楼主: milomoon
[快速入门] 【基础教程】HomeAssistant的设备ID及汉化!
发表于 2018-10-30 15:49:15 | 显示全部楼层
waitshare 发表于 2018-10-30 14:43
你添加在哪个地方?
看图,就这样子编辑后就登陆不了,
发表于 2018-10-30 16:22:23 | 显示全部楼层
liqun5417 发表于 2018-10-30 15:49
看图,就这样子编辑后就登陆不了,
目录下有个log文件,你看看你们报错提示什么
发表于 2018-10-30 16:26:41 | 显示全部楼层
大神帮我看看
发表于 2018-10-30 16:29:51 | 显示全部楼层
把斐讯设备的注释掉看看,然后再启动
发表于 2018-10-30 16:38:13 | 显示全部楼层
waitshare 发表于 2018-10-30 16:29
把斐讯设备的注释掉看看,然后再启动
这句不懂了,里面没有斐讯的字眼啊
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: 0
  longitude: 0
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 0
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: [url]http://en.wikipedia.org/wiki/List_of_tz_database_time_zones[/url]
  time_zone: UTC
  # Customization file
  customize: !include customize.yaml
# Show links to resources in log and frontend
# introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
   api_password: !secret http_password
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# [url]https://home-assistant.io/blog/2016/10/25/explaining-the-updater/[/url]
updater:
  # Optional, allows Home Assistant developers to focus on popular components.
  # include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
# sun:
# Weather prediction
  - platform: yr
# Text to speech
tts:
  - platform: google
# Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
homeassistant:
发表于 2018-10-30 16:50:26 | 显示全部楼层
liqun5417 发表于 2018-10-30 16:38
这句不懂了,里面没有斐讯的字眼啊
[code]homeassistant:
  # Name of the loca ...
是斐讯的插座报错,/homeassistant/custom_components/sensor下有没有放入py格式的脚本(斐讯插座的)
发表于 2018-10-30 16:53:34 | 显示全部楼层
waitshare 发表于 2018-10-30 16:50
是斐讯的插座报错,/homeassistant/custom_components/sensor下有没有放入py格式的脚本(斐讯插座的) ...
有,插座可以正常控制,插座的放在switch文件夹,M1的放在sensor文件夹
发表于 2018-10-30 16:59:42 | 显示全部楼层
那你把M1注释掉看看
发表于 2018-10-30 17:01:40 | 显示全部楼层
waitshare 发表于 2018-10-30 16:59
那你把M1注释掉看看
你把log文件贴上来,截图我不好复制给你
发表于 2018-10-30 17:03:06 | 显示全部楼层
那你把M1注释掉看看
怎么操作,把M1的配置删掉吗
GMT+8, 2026-1-14 15:39 , Processed in 1.688396 second(s), 7 queries , MemCached On.
