查看: 2408|回复: 0
[求助] hk 連到 ha , sony tv 不顯示 問題
发表于 2018-5-9 23:09:30 | 显示全部楼层 |阅读模式
請高手出手幫助 ! 謝謝 !
ha 連到電視的控制 : 正常
hk 連到 ha 可以顯示 binary_sensor 的裝置
- hass 0.68- 以下是 ha 連到電視的套件https://community.home-assistant.io/t/sony-bravia-tv-component-with-pre-shared-key/30698
以下是錯誤信息
Error doing job: Future exception was never retrieved
Traceback (most recent call last):  File "/usr/lib64/python3.6/concurrent/futures/thread.py", line 56, in run    result = self.fn(*self.args, **self.kwargs)
File "/usr/lib/python3.6/site-packages/homeassistant/components/homekit_controller/__init__.py", line 243, in discovery_dispatch    device = HKDevice(hass, host, port, model, hkid, config_num, config)
File "/usr/lib/python3.6/site-packages/homeassistant/components/homekit_controller/__init__.py", line 73, in __init__    import homekit
File "/root/.homeassistant/deps/lib/python3.6/site-packages/homekit/__init__.py", line 23, in <module>    from homekit.protocol import perform_pair_setup, get_session_keys
File "/root/.homeassistant/deps/lib/python3.6/site-packages/homekit/protocol.py", line 21, in <module>    import py25519
File "/root/.homeassistant/deps/lib/python3.6/site-packages/py25519/__init__.py", line 252, in <module>    selftest()
File "/root/.homeassistant/deps/lib/python3.6/site-packages/py25519/__init__.py", line 221, in selftest    sk1 = Key25519()
File "/root/.homeassistant/deps/lib/python3.6/site-packages/py25519/__init__.py", line 120, in __init__    lib.ed25519_CreateKeyPair(
File "/root/.homeassistant/deps/lib/python3.6/site-packages/cffi_utils/sowrapper.py", line 151, in __getattr__    return self.__getattribute__(name)
AttributeError: 'SharedLibWrapper' object has no attribute 'ed25519_CreateKeyPair'
GMT+8, 2025-11-6 19:23 , Processed in 1.110464 second(s), 20 queries , MemCached On.
