查看: 9618|回复: 7
[技术探讨] 如何将Badge传感器移动到Card卡片
aaa
34
发表于 2018-5-14 15:26:05 | 显示全部楼层 |阅读模式
homeassistant:
  customize:
    sensor.latest_homeassistant:
      friendly_name: 最新版本
      homebridge_hidden: true
    sensor.cpu_temperature:
      friendly_name: 系统温度
      icon: mdi:temperature-celsius
    sensor.disk_use_:
      friendly_name: 已使用
    sensor.disk_free_:
      friendly_name: 剩余
    sensor.network_out_wlan0:
      friendly_name: 发送字节
    sensor.network_in_wlan0:
      friendly_name: 接收字节
    sensor.ipv4_address_wlan0:
      friendly_name: IP地址
    sensor.last_boot:
      friendly_name: 上次重启
    sensor.since_last_boot_templated:
      friendly_name: 已启动
    sensor.memory_use_percent:
      friendly_name: RAM使用率
    sensor.cpu_speed:
      friendly_name: CPU频率
    sensor.processor_use:
      friendly_name: CPU使用频率
    sensor.uptime:
      friendly_name: 系统运行
  - platform: systemmonitor
    resources:
    - type: memory_use_percent
    - type: processor_use
    - type: disk_use
      arg: /
    - type: disk_free
      arg: /
    - type: disk_use_percent
    - type: network_in
      arg: wlan0
    - type: network_out
      arg: wlan0
    - type: ipv4_address
      arg: wlan0
    - type: last_boot
      #arg: octave-cli
    - type: since_last_boot
    #  arg: octave-cli
#HomeAssistant运行时间
  - platform: uptime
    unit_of_measurement: hours
  - platform: command_line
    name: CPU Temperature
    command: "cat /sys/class/thermal/thermal_zone0/temp"
    # If errors occur, remove degree symbol below
    unit_of_measurement: "°C"
    value_template: '{{ value | multiply(0.001) | round(2)}}'
    #value_template: '{{ value | round(2) }}'
    scan_interval: 30
    command: python3 -c "import requests; print(requests.get('https://pypi.python.org/pypi/homeassistant/json').json()['info']['version'])"
  - platform: template
    sensors:
        value_template: >-
          {% if states.sensor.since_last_boot.state.count("day") > 0 %}
          {{states.sensor.since_last_boot.state.split(",") [0] +
          states.sensor.since_last_boot.state.split(",") [1].split(":") [0] +
          " hours, " +
          states.sensor.since_last_boot.state.split(",") [1].split(":") [1] +
          " minutes" }}
          {% else %}
          {{ "0 days, " +
          states.sensor.since_last_boot.state.split(",") [0].split(":") [0] +
          " hours, " +
          states.sensor.since_last_boot.state.split(",") [0].split(":") [1] +
          " minutes" }}
          {% endif %}
group:
  system:
    view: no
    entities:
      - sensor.cpu_temperature
      - sensor.last_boot
      - sensor.since_last_boot_templated
      - sensor.uptime
      - senso.processor_use
      - sensor.memory_use_percent
      - sensor.disk_use_
      - sensor.disk_free_
      - sensor.disk_use_percent
      - sensor.network_in_wlan0
      - sensor.network_out_wlan0
      - sensor.ipv4_address_wlan0
树莓派系统监视器 中的 CPU使用率 移动到下方卡片中,同时隐藏上方Badge里的同一个项目
感谢指导
发表于 2018-5-14 15:28:35 | 显示全部楼层
哦 先做个沙发然后在看
活跃会员
发表于 2018-5-14 15:30:13 | 显示全部楼层
加到group里,上面就消失了
发表于 2018-5-14 15:46:41 | 显示全部楼层
要用customui。
aaa
34
 楼主| 发表于 2018-5-14 17:08:57 | 显示全部楼层
aktifin 发表于 2018-5-14 15:30
加到group里,上面就消失了
group:
  system:
    view: no
    entities:
      - sensor.cpu_speed
我尝试这样修改一下,但是没有效果
aaa
34
 楼主| 发表于 2018-5-14 17:45:06 | 显示全部楼层
应该不用这么复杂吧
活跃会员
发表于 2018-5-14 19:29:42 | 显示全部楼层
这个写错了
- sensor.processor_use
aaa
34
 楼主| 发表于 2018-5-15 10:42:09 | 显示全部楼层
这个写错了
老师,眼神真的好使,解决了,感谢指导!
GMT+8, 2026-1-3 10:59 , Processed in 0.554781 second(s), 11 queries , MemCached On.
