查看: 11776|回复: 5
[已解决] 小米 青米插线板无法接入HA
发表于 2018-5-19 11:38:58 | 显示全部楼层 |阅读模式
错误信息如下:
2018-05-19 11:24:44 ERROR (SyncWorker_6) [miio.protocol] unable to parse json '{"result":[
"on",50,58,"normal",6,,],"id":102}': Expecting value: line 1 column 34 (char 33)
2018-05-19 11:24:44 ERROR (MainThread) [homeassistant.components.switch] xiaomi_miio: Erro
r on device update!
  File "/usr/local/lib/python3.6/site-packages/miio/device.py", line 258, in send
    data, addr = s.recvfrom(1024)
socket.timeout: timed out
  File "/usr/src/app/homeassistant/helpers/entity_platform.py", line 244, in _async_add_en
tity
    await entity.async_device_update(warning=False)
  File "/usr/src/app/homeassistant/helpers/entity.py", line 325, in async_device_update
    yield from self.async_update()
  File "/usr/src/app/homeassistant/components/switch/xiaomi_miio.py", line 370, in async_u
pdate
    state = await self.hass.async_add_job(self._plug.status)
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/local/lib/python3.6/site-packages/miio/powerstrip.py", line 107, in status
    properties
  File "/usr/local/lib/python3.6/site-packages/miio/device.py", line 287, in send
    return self.send(command, parameters, retry_count - 1)
  File "/usr/local/lib/python3.6/site-packages/miio/device.py", line 264, in send
    self.__id = m.data.value["id"]
TypeError: 'NoneType' object is not subscriptable
 楼主| 发表于 2018-5-19 15:00:15 | 显示全部楼层
已解决!
发表于 2018-6-15 22:01:15 | 显示全部楼层
请问怎么解决的???谢谢!
 楼主| 发表于 2018-6-16 23:15:31 | 显示全部楼层
josurun 发表于 2018-6-15 22:01
请问怎么解决的???谢谢!
将qmi.powerstrip.v1 修改为 chuangmi.plug.m1 即可
发表于 2018-9-6 09:57:04 | 显示全部楼层
可以发一下配置格式吗?
发表于 2021-3-2 13:52:39 | 显示全部楼层
请问用什么插件接入的
GMT+8, 2025-12-22 21:17 , Processed in 0.193505 second(s), 12 queries , MemCached On.
