查看: 8479|回复: 2
[技术探讨] 和风天气无法获取今天天气数据
发表于 2018-5-12 09:03:28 | 显示全部楼层 |阅读模式
参照蓝火帖子改造:https://bbs.hassbian.com/forum.p ... =%E5%A4%A9%E6%B0%94
添加今天天气数据,配置运行没有问题却无法获取数据,何故?
配置如下:
略
       self._forecast_url = "https://free-api.heweather.com/s6/weather/forecast?parameters"
略
        #今天天气预报
        try:
            r_forecast = requests.get(self._forecast_url, self._params, verify=True, headers=self._headers)
            con_forecast = r_forecast.json()
            self._day0_cond_txt = con_forecast["HeWeather6"][0]["daily_forecast"][0]["cond_txt_d"]
            self._day0_hum = con_forecast["HeWeather6"][0]["daily_forecast"][0]["hum"]
            self._day0_pcpn = con_forecast["HeWeather6"][0]["daily_forecast"][0]["pcpn"]
            self._day0_pres = con_forecast["HeWeather6"][0]["daily_forecast"][0]["pres"]
            self._day0_tmp_max = con_forecast["HeWeather6"][0]["daily_forecast"][0]["tmp_max"]
            self._day0_tmp_min = con_forecast["HeWeather6"][0]["daily_forecast"][0]["tmp_min"]
            self._day0_vis = con_forecast["HeWeather6"][0]["daily_forecast"][0]["vis"]
            self._day0_wind_spd = con_forecast["HeWeather6"][0]["daily_forecast"][0]["wind_spd"]
            self._day0_wind_sc = con_forecast["HeWeather6"][0]["daily_forecast"][0]["wind_sc"]
            self._day0_wind_dir = con_forecast["HeWeather6"][0]["daily_forecast"][0]["wind_dir"]
        except:
            _LOGGER.info("今天天气连接失败".join(con_forecast))
发表于 2018-6-1 08:47:20 | 显示全部楼层
请问你的问题解决了吗 我也遇到相同问题
发表于 2020-4-10 16:03:58 | 显示全部楼层
我也是 但是得到的邮件说是 试用超限
GMT+8, 2025-12-31 02:46 , Processed in 0.165218 second(s), 13 queries , MemCached On.
