楼主: c1pher_小愚
萤石的取图组件,不依赖ffmpeg,支持布防撤防
发表于 2018-7-28 09:11:18 | 显示全部楼层
棒棒的
发表于 2018-8-2 14:17:40 | 显示全部楼层
可以使用,但日志里不定时的报错,看着不舒服。
★Raspberry + Raspbian + Home Assistant v0.1
★树莓派 + Raspbian系统 + HomeAssistant
https://github.com/huangqian8/homeassistant
 楼主| 发表于 2018-8-2 16:37:47 | 显示全部楼层
加了错误处理 再试试看
发表于 2018-8-3 10:36:21 | 显示全部楼层
25989406 发表于 2018-8-2 16:37
加了错误处理 再试试看
组件都不显示了。自己找了一下原因,应该是组件里的代码有问题,漏了几个“self.”
 楼主| 发表于 2018-8-3 14:31:07 | 显示全部楼层
好,昨天改的。。 没测试我再改下
 楼主| 发表于 2018-8-3 15:28:09 | 显示全部楼层
空的话帮我测测看,改好了
发表于 2018-8-10 23:30:48 | 显示全部楼层
学习一下子,哈哈
活跃会员教程狂人
发表于 2019-4-12 15:18:33 | 显示全部楼层
大佬请教下,萤石的录像机该怎么设置“id”,页面显示的id是NVR的,摄像头是按照通道显示的,有空的话帮忙解答一下,多谢。
所有过往,皆为序章。
发表于 2019-4-24 21:41:56 | 显示全部楼层
[homeassistant.helpers.entity] Updating state for camera.name (<class 'custom_components.ezviz.camera.EzvizCamera'>) took 0.810 seconds.
以上提示请教楼主,谢谢!
发表于 2019-4-25 23:17:17 来自手机 | 显示全部楼层
2019-04-24 14:25:27 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for camera.name (<class 'custom_components.ezviz.camera.EzvizCamera'>) took 0.407 seconds. Please report platform to the developers at https://goo.gl/Nvioub 2019-04-24 15:11:28 ERROR (MainThread) [homeassistant.components.updater] Got unexpected response: None 2019-04-24 18:11:40 ERROR (SyncWorker_5) [xiaomi_gateway] Got error element in data {"error":"Invalid key"} 2019-04-25 05:01:03 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error in data received Traceback (most recent call last):   File "/usr/local/lib/python3.7/asyncio/sslproto.py", line 526, in data_received     ssldata, appdata = self._sslpipe.feed_ssldata(data)   File "/usr/local/lib/python3.7/asyncio/sslproto.py", line 207, in feed_ssldata     self._sslobj.unwrap()   File "/usr/local/lib/python3.7/ssl.py", line 767, in unwrap     return self._sslobj.shutdown() ssl.SSLError: [SSL: DECRYPTION_FAILED_OR_BAD_RECORD_MAC] decryption failed or bad record mac (_ssl.c:2609) 2019-04-25 10:45:41 ERROR (MainThread) [homeassistant.core] Error doing job: SSL handshake failed Traceback (most recent call last):   File "/usr/local/lib/python3.7/asyncio/sslproto.py", line 625, in _on_handshake_complete     raise handshake_exc   File "/usr/local/lib/python3.7/asyncio/sslproto.py", line 189, in feed_ssldata     self._sslobj.do_handshake()   File "/usr/local/lib/python3.7/ssl.py", line 763, in do_handshake     self._sslobj.do_handshake() ssl.SSLError: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1056) 2019-04-25 10:45:41 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error in data received Traceback (most recent call last):   File "/usr/local/lib/python3.7/asyncio/sslproto.py", line 526, in data_received     ssldata, appdata = self._sslpipe.feed_ssldata(data)   File "/usr/local/lib/python3.7/asyncio/sslproto.py", line 189, in feed_ssldata     self._sslobj.do_handshake()   File "/usr/local/lib/python3.7/ssl.py", line 763, in do_handshake     self._sslobj.do_handshake() ssl.SSLError: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1056) 2019-04-25 15:11:32 ERROR (MainThread) [homeassistant.components.updater] Could not contact Home Assistant Update to check for updates
GMT+8, 2026-1-31 12:30 , Processed in 0.123849 second(s), 15 queries , MemCached On.
