隔TIME_BETWEEN_UPDATES,调用一次update(),从京东万象获取数据
        track_time_interval(hass, self.update, TIME_BETWEEN_UPDATES)
    @property
    def temprature(self):
        """温度."""
        return self._temprature
    @property
    def humidity(self):
        """湿度."""
        return self._humidity
    @property
    def pm25(self):
        """pm2.5."""
        return self._pm25
   @property
    def speed(self):
        """风速."""
        return self._speed
    @property
    def updatetime(self):
        """更新时间."""
        return self._updatetime
    def update(self, now):
        """从远程更新信息."""
        _LOGGER.info("Update from JingdongWangxiang's OpenAPI...")
        # 通过HTTP访问,获取需要的信息
        infomation_file = request.urlopen(
            self._url, parse.urlencode(self._params).encode('utf-8'))
        content = infomation_file.read()
        result = json.loads(content.decode('utf-8'))
        if result is None:
            _LOGGER.error("Request api Error")
            return
        elif result["code"] != "10000":
            _LOGGER.error("Error API return, code=%s, msg=%s",
                          result["code"],
                          result["msg"])
            return
        # 根据http返回的结果,更新数据
        all_result = result["result"]["HeWeather5"][0]
        self._temprature = all_result["now"]["tmp"]
        self._humidity = all_result["now"]["hum"]
        self._speed = all_result["now"]["spd"]
        self._pm25 = all_result["aqi"]["city"]["pm25"]
        self._updatetime = all_result["basic"]["update"]["loc"]
发表于 2018-6-6 16:18:52 | 显示全部楼层
回帖奖励 +1 金钱
贴下log看看
发表于 2018-11-6 00:33:03 | 显示全部楼层
读取京东万象云服务数据,修改hachina.py文件多增加一个传感器不成功https://www.hachina.io/dwqa-question/9812.html
发表于 2018-11-6 00:34:07 | 显示全部楼层
配置无效Invalid config for [sensor.hachina]: value is not allowed @ data['options'][0]. Got 'coldrisk'. (See ?, line ?). Please check the docs at https://home-assis
发表于 2018-11-6 22:12:09 | 显示全部楼层
经过重启,问题解决。
GMT+8, 2025-12-25 10:18 , Processed in 0.076984 second(s), 16 queries , MemCached On.
