楼主: ruohan.chen
HA支持中弘中央空调控制器插件
发表于 2021-6-16 06:54:54 来自手机 | 显示全部楼层
支持,太牛了
发表于 2021-8-30 22:58:21 | 显示全部楼层
lostcup 发表于 2019-7-20 13:04
最近重新装Hassos,用新的preview 3.3版,但是遇到了报错,请问是怎么回事?谢谢!
2019-07-20 13:00:33 E ...
我遇到同样的报错,你的解决了么?
发表于 2021-9-17 23:40:57 | 显示全部楼层
好东西啊,积分要求太高了
发表于 2021-9-27 17:21:20 | 显示全部楼层
中弘的网关不就是1000多么
发表于 2021-10-28 21:10:21 | 显示全部楼层
感谢楼主分享
发表于 2021-12-4 21:43:43 | 显示全部楼层
6666666666666666666
发表于 2023-8-24 15:31:04 | 显示全部楼层
我这也不工作了,直接报错了。
Logger: homeassistant.loader
Source: components/zhong_hong/climate.py:8
First occurred: 15:08:27 (6 occurrences)
Last logged: 15:26:07
Unexpected exception importing platform homeassistant.components.zhong_hong.climate
  File "/usr/src/homeassistant/homeassistant/loader.py", line 833, in get_platform
    cache[full_name] = self._import_platform(platform_name)
  File "/usr/src/homeassistant/homeassistant/loader.py", line 850, in _import_platform
    return importlib.import_module(f"{self.pkg_path}.{platform_name}")
  File "/usr/local/lib/python3.10/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1050, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1027, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1006, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 688, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 883, in exec_module
  File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
  File "/usr/src/homeassistant/homeassistant/components/zhong_hong/climate.py", line 8, in <module>
    from zhong_hong_hvac.hub import ZhongHongGateway
  File "/usr/local/lib/python3.10/site-packages/zhong_hong_hvac/hub.py", line 12, in <module>
    from . import helper, protocol
  File "/usr/local/lib/python3.10/site-packages/zhong_hong_hvac/helper.py", line 6, in <module>
    from .protocol import (AcData, AcOnline, AcStatus, ChecksumError, CtlStatus,
  File "/usr/local/lib/python3.10/site-packages/zhong_hong_hvac/protocol.py", line 218, in <module>
    class AcData(collections.Iterable):
AttributeError: module 'collections' has no attribute 'Iterable'
发表于 2023-9-29 06:06:05 | 显示全部楼层
666666楼主牛皮
发表于 2024-6-9 15:50:27 | 显示全部楼层
还是那么贵
发表于 2025-2-3 16:12:25 | 显示全部楼层
这个可以好好研究一下
GMT+8, 2026-2-6 14:06 , Processed in 0.058323 second(s), 11 queries , MemCached On.
