查看: 3585|回复: 2
[求助] hass 0.68.1 更新到0.69.1 智能插座增强版 空气清净器無法接入
发表于 2018-5-29 13:12:30 | 显示全部楼层 |阅读模式
各位前辈,  原本hass0.68.1 中的"智能插座增强版" "小米空氣清淨器" "小米萬能遙控器" 在此版本可正常使用~
但是更新到hass0.69.1 及 hass0.70.0 就无法接入"智能插座增强版" "小米空氣清淨器" "小米萬能遙控器"~
其中configuration.yaml中的这些设备设定都没有改过~且miio版本都是0.39.0版本~
请问各位前辈 是否有遇到这问题~或者有解决方法~
2018-05-29 14:24:55 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: 'None' has no attribute 'attributes'
2018-05-29 14:25:00 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: 'None' has no attribute 'attributes'
2018-05-29 14:25:05 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: 'None' has no attribute 'attributes'
2018-05-29 14:25:10 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: 'None' has no attribute 'attributes'
2018-05-29 14:25:15 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: 'None' has no attribute 'attributes'
2018-05-29 14:25:20 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: 'None' has no attribute 'attributes'
2018-05-29 14:25:25 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: 'None' has no attribute 'attributes'
2018-05-29 14:25:30 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: 'None' has no attribute 'attributes'
2018-05-29 14:25:32 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.weather_home_aqi is taking over 10 seconds
2018-05-29 14:25:34 ERROR (Thread-8) [homeassistant.components.device_tracker.xiaomi] Connection to the router timed out at URL http://192.168.31.1/cgi-bin/luci ... misystem/devicelist
  File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/connectionpool.py", line 387, in _make_request
    six.raise_from(e, None)
  File "<string>", line 2, in raise_from
  File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/connectionpool.py", line 383, in _make_request
    httplib_response = conn.getresponse()
  File "/usr/lib/python3.5/http/client.py", line 1198, in getresponse
    response.begin()
  File "/usr/lib/python3.5/http/client.py", line 297, in begin
    version, status, reason = self._read_status()
  File "/usr/lib/python3.5/http/client.py", line 258, in _read_status
    line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
  File "/usr/lib/python3.5/socket.py", line 576, in readinto
    return self._sock.recv_into(b)
socket.timeout: timed out
  File "/srv/homeassistant/lib/python3.5/site-packages/requests/adapters.py", line 440, in send
    timeout=timeout
  File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/connectionpool.py", line 639, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/util/retry.py", line 357, in increment
    raise six.reraise(type(error), error, _stacktrace)
  File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/packages/six.py", line 686, in reraise
    raise value
  File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/connectionpool.py", line 601, in urlopen
    chunked=chunked)
  File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/connectionpool.py", line 389, in _make_request
    self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
  File "/srv/homeassistant/lib/python3.5/site-packages/urllib3/connectionpool.py", line 309, in _raise_timeout
    raise ReadTimeoutError(self, url, "Read timed out. (read timeout=%s)" % timeout_value)
urllib3.exceptions.ReadTimeoutError: HTTPConnectionPool(host='192.168.31.1', port=80): Read timed out. (read timeout=5)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/xiaomi.py", line 113, in _retrieve_list
    res = requests.get(url, timeout=5, **kwargs)
  File "/srv/homeassistant/lib/python3.5/site-packages/requests/api.py", line 72, in get
    return request('get', url, params=params, **kwargs)
  File "/srv/homeassistant/lib/python3.5/site-packages/requests/api.py", line 58, in request
    return session.request(method=method, url=url, **kwargs)
  File "/srv/homeassistant/lib/python3.5/site-packages/requests/sessions.py", line 508, in request
    resp = self.send(prep, **send_kwargs)
  File "/srv/homeassistant/lib/python3.5/site-packages/requests/sessions.py", line 618, in send
    r = adapter.send(request, **kwargs)
  File "/srv/homeassistant/lib/python3.5/site-packages/requests/adapters.py", line 521, in send
    raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPConnectionPool(host='192.168.31.1', port=80): Read timed out. (read timeout=5)
2018-05-29 14:25:35 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: 'None' has no attribute 'attributes'
2018-05-29 14:25:35 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.latest_homeassistant is taking over 10 seconds
2018-05-29 14:25:40 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: 'None' has no attribute 'attributes'
2018-05-29 14:25:42 WARNING (MainThread) [homeassistant.core] Unable to find service homekit/start
2018-05-29 14:25:45 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: 'None' has no attribute 'attributes'
2018-05-29 14:25:50 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: 'None' has no attribute 'attributes'
2018-05-29 14:25:55 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: 'None' has no attribute 'attributes'
2018-05-29 14:26:00 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: 'None' has no attribute 'attributes'
2018-05-29 14:26:05 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: 'None' has no attribute 'attributes'
2018-05-29 14:26:10 ERROR (MainThread) [homeassistant.helpers.service] Error rendering data template: UndefinedError: 'None' has no attribute 'attributes'
发表于 2018-5-29 13:23:45 | 显示全部楼层
  1. 最好提供日志。
  2. 上 [python-miio]https://github.com/rytilahti/python-miio 看看有没有更新修复的commit,如果有可以自行覆盖,或等homeassistant 合并PR再更新。
发表于 2018-5-29 14:25:53 | 显示全部楼层
我用docker home-assistant
從0.68.1 --> 0.69.1 --> 0.70.0 都沒有任何問題
GMT+8, 2025-12-25 01:48 , Processed in 0.196447 second(s), 11 queries , MemCached On.
