查看: 20500|回复: 13
[技术探讨] 【六神分享】HA0.69+博联broadlink MP1(或鸿雁)插件修复
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-5-12 14:46:59 | 显示全部楼层 |阅读模式
2018-05-12 14:42:07 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform broadlink_mp1
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 129, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=hass.loop)
  File "/usr/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
    return fut.result()
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/config/custom_components/switch/broadlink_mp1.py", line 74, in setup_platform
    persistent_notification = loader.get_component('persistent_notification')
TypeError: get_component() missing 1 required positional argument: 'comp_or_platform'
请看二楼解决办法及附件
发表于 2018-5-12 15:56:51 | 显示全部楼层
jyz_0501 发表于 2018-5-12 15:05
哈哈  给解决掉错误就告诉你
估计升级到开发板就修好了这个BUG
https://github.com/home-assistan ... 581bb578cf88dd01693
下载这个文件 https://raw.githubusercontent.co ... assistant/loader.py
放到 /usr/lib/python3.6/site-packages/homeassistant/ 下面(记得备份原来的文件。)试试行不行?乱猜的哈哈
囧,不说是自改版,我还以为是官方版呢
不懂python,但是看起来是知道 0.69.0 loader.get_component 是加了一个输入参数。而自建插件缺了个参数。
论坛的broadlink_mp1.py
    ip_addr = config.get(CONF_HOST)
    friendly_name = config.get(CONF_FRIENDLY_NAME)
    alias_names = config.get(CONF_ALIAS)
    mac_addr = binascii.unhexlify(
        config.get(CONF_MAC).encode().replace(b':', b''))
    switch_type = config.get(CONF_TYPE)
    persistent_notification = loader.get_component('persistent_notification') """← 这里缺了个参数。"""
而 homeassistant test 里面的标准写法
    def setUp(self):
        """Setup things to be run when tests are started."""
        self.hass = get_test_home_assistant()
        platform = loader.get_component(self.hass, 'switch.test')  """←这里应该要多了个 self.hass"""
        platform.init()
        # Switch 1 is ON, switch 2 is OFF
        self.switch_1, self.switch_2, self.switch_3 = \
            platform.DEVICES
至于 get_test_home_assistant() 这个方法是在这个py文件里面 https://github.com/home-assistant/home-assistant/blob/dev/tests/common.py
这个到底干嘛不太明白。
萌新蒙的解决方法
在论坛的 broadlink_mp1.py 74 行从
改成
    persistent_notification = loader.get_component(hass,'persistent_notification')
我懵的,不知道对不对啊。(经过测试是对的)
下面附件是改好的文件
broadlink_mp1_for_0.69.0.zip
2.2 KB, 下载次数: 262
参与人数 2金钱 +27 收起 理由
+ 20 你是对的!谢谢!
jyz_0501 + 7 分享是一种美德!
发表于 2018-5-12 15:03:33 | 显示全部楼层
一直很好奇楼主的配色是自己手动一个一个拷进去的吗?
据说69 框架大改,估计会有一大批插件挂掉。
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-5-12 15:05:41 | 显示全部楼层
哈哈  给解决掉错误就告诉你
是vs code 自带的, 直接复制 连带着主题都复制过来了~~
发表于 2018-5-12 15:07:48 | 显示全部楼层
哈哈  给解决掉错误就告诉你
那么背景也整个换成黑色好啦。这样看的眼花
发表于 2018-5-12 15:16:04 | 显示全部楼层
69是不是自制插件要限制了?
活跃会员
发表于 2018-5-12 15:25:43 | 显示全部楼层
0.69我一直用,博联都正常使用呢,rmpro和黑豆
我就是六神
活跃会员教程狂人灌水之王
 楼主| 发表于 2018-5-12 15:30:06 | 显示全部楼层
我用的改版的MP1插件,不是用的 官方自带的MP1
发表于 2018-5-12 16:33:06 | 显示全部楼层
我的也挂了  每次升级 都要挂一次
发表于 2018-5-12 17:14:14 | 显示全部楼层
neroxps 发表于 2018-5-12 15:56
[md]~~估计升级到开发板就修好了这个BUG~~
~~https://github.com/home-assistan ... 581bb578cf88dd01693 ...
谢谢  加了hass  就好了
GMT+8, 2025-12-12 08:06 , Processed in 0.133903 second(s), 14 queries , MemCached On.
